The previous forum I posted to states that the question is assumed answered.
However, Flash 22 (when I indicate that I will allow it to run) is still stalling/freezing Firefox.
This is not an insignificant problem. I downgraded to Flash 21 for a while, but then re-upgraded to Flash 22, thinking that the problem would be fixed. The problem is not fixed at all.
Error message reads as follows:
Warning: Unresponsive script
A script on this page may be busy, or it may have stopped responding. You can stop the script now, open the script in the debugger, or let the script continue.
Script: http://connect.facebook.net/en_US?.....
[Checkbox] Don't ask me again.
[Choices:] Continue/Debug script/Stop script
This script keeps appearing and reappearing. usually not long enough for me to click on "Stop script."
I therefore have to use the Task Manager to stop Firefox.
Problem repeats, and repeats, and repeats. No variation.
Please inform whether this problem is being worked on.
Please log a bug for this.
Before posting, please read and provide the following information:
I did log a bug on 7/3, the same day that Satinder Bains (see above) requested it.
A few days ago I started using Flash 22 again. To my surprise and satisfaction, flash is started working with no stalling or freezing.
Thanks to those who worked diligently to correct this. (I am not discounting that some of the people who resolved the problem may be from other software companies/Mozillia plugin creators who also became aware of this bug.)
To the previous poster: my OS is 64 bit.
Thanks -
TCGeekette​
I have some information for you.
Please try using the 64 bit version of Firefox, it is much more stable on 64bit systems.
I have a guide with the download link and some other useful information
Guide to Manually updating Flash Player - Windows
I would also try a uninstall and re-install as well, that is in the guide its only two steps
For Firefox download the 64bit version, uninstall the 32bit version ( don't worry about bookmarks they will not get deleted unless you manually choose to )
Then Install the 64 bit version. That unresponsive script thing you are seeing ; Firefox 64 bit is 99% immune to that issue.
Hopefully that will resolve your issue
Best Regards
Please make my post helpful or answered if I have assisted you
Thank You
This is NOT a flash bug as far as I know as it is a Firefox issue and the 32bit version of Firefox
