1 Reply Latest reply on Mar 16, 2009 3:58 PM by ChrisKStuart
    Cannot Set Text Value of "simpleContent" XML Element
    ChrisKStuart
      Imported WSDL but cannot set the text value of "simpleContent" XML Elements. See WSDL element definition and sample code below:
      // WSDL Element Definition
      <xsd:element maxOccurs="1" minOccurs="0" name="OpportunityName" type="xsdLocal2:queryType"/>
      <xsd:complexType name="queryType">
      <xsd:simpleContent>
      <xsd:extension base="xsd:string">
      <xsd:attribute name="sortorder" type="xsd:string"/>
      <xsd:attribute name="sortsequence" type="xsd:string"/>
      </xsd:extension>
      </xsd:simpleContent>
      </xsd:complexType>
      // Instantiate object
      var opptyQuery:OpportunityQuery = new OpportunityQuery();
      // Instantiate type
      opptyQuery.OpportunityName = new QueryType();
      // Set attribute values
      opptyQuery.OpportunityName.sortorder = "ASC";
      opptyQuery.OpportunityName.sortsequence = "1";
      Resulting XML output
      <xsdLocal2:OpportunityName xsi:nil="true" sortorder="ASC" sortsequence="1"/>
      Desired XML output:
      <xsdLocal2:OpportunityName sortorder="ASC" sortsequence="1">Acme Inc*</xsdLocal2:OpportunityName>
      What is the ActionScript code required to generate the desired XML output?
      Thanks!
        • 1. Re: Cannot Set Text Value of &quot;simpleContent&quot; XML Element
          ChrisKStuart Level 1
          Forgot to include generated code:
          * QueryType.as
          * This file was auto-generated from WSDL by the Apache Axis2 generator modified by Adobe
          * Any change made to this file will be overwritten when the code is re-generated.
          package generated.webservices{
          import mx.utils.ObjectProxy;
          import flash.utils.ByteArray;
          import mx.rpc.soap.types.*;
          * Wrapper class for a operation required type
          public class QueryType
          * Constructor, initializes the type class
          public function QueryType() {}
          public var sortorder:String;
          public var sortsequence:String;public function toString():String
          return sortorder.toString() + sortsequence.toString();
