2 Replies Latest reply on Jun 30, 2016 3:40 AM by michelleh23292020
    Help with Signature Properties
      Hello I am trying to make certain text fields and group fields as read only once an electronic signature has been placed into the document, I then need to repeat this exercise a couple of times throughout the form.  After an incredibly frustrating time with the help desk they suggest I ask for help.  The Signature properties box has a drop down menu from which it indicates you can select certain fields.  At the moment all I can do is select all or deselect.  Failing this can someone help with some javascript so I can lock these fields.
      Thank you
        • 1. Re: Help with Signature Properties
          George_Johnson MVP & Adobe Community Professional
          Try using the spacebar to select/deselect individual fields and the tab and cursor keys to navigate in the list of fields.
          • 2. Re: Help with Signature Properties
            michelleh23292020 Level 1
            Hi George – AWESOME thank you!!
            I don’t suppose you know if I can
            create a value in a form using radio buttons, to then provide a tally score do
            you.  I have been working on a
            performance review and there is input for the employee and the manager.  I want to tally the managers scores behind
            the scenes to create an overall performance level.  For example
            Did not Meet = -2
            Needs improvement = -1
            Meets = 1
            Exceeds = 2
            Outstanding = 3
            This is in 8 places within the
            The scores should then tally to make
            an overall level of performance, so if someone gets 12 points they would be
            Meets, but if they scored less than 5 it would be Needs Improvement for
            Anyway I honestly cannot thank you enough.
