39 Replies Latest reply on Jan 19, 2018 10:22 AM by JaimeGomez78
    RAM Preview – Not in real-time
    papanapa Level 1
      Hello.
      I'm having a hard time dealing with this new Preview in AE. A lot of times it is not giving me a real-time playback.
      It is nice to have the preview continuously playing while making some changes on the comp, but sometimes I would like to have a real-time preview, like the old RAM preview.
      Is it possible to generate a real-time RAM preview? I don't mind waiting for AE to render before playing back the animation.
      I have tried the Numpad 0 and also spacebar. I've tried to purge all, restart machine, etc...
      Thanks in advance.
      Best,
      Andre Arruda
      After Effects 2015.3 (13.8.0.144)
      Mac Pro (Late 2013)
      3.5 GHz 6-Core Intel Xeon E5
      64 GB 1866 MHz DDR3 ECC
        • 1. Re: RAM Preview – Not in real-time
          Pull your Preview panel down so you can see all of the options. Switch the preview shortcut dropdown to the Num 0 option and check to make sure it has the Cache before playback option checked. That should make it behave similar to the old RAM preview.
          If you have a preview cached and it's not playing those cached frames back in real time, there's a bug.
          One thing to try.
          Make your timeline smaller. I'm assuming you're working on a 4K or 5K screen. Shrink your timeline panel vertically so it takes up a lot less screen space and try again.
          If that doesn't help, try pressing ` to make your comp window fill the screen and try it.
          If that doesn't help, try putting another panel (such as the libraries panel) underneath the timeline.
          Please let us know your results.
          3 people found this helpful
          • 2. Re: RAM Preview – Not in real-time
            papanapa Level 1
            Szalam thanks for your reply.
            It seams to be a bug indeed. The checkbox "cache Before Playback" is checked.
            Putting the libraries panel under the timeline did help a lot but I'm still having some playback under real-time (27/28 out of 30fps).
            Thanks for ur help!
            U28D590 Display
            27.5-inch (3840 x 2160)
            AMD FirePro D700 6144 MB graphics
            • 3. Re: RAM Preview – Not in real-time
              So none of the other two suggestions worked, huh? Interesting.
              Please, please, please file a bug report and give them as much information as you can (including what you've tried and what worked). This is one of those really persistent bugs introduced by this new architecture that the Adobe people need more help squashing.
              • 4. Re: RAM Preview – Not in real-time
                Zulkifar2 Level 1
                I have the same problem here. Video preview was weird. Now that I'm previewing with an audio track I can definitely say that the preview is not realtime. Sometimes it doubles the frame, sometimes goes slower or faster. The audio sounds distorted and jumpy.
                • 5. Re: RAM Preview – Not in real-time
                  Did you try any of the things I suggested? If so, which ones and what were the results?
                  What exact version number of AE are you using?
                  What version number of your OS?
                  Please describe your computer hardware.
                  • 6. Re: RAM Preview – Not in real-time
                    PGH4LYF Level 1
                    The green bar used to mean a rock-solid assurance that this cached content will play back right now. It now isn't worth the pixels it's displayed in.
                    • 7. Re: RAM Preview – Not in real-time
                      Bernhard Naether
                      Hello, so now its for me also time to get into the discussion because I have the exact same issues with the RAM Preview.
                      What I tried and what helps to get around this:
                      - making the timelinewindow smaller, so its just some layers high
                      - moving the rendered workarea out of the timeline view
                      If I see the timeline in "normal" size and the rendered work area, it makes also a lot of these vertical lines which look like coming from the current time indicator.
                      My system is a Z800 Win10 PC with latest AE 13.8.1.38 running. AND I am working with a two 4K Monitor Setup, while Windows scales 125%.
                      Another "strange" behavior while RAM Preview is, that during the glitchy playback, the Disk Cache is creating a lot of workload on my Media Stripeset, which I would not really expect because it should play out of the RAM? Shouldnt it?
                      Maybe I also should file in a bug report...
                      • 8. Re: RAM Preview – Not in real-time
                        ananggadipa Level 1
                        Same here, I wonder when this would be fixed.
                        I'm using iMac 5K Late 2015. Latest AE & Mac as right now. Upgrading to 32GB RAM from 8GB not helping though.
                        Tried submit bug report but when I submit there's error messages.
                        • 9. Re: RAM Preview – Not in real-time
                          PerryPride
                          I have a simple animation which shouldn't be any problems at all to preview but even if I cache the preview, lover my timeline, add a panel beneath it it still previews in 9-15fps with a quarter resolution. This is insane! I need to render out my animation to see it in real time! Unacceptable! My impression is that it's better to install AE 2014 and work in that. The AE CC has had this problem all along!
                          I using a late 2015 iMac 27" 5K Retina
                          4GHz Intel core i7
                          32GB of RAM
                          • 10. Re: RAM Preview – Not in real-time
                            ananggadipa Level 1
                            The last one work for me (putting another panel underneath)
                            • 11. Re: RAM Preview – Not in real-time
                              Edward S Sanchez
                              Shrinking timeline seems to improve it. But I hope someone fixes this. I'm on a 5k iMac - I shouldn't be having this problem!
                              • 13. Re: RAM Preview – Not in real-time
                                Davide Boscolo Level 1
                                Still the same problem here even after the new updates. Cache Before Playback is on. Can't preview 4 seconds without distortions. I'm on a Mac Pro with SierraOS.
                                • 14. Re: RAM Preview – Not in real-time
                                  That's got to be really frustrating. My Mac doesn't have the issue, but that's because it's a 15-inch MacBook Pro from 2011, so I don't have a huge screen resolution. I'm sure this is a high-priority issue for the AE team at Adobe as it's affecting so many people. They've done a few things to fix the issue for some people (it's not nearly as much of an issue in the CC 2017 release as it was in the first CC 2015 release), but the main issue is still a problem it would seem.
                                  Hopefully they are close to a proper, real fix. They know it's a widespread issue that frustrates a lot of people, but it's taking a while to nail down the underlying cause. If you haven't yet, you could file a bug report. Give them as much technical information as you can about your system and the problem you're experiencing (but try to keep emotion out of it - I know it's frustrating and they know it's frustrating, so let's  just try to get it solved )..
                                  • 15. Re: RAM Preview – Not in real-time
                                    ccolbertemg Level 1
                                    Change the timeline to a Stacked Panel.  It should playback in realtime now.
                                    • 16. Re: RAM Preview – Not in real-time
                                      PerryPride Level 1
                                      That is so wierd! It did work for me though but how can that be an issue if its stacked or not?
                                      Anyway thanks a lot!
                                      • 17. Re: RAM Preview – Not in real-time
                                        Here's a simplified answer: Mac 10.11 changed how redraw rectangles are calculated when they intersect the region at the bottom of the application window between the rounded corners, which forced After Effects to invalidate how it was re-drawing the timeline and then draw a much bigger region than expected, which slowed down the refresh rate during previews. So, doing odd things with the UI fixes it in some cases (like docking a panel underneath.)
                                        Hopefully a proper fix from Adobe comes so workarounds like this aren't needed.
                                        • 18. Re: RAM Preview – Not in real-time
                                          Bernhard Naether Level 1
                                          What about the Windows version? Still the same Preview Issues here, also with CC 2017!
                                          • 19. Re: RAM Preview – Not in real-time
                                            If you are having issues with this on Windows, it may be similar symptoms, but it's an entirely different cause. I've heard only one or two other people on Windows with a similar issue. You should create a new thread (since it's a different problem) and share as much information as you can about your system. It's a very rare problem, so it's probably going to require a good bit of troubleshooting to find the cause.
                                            • 20. Re: RAM Preview – Not in real-time
                                              Everybody who is having this issue, please install the latest update that came out last night: After Effects CC (November 2017) Bug-Fix Update Is Now Available
                                              This update is 14.0.1 and should be a bug fix for this and several other disturbing issues - especially for Mac users. It does not fix all the bugs that are new with the CC 2017 release (Known issues in After Effects CC 2017), but it does fix some issues that have been plaguing After Effects since the first parts of the new architecture showed up in the CC 2015 release.
                                              If you can't see the update yet, you may need to wait a while until you see it as it can take up to 24 hours to populate an update across all the data centers. You may need to log out, relaunch the Creative Cloud app, and log in again.
                                              HUZZAH!
                                              • 21. Re: RAM Preview – Not in real-time
                                                ananggadipa Level 1
                                                just updated it, tried on one project, I think it's fixed now.
                                                thanks adobe.
                                                • 22. Re: RAM Preview – Not in real-time
                                                  Arkaik
                                                  Preview is — no one wants to edit footage in real time. BRING BACK RAM PREVIEW! I have the same problem as thousands of after effects users audio glitching during "Preview" then when it plays the audio it is actually out of sync, preview is never at frame rate, highly frustrating if you use any sort of audio with visual effects, or actually want to preview your work without having to pre render. I am running a mac pro 2015, and this software is just a load of B. I have been using after effects for over 5 years and didn't install the 2015 when they switched to "preview" as to me it seems ridiculous. After effects  cc ran better on my 2012 mac book pro than this does on my 2015 mac pro! The "RAM Preview" renders the frames first so then you are assured a smooth playback whatever ram you have installed, now there is no option for ram preview so the use of this program is pointless.  Does anyone know how to re-download CC2014 as now in my adobe account I can only access cc2015 which has the same render process as this. Adobe sort it out.
                                                  Moderator note: Please refrain from using profanity.
                                                  • 23. Re: RAM Preview – Not in real-time
                                                    Arkaik Level 1
                                                    I have paid more for adobe CC than I would if i bought the adobe package back when it was CS6, and now you screw over hardworking people who use your software daily so that you can try and make it cooler! Do everyone favour and test this on multiple machines with multiple different graphics cards before launching the update!!!! Thinking that everyone who uses after effects has a top spec desktop. No one I know who uses this software is happy with cc2015 or now cc2017 "preview" function, yet again you have forgotten about the general user. Please Adobe do some customer research before you bring out a product, ask consumers before you alienate yourself from the market
                                                    • 24. Re: RAM Preview – Not in real-time
                                                      PerryPride Level 1
                                                      Maybe it's a stupid question from my side but have you checked the "Cache Before Playback" box in the Preview window?
                                                      With that option checked it works fine on my late 2015 iMac since the update last night.
                                                      • 25. Re: RAM Preview – Not in real-time
                                                        Roei Tzoref Adobe Community Professional
                                                        you can have the old behaviour of RAM Preview by simply setting up your preview settings like this:
                                                        let's take a closer look at this option:
                                                        this is exactly how RAM Preview worked. some Mac systems had playback problems even with this checked on since 2015. I cannot imagine how frustrating it is. I am a windows user and my experience is a better and better playback with every version. the latest 14.0.1 update will hopefully put an end to these problems.
                                                        another thing to check: in my system in this version of CC2017 and in CC2015.3, it appears that hardware acceleration checked on is NOT good for my playback with audio. so I check it off:
                                                        2 people found this helpful
                                                        • 26. Re: RAM Preview – Not in real-time
                                                          I don't think it's a stupid question. Because he is asking for exactly this.
                                                          • 27. Re: RAM Preview – Not in real-time
                                                            ugop43432731
                                                            even with the update the ram preview is not as reliable as it used to be, i hate it.
                                                            this is classical adobe, they just add little changes to make the software looks cool, but they dont improve it. they should learn from maxon.
                                                            • 28. Re: RAM Preview – Not in real-time
                                                              papanapa Level 1
                                                              I just updated my After Effects but it is still not giving me real-time preview, annoying!!
                                                              Any thoughts or ideas?
                                                              • 29. Re: RAM Preview – Not in real-time
        What version number of your OS are you running?
        What exact version number of AE have you updated to?
        • 30. Re: RAM Preview – Not in real-time
        papanapa Level 1
        MacOS 10.12.3
        After Effects 14.1.0.57
        Just as an example, I've just created a simple FullHD 8 layers shape animation on position and it does not give me real-time preview.
        After the 3rd loop on the preview it started to run on 29.97fps. But if I stop the preview and press 0 again, without any changes, it won't play real-time preview on the first playback.
        My monitor (Samsung 4k) is running on 30Hz, even though the Mac Pro and the monitor both support 60Hz. Could that be an issue?
        Mac Pro (Late 2013)
        Monitor Samsung 28" 4k - U28D590
        Plugged with the HDMI cable provided with the monitor, directly into the HDMI port on the MacPro.
        • 31. Re: RAM Preview – Not in real-time
        Possibly. Your scene description should DEFINITELY have no problem playing back in real time, so something is amiss and that would be the first thing I'd troubleshoot if I were in your position.
        • 32. Re: RAM Preview – Not in real-time
        fitzfilmfx Level 1
        After effects is telling me it IS playing back in real time, but that definitely isn't the case. The image stutters along at 15 FPS (a guess). Any ideas?
        • 33. Re: RAM Preview – Not in real-time
        viktork55484552
        Hello, this is the end of 2017 and I have all updates on Ae CC 2017 MacOS 10.12.6
        and I still have this issue on 59,94 fps 1080p composition. The cached area doesn't playback properly and this is very annoying! because it's not obvious at first look and happens from time to time. You just can't get expected result (no matter preview resolution down factor) and the same time you can't understand is this animation timing or playback that is not synchronized.  I've tried all the tricks in the thread. Bigger work-areas works slower. I can't believe that this is not a joke to get in a situation when you simply can't finalize the urgent project because of this little annoying bug.
        • 34. Re: RAM Preview – Not in real-time
        papanapa Level 1
        Changing the monitor to 60Hz solved the problem here =]
        • 35. Re: RAM Preview – Not in real-time
        jackthegiantslayer Level 1
        Perhaps you should stop setting these forums to "ANSWERED" when they most certainly freaking are not.
        • 36. Re: RAM Preview – Not in real-time
        PolkaFever
        Well, to be fair, changing monitor refresh rate to 60Hz solved it for papanapa , so it's probably the right thing to do for this post. But clearly there are people coming to this post trying to find the answer, only to be let down. #metoo This post doesn't solve all these similar RAM preview issues. RAM previews have been rock solid in the past, and at the moment they are not!
        • 37. Re: RAM Preview – Not in real-time
        Landstreicher
        Got the same issue here on a windows machine, since i moved to a 4k Screen. It's a shame paying for those buggy Adobe software, yet nothing really improves over there years.
        my setup:
        Win10 (latest)
        AFX '18 (latest)
        Intel 2600k
        32gb Ram
        nvidia 980TI (hdmi 2.0 4k 60hz)
        LG 32UD89-W (4k 60hz)
        any ideas? the ridiculous stacking fix helped improving the framerate (yet this a terrible workaround). If i close the timeline, it says it's playing with full framerate (up to 100) on a full preview 3k sequence. but comparing it to a rendered clip in external video player, it's far away from being real time.
        so?
        • 38. Re: RAM Preview – Not in real-time
        StephaneA_AfterEffects Level 1
        Same issue here.
        My workstation:
        Win 10
        AE CC 2018 (15.0.0 build 180)
        Intel i7 5960x
        64 Go
        Nvidia 1080 ti
        BL 2711U Benq 4k (60 Hz)
        On the same machine, with the same project,  AE CC 2014 ram preview give me a rock solid fps playback.
        Since CC 2015 the ram preview is wrong with unconsistant framerate playback.
        • 39. Re: RAM Preview – Not in real-time
        JaimeGomez78 Level 1
        Same here. i don't know why something that works great before is now a pain. Plase Adobe, please..
