3 Replies Latest reply on Mar 17, 2009 11:19 AM by Newsgroup_User
    Referencing THIS object from a function?
    rpeters1983
      This may be more of a general programming question, but I this is being done in AIR.
      myObject.addEventListener(MYEVENT, function ():void {
      // function code
      this.height = 200; // <----------- THIS LINE
      I need to reference the Application. When I use "this" it is obviously not referencing the Application (in my case, WindowedApplication) object. I'm sort of new to actionscript and flex. I need to change the height after the event has fired. Thanks.
      Ryan
        • 1. Referencing THIS object from a function?
          BuG300K
          Could you be looking for the apply() method?
          function.apply(object,[arg1,arg2])
          function would be the function you're calling
          object would be the object you're going to refer to as 'this'
          and [arg1,arg2] is an array of arguments you are passing (If any)
          Hope this helped!
          Edit :
          Also - you could pass your event object to the function and use the event.target property to access the element that called the function, like the following :
          • 2. Referencing THIS object from a function?
            Ansury Level 3
            You might want to do this:
            Application.application.height = 200;
            Or it may start with WindowedApplication with AIR, I forget.
            • 3. Re: Referencing THIS object from a function?
              Level 7
              "rpeters1983" <webforumsuser@macromedia.com> wrote in message
              news:gpm1il$51c$1@forums.macromedia.com...
              > done in
              > AIR.
              > // function code
              This is code from an AIR app I have:
              private function setLayoutProperties():void{
              switch(appWidth) {
              case FAT:
              this.x=areaRect.x;
              this.width=areaRect.width;
              toggleWindow.setStyle('icon', leftArrow);
              optionsButton.toolTip='Shrink window';
              //buttonHolder.setStyle('borderStyle', 'solid');
              //testDataGrid.includeInLayout=true;
              //testDataGrid.visible=true;
              break;
              case SKINNY:
              this.width=smallWidth;
              toggleWindow.setStyle('icon', rightArrow);
              optionsButton.toolTip='Grow window'
              //testDataGrid.includeInLayout=false;
              //testDataGrid.visible=false;
              //buttonHolder.setStyle('borderStyle', 'none');
              Maybe you will find it helpful;
              Amy
