7 Replies Latest reply on Jul 4, 2016 3:01 AM by tpk1982
    Overprint Issue
    tpk1982 Level 4
      I am using the below script for applying overprint ON/OFF in particular layer. It is working fine till now. But recently i noticed this is not applying correctly in the expanded stroke lines.
      My script:
      var w = new Window ("dialog");
      var radio_group = w.add ("panel");
      radio_group.alignChildren = "left";
      radio_group.onover = w.add ("radiobutton", undefined, "Overprint ON");
      radio_group.offover = w.add ("radiobutton", undefined, "Overprint OFF");
      radio_group.onover.value=true;
      w.add ("button", undefined, "OK");
      w.add ("button", undefined, "Cancel");
      var myResult = w.show();
      if(myResult == true){
          if (radio_group.onover.value ==  true){
              myON(true);
          else{myON(false);}
      //w.show ();
      function myON(Otrue){
      var doc = app.activeDocument;
      var items = doc.activeLayer.pageItems;
         for (var i = 0; i < items.length; i++) {
              doc.activeLayer.locked = false;
            app.executeMenuCommand ('selectall');
           app.executeMenuCommand ('ungroup');
                if(items[i].filled == true){
                    items[i].fillOverprint=Otrue;
              if(items[i].stroked == true){
                    items[i].strokeOverprint=Otrue;
      The below item is not applied:
      Please help to sort this problem.
      Karthi
        • 1. Re: Overprint Issue
          Silly-V Adobe Community Professional
          Hey Karthi, what's up my homie! Okay, so when you ungroup the items, may your item count be changing and screwing it all up?
          Try moving things that do not belong in your loop such as ungrouping and unlocking layer, outside of the loop. Good luck!
          • 2. Re: Overprint Issue
            tpk1982 Level 4
            Hi Silly-V,
            Tried and failed. I removed the lock and ungroup coding. But again it is not applied.
            If a stroked line expanding it turned as fill. Maybe this cause problem?
            Am not sure the terms about compound path.
            Scripting in Illustrator is tedious for me every time
            Karthi
            • 3. Re: Overprint Issue
              tpk1982 Level 4
              The script working if i use Release  Compound Path option
              Karthi
              • 4. Re: Overprint Issue
                tpk1982 Level 4
                var items = doc.activeLayer.compoundPathItems;
                even this also not taken as account.. my head is rounding now
                Please help
                • 5. Re: Overprint Issue
                  Ten A Adobe Community Professional
                  Try below:
                  app.activeDocument.compoundPathItems[0].pathItems[0].strokeOverprint = true;
                  • 6. Re: Overprint Issue
                    Alexander Ladygin Level 2
                    As an option:
                    var w = new Window ("dialog"),
                    if (myResult == true) {
                        if (radio_group.onover.value == true) myON(true);
                        else myON(false);
                    function myON (Otrue) {
                        var doc = app.activeDocument,
                            var item = items[i];
                            if ( items[i].typename === 'CompoundPathItem' ) {
                                item = items[i].pathItems[0];
                            if (item.filled) {
                                item.fillOverprint = Otrue;
                            if (item.stroked) {
                                item.strokeOverprint = Otrue;
                    • 7. Re: Overprint Issue
                      tpk1982 Level 4
                      Hi alexanderl15015835,
                      Awesome, it is working like a charm.. so happy...thanks you so much
                      @Ten A: Thanks for your answer
                      Regards,
                      Karthi
