I recently started having an issue where I notice that the color of my photos in the library view is different from the develop view in Lightroom. This has not happened in the past. See below picture.
I am running the 2015.6 release. I am not sure if this is a windows problem, a monitor profile problem, or a Lightroom problem. I would appreciate any help in troubleshooting this.
This is most likely caused by a defective monitor profile.
Try setting the monitor profile to sRGB as described here:
How do I change my monitor profile to check whether it’s corrupted? - The Lightroom Queen
If this fixes the problem, you should ideally calibrate your monitor with a hardware calibrator.
This solved the problem! My monitor (Samsung U32D970Q) claims to be "self-calibrating", but I don't know if that is bunk or not.
In any case, the colors look correct in library view now. Thanks for your help!
This is a wide gamut monitor. You really should set up the correct profile for this monitor that matches the settings you have set on the monitor.
Read about color management here: How to manage color in Lightroom
