7 Replies Latest reply on Jun 30, 2016 6:42 AM by karthiks94217840
    Apply paragraph style in below heading text
    karthiks94217840 Level 2
      Hi Friend,
      I was try to script, find and apply paragraph style "T1" for all heading "H1" below text only. I have place the screenshot for your reference.
      Otherwise my code also. Please suggest friends.
      My Code:
      var thisStyle, testStyle;
      var docRef = app.documents.item(0);
      var storyRef = docRef.stories.item(-1);
      var paraList = storyRef.paragraphs;
      var lastTest = paraList.length - 1;
      //repeat through array of paragraphs
      for (var i = 0; i < lastTest; i++) {
          thisStyle = paraList[i].appliedParagraphStyle.name;
          testStyle = paraList[i + 1].appliedParagraphStyle.name;
          if (thisStyle == "H1" && testStyle == "T") {
            paraList[i].appliedParagraphStyle = "T1";
      alert("Done")
      My Screenshot:
      Thanks in Advance
        • 1. Re: Apply paragraph style in below heading text
          It would really help if you also tell us what your code currently does.
          Just by looking at it, I am guessing what you get now is that the heading gets that new style "T1". Change
          to
          paraList[i+1].appliedParagraphStyle = "T1";
          should fix that.
          • 2. Re: Apply paragraph style in below heading text
            Hi Jongware,
            Thanks for your replay.
            I need:
            Find:
            <H1>Heading
            <T>Text
            Change to:
            <H1>Heading
            <T1>Text
            Otherwise, I try to your code. But not working. Please suggest one more.
            alert("Done")
            • 3. Re: Apply paragraph style in below heading text
              Jump_Over Level 5
              You need to stop looping before last para if yoar goal is to process para[i+1] inside this loop.
              However you could use find...change utility to match desired paras at once.
              Something like:
              var
                mDoc = app.activeDocument,
                mStory = mDoc.stories[-1], // last created story is a target
                mFound, cFound, mNext,
                mHead = mDoc.paragraphStyles.item("H1"),
                mWrongStyle = mDoc.paragraphStyles.item("T"),
                mGoodStyle = mDoc.paragraphStyles.item("T1");
              app.findTextPreferences = app.changeTextPreferences = null;
              app.findTextPreferences.appliedParagraphStyle = mHead;
              mFound = mStory.findText();
              while (cFound = mFound.pop()) {
                mNext = mStory.paragraphs.nextItem(cFound.paragraphs[-1]);
                if (mNext.isValid && mNext.appliedParagraphStyle == mWrongStyle)
                     mNext.appliedParagraphStyle = mGoodStyle;
              Jarek
              • 4. Re: Apply paragraph style in below heading text
                Hi together,
                please note also the two options we have:
                1. Apply a paragraphStyle by assigning a paragraphStyle with the "=" operand by using:
                text.appliedParagraphStyle =
                No options possible. Overrides are wiped totally.
                2. Method applyParagraphStyle( arg1, arg2 ) for all Text objects.
                Argument 1 defines the paragraphStyle that should be applied. Not optional.
                Argument 2 is optional and will clear or not clear overrides.
                Default is true. If set to false, it will maintain overrides as they are.
                Uwe
                • 5. Re: Apply paragraph style in below heading text
                  Hi Jarek,
                  Thank for your replay,
                  I'm try your code. But not working Jarek.
                  Result: undefined
                  What can i do?
                  Thanks in Advance
                  • 6. Re: Apply paragraph style in below heading text
                    Jump_Over Level 5
                    Result: undefined
                    What can i do?
                    add at the end of code:
                    result = "This is not a true if someone says I am not working";
                    OR
                    Describe more about "not working" symptoms (no doc?, no story?, no style?)
                    Jarek
                    • 7. Re: Apply paragraph style in below heading text
                      Hi Jarek,
                      One more thanks for you,
                      I have add your above code and run the script. That code changed to "result" comment only. But not full fill my requirements.
                      Thanks in Advance
