7 Replies Latest reply on Jul 5, 2016 5:13 PM by Karl Heinz Kremer
    Question 1: How to add or use jQuery in Folder Level Adobe Javascript.  Question 2: How to write normal Javascript in Folder Level Adobe Javascript ie., getElementbyid etc...  Please find the code below which shows what I am referring to
    syedm23513233 Level 1
      Below is my Folder Level Javascript which comes as a Pop up when I click on a Custom created button in a PDF reader..
      I created a Test.js file and then pasted the below code in it. Then I copy pasted that file in the following path:  C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\JavaScripts
      Now I want to know how to add either jQuery Code or the Normal Javascript in the below code. Please give an example.
      Note: I am not using the Javascript Forms here. This is a folder ACROJS Javascript.
      // Start of Code
      app.addMenuItem({ cName: "PERSONAL INFO", cParent: "File", cExec: "helloWorld()" });
      var helloWorld = app.trustedFunction(function () {
          app.beginPriv();
      var dialog1 = {
      description:
      elements:
      type: "cluster",
      align_children: "align_left",
      elements:
      type: "static_text",
      type: "edit_text",
      alignment: "align_fill",
      width: 300,
      height: 20
      alignment: "align_left",
      type: "ok_cancel",
      ok_name: "Ok",
      cancel_name: "Cancel"
      app.execDialog(dialog1);
      app.endPriv();
      //End of Code
        • 1. Re: Question 1: How to add or use jQuery in Folder Level Adobe Javascript.  Question 2: How to write normal Javascript in Folder Level Adobe Javascript ie., getElementbyid etc...  Please find the code below which shows what I am referring to
          You can't use jQuery in Acrobat. Well, you can install it as a folder-level script, but it doesn't make any sense. The functions in it have no relevance in this environment. They were developed for web-based JS. Same goes for getElementbyid.
          If you describe what you want to achieve we might be able to help you using the tools which are available and relevant.
          • 2. Re: Question 1: How to add or use jQuery in Folder Level Adobe Javascript.  Question 2: How to write normal Javascript in Folder Level Adobe Javascript ie., getElementbyid etc...  Please find the code below which shows what I am referring to
            Karl Heinz Kremer Adobe Community Professional
            Let's take a step back and figure out what "normal" JavaScript is. Normal for you probably means browser based, but that is only your point of reference. Any JavaScript implementation consists of at least the JavaScript core language, and that is what you have in both Acrobat's JavaScript, but also in the browser based JavaScript. Things like the JavaScript syntax are handled in that part of the language, how different types are handled (numbers, strings, arrays, classes, ...), but also a number of library items like e.g. the Date object. In addition to that core language, almost all JavaScript implementations have a second part, which is application specific. In the browser, you are dealing with HTML and windows, and other things that only make sense in the browser environment. In Acrobat, you deal with PDF documents, annotations, form fields,  and more. The web browser specific Javascript is not more or less "normal" than the implementation in Acrobat. You have to get used to a different environment, and that is what the Acrobat JavaScript API reference is for. You will find all Acrobat specific objects and methods described in there. What makes things a bit harder for you is that you probably don't know where the dividing line is between the core language and browser specific extensions, so you will have some re-learning of the language ahead of you.
            2 people found this helpful
            • 4. Re: Question 1: How to add or use jQuery in Folder Level Adobe Javascript.  Question 2: How to write normal Javascript in Folder Level Adobe Javascript ie., getElementbyid etc...  Please find the code below which shows what I am referring to
              Thanks for the reply -> that was a helpful answer.
              I have designed the below and I don't want the empty space to appear.
              The empty space should be replaced by the Hiring Info.
              Requirement:
              In the screen 1 on Left the Empty space should not appear at all.
              In the Screen 2 on the right the Empty space on the Top should not appear. It should be replaced by the Hiring Information Cluster Block.
              I need a Grid layout in which I can place my Fields.
              Please find below my complete code.
              ////My code
              // This should be pasted in the folder : C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\JavaScripts
              app.addMenuItem({ cName: "Hiring Info", cParent: "File", cExec: "helloWorld()" });
                  app.beginPriv();
                  var dialog2 =
                      initialize: function (dialog) {
                          dialog.visible({ "CLU2": false });
                      rd01: function (dialog) {
                          // First Option - Enable
                          dialog.visible({ "CLU1": true });
                      rd02: function (dialog) {
                          dialog.visible({ "CLU1": false });
                          dialog.visible({ "CLU2": true });
                      // The Dialog Description
                      description:
                          elements:
                              type: "view",
                              align_children: "align_center",
                              elements:
                bold: true,
                font: "dialog",
                char_width: 30,
                height: 20,
                                  type: "cluster",
                                  align_children: "align_row",
                                  elements:
                                      type: "view",
                                      elements:
                                          type: "radio",
                                          item_id: "rd01",
                                          group_id: "rado",
                                      type: "view",
                                      elements:
                                          type: "radio",
                                          item_id: "rd02",
                                          group_id: "rado",
                              // Add the Individual Types....
                              //First
                                  type: "cluster",
                                  item_id: "CLU1",
                                  elements:
                type: "button",
                item_id: "BUT1",
                bold: true,
                font: "dialog",
                width: "40",
                height: 20,
                                      type: "view",
                                      elements:
                                          item_id: "1000",
                                          width: 100
                                          item_id: "1001",
                                          type: "edit_text",
                                          width: 100,
                                          height: 20
                                      type: "view",
                                      elements:
                                          item_id: "1002",
                                          width: 100
                                          type: "edit_text",
                                          width: 100,
                                          item_id: "1003",
                                          height: 20
                                      type: "view",
                                      elements:
                                          item_id: "1004",
                                          width: 100
                                          type: "edit_text",
                                          width: 100,
                                          item_id: "1005",
                                          height: 20
                                  type: "cluster",
                                  item_id: "CLU2",
                                  elements:
                type: "button",
                name: "Hiring Information",
                bold: true,
                item_id: "BUT2",
                font: "dialog",
                width: "40",
                height: 20,
                                      type: "view",
                                      elements:
                                          item_id: "1008",
                                          width: 100
                                          type: "edit_text",
                                          item_id: "1009",
                                          width: 100,
                                          height: 20
                                      type: "view",
                                      elements:
                                          name: "Assigned Manager",
                                          item_id: "1010",
                                          width: 100
                                          type: "edit_text",
                                          item_id: "1011",
                                          width: 100,
                                          height: 20
                                      type: "view",
                                      elements:
                                          item_id: "1012",
                                          width: 100
                                          type: "edit_text",
                                          item_id: "1013",
                                          width: 100,
                                          height: 20
                                  type: "ok_cancel_other",
                                  ok_name: "Ok",
                                  cancel_name: "Cancel",
                other_name: "Reset"
                              type: "gap", //add a small vertical gap between
                              height: 20 //..radio fields and buttons
                      // End of Code for linking the Document for the Client....
                  app.execDialog(dialog2);
                  app.endPriv();
              • 7. Re: Question 1: How to add or use jQuery in Folder Level Adobe Javascript.  Question 2: How to write normal Javascript in Folder Level Adobe Javascript ie., getElementbyid etc...  Please find the code below which shows what I am referring to
                You are just hiding the information that you don't want to see, but that does not remove it. It is still there and it is still occupying space - hence the blank areas. I would not hide the elements that are not relevant for a given configuration, but disable them via dialog.enable() (which is not documented, but used in the samples to app.execDialog()). This way, there is no empty space in your dialog, and the user knows that depending on which function is selected, one group vs. the other group of elements becomes active.
