Do students have the ability to print or download their quiz results? If so, how do I enable?
Matt
It seems you have posted this same question twice under very similar thread titles.
Please do not double post.
thanks for that... no answer to question I see????
There is no default functionality in Captivate to allow students to download their quiz results. That's normally cared for by an LMS.
Printing a slide (e.g. the quiz result slide) is possible but people are often unhappy with the results because although you can set up a button to call up the default Print dialog in the web browser your learner will need to fiddle with the Print Settings to avoid getting part of the slide cut off. So it's not usually something course developers usually do.
Not sure if you're still looking for an answer. If you create a certificate of completion, the quiz results can be inserted on the certificate.
