7 Replies Latest reply on Jul 8, 2016 3:02 AM by Loic.Aigon
    GUI: Updating an edittext type box
    beltan5
      Hi all.
      I'm a database developer by profession. Doing some work, however, in ID for a client. In my down time I'm exploring scripting. I built a cool GUI for the scripts that I'll use while working on a client's document.
      On the initial running of the script that generates the GUI, an edit text box gets populated with the names of the layers in this document. If the layers are NOT set how I need them for the client, then I run an "Set Layers" script which adds a 2nd layer, renames both layers and such.
      What I need is that "Set Layers" script to update the textbox in my GUI:
      How do I get what temporarily shows up in the Alert into that edit-text field? How do I pull the object name from that? When the window generates, this code generates that edittext box.
      utilityGroupThree.add ("statictext",undefined,"Layers:");
         var myTextLayers = utilityGroupThree.add("edittext", undefined,layerNames);
          myTextLayers.characters = 10;
      i'm guessing the name of the textbox doesn't stay. Can I assign this text box something so that I can grab it for a function called on a button click?
      Thanks.
        • 1. Re: GUI: Updating an edittext type box
          Vamitul Level 4
          myTextLayers.text='Yada yada ho!"
          • 2. Re: GUI: Updating an edittext type box
            beltan5 Level 1
            Hmm. That doesn't seem to work. the debugger says myTextLayers is undefined. I would have thought the name of the object would be retained in the session, but that doesn't seem to work...
            Thanks for your help.
            • 3. Re: GUI: Updating an edittext type box
              Loic.Aigon Adobe Community Professional
              Hard to explain without more code but Vamitul suggestion should work.
              • 4. Re: GUI: Updating an edittext type box
                beltan5 Level 1
                I would have thought so too. I tried a lot of attributes of the edit text box. But it seems that after the window is generated, the edittext field doesn't keep its name, so I can't add to it or change it.
                I'm overall not really sure how ExtendScript works. In a browser and pure JS, the object would retain its name, right? Does a window, in the session, retain the name of objects?
                Here's the code that creates the edittext area:
                for (i = 0; i < countLayers ; i++) {
                    var layerName = myLayer.item(i).name;
                    layerNames.push(layerName);
                    //updateLayerInfo
                var setLayersCheckbtn = utilityGroupThree.add('button',undefined,'Check Layers');
                        setLayersCheckbtn.onClick = function() { updateLayerInfo()};
                var setLayersbtn = utilityGroupOne.add('button',undefined,'Set Layers ');
                        setLayersbtn.onClick = function() { checkLayer()};
                Here's the code that is supposed to recheck the layer names and report them (called from the "Check Layers" button):
                function updateLayerInfo () {
                    var myDocument = app.documents.item(0);
                    var myLayer = myDocument.layers;
                    var countLayers = myLayer.length;
                var layerNames = new Array( );
                alert (layerNames);
                myTextLayers.text = layerNames;
                //windowClose
                • 5. Re: GUI: Updating an edittext type box
                  Your code works just fine. The only reason I can think of about ScriptUI doing not what it is asked is that an uncaught error raised before the ui change. (Those errors are not thrown through the UI).
                  Try converting array to string as:
                  myTextLayers.text = layerNames.join("");
                  • 6. Re: GUI: Updating an edittext type box
                    beltan5 Level 1
                    Thank you for your advice. I appreciate your attention and support in this matter.
                    I still can't get it to work with your suggestion. Long after the window script runs creating the panel (not a dialog), the function updateLayerInfo() can't find that edittext box in the window UI. It certainly works when the window script first runs; just not after.
                    But I'll just use the alert function to show me the layer names. That seems reasonable.☺ I did way more on this than I really needed to, but that's okay. The learning is the best.
                    • 7. Re: GUI: Updating an edittext type box
                      It's probably a scope issue
                      Given that you have
                      var buildUI = function() {
                           var w = new Window …
                           var myTextLayers = …
                      and then
                      var updateLayerInfo = function() {
                           myTextLayers .text = "rototo"
                      That fails because even if by not using var in updateLayerInfo made your myTextLayers variable a global one, the myTextLayers variable you are looking at is actually contained in the buildUI scope so it's local. At the global level, myTextLayers is…undefined.
                      So you need to either put your updateLayerInfo inside the buildUI scope,
                      or pass myTextLayers as argument  : updateLayerInfo (myTextLayers),
                      or make myTextLayers a global variable inside the buildUI function.
                      More infos here:
                      JavaScript Scope
                      HTH
                      Loic
                      Ozalto | Productivity Oriented - Loïc Aigon
