2 Replies Latest reply on Jul 6, 2016 2:36 AM by K.Daube
    Updating a global array
    K.Daube Level 1
      Dear friends!
      I do not remmber what I have done some days ago - global arrays are no more updated. I have cut it down to this mechanism:
      var arrayOfObjects = [];             // global Array
      UpdateA (arrayOfObjects);            // array is NOT updated
      $.writeln ("1) arraOfObjects = \n" + arrayOfObjects);
      UpdateB (arrayOfObjects);            // array is NOT updated either
      $.writeln ("2) arraOfObjects = \n" + arrayOfObjects);
      function UpdateA (gArray, someotherStuff) {
      var locObject = new Object();
          locObject.Name = "A";
          locObject.Item = "Something";
          gArray = [locObject, locObject, locObject];
      $.writeln ("A) gArray = " + gArray);
      function UpdateB (gArray, someotherStuff) {
      var localArray = [locObject, locObject, locObject];
          gArray = localArray.slice();
      $.writeln ("B) gArray = " + gArray);
      The output is quite clear: the gobal array is not touched at all by the Update functions:
      A) gArray = [object Object],[object Object],[object Object]
      1) arraOfObjects =
      B) gArray = [object Object],[object Object],[object Object]
      2) arraOfObjects =
      Have I become blind?
      In the original script the update function collects markers and (did so) put them into the global array.
      It seems that I need a tool to save changes ...
      Klaus
        • 1. Re: Updating a global array
          K.Daube Level 1
          Can please someone enlighten me, why this works:
          UpdateA (arrayOfObjects);            // array _is_ updated
          $.writeln ("Global: arraOfObjects = " + arrayOfObjects);
              for (var j= 0; j < 3; j++) {
                gArray.push(locObject);
          $.writeln ("Inside func: gArray = " + gArray);
          And this does not work?
          In both functions gArray receives stuff by a method - So what is the difference?
          • 2. Re: Updating a global array
            K.Daube Level 1
            Dear friends,
            After much fiddling around I have found solutions to the desired array functions. One essential hint was that
            gArray = [];
            wihin a function creates a new array, not emptying the original one.
            So Now I have a set of functions for arrays. It may be trivial for You, but not for me...
            gArray = [];
            gArray2 = ["1", "2", "3", "4", "5"];
            AmendArray (gArray, "one", "two", "three", "four", "five");          //1 gArray =
            $.writeln ("1 gArray = \n   " + gArray);                             //  one,two,three,four,five  OK
            DeleteArrayItem (gArray, 1);                       // remove item 2  //2 gArray =
            $.writeln ("2 gArray = \n   " + gArray);                             //  one,three,four,five      OK
            CopyArray (gArray, gArray2);                                         //3 gArray =
            $.writeln ("3 gArray = \n   " + gArray);                             //  1,2,3,4,5                OK
            InsertArrayItem (gArray, 1, "two");                                  //4 gArray =
            $.writeln ("4 gArray = \n   " + gArray);                             //  1,two,2,3,4,5            OK
            ReplaceArrayItem (gArray, 3, "three");                               //5 gArray =
            $.writeln ("5 gArray = \n   " + gArray);                             //  1,two,2,three,4,5        OK
            ExtractArray (gArray, gArray2, 2, 3);          // extract items 3..4 //6 gArray, gArray2          OK
            $.writeln ("6 gArray, gArray2 = \n   " + gArray + "\n   " + gArray2);//  3,4,5
        //  1,2
            function AmendArray (array, items) {
              var j, n = arguments.length;
              for (j = 1;  j < n; j++) {
                array.push(arguments[j]);
            function DeleteArrayItem (array, index) {
            // array.splice(index, n-delete,insert-item1,.....,itemX)
              array.splice (index, 1);
            function CopyArray (target, source) {
            // http://www.2ality.com/2012/12/clear-array.html tells:
            // target = [];        Creates extra garbage: existing array not reused, a new one is created.
            // target.length = 0;  JavaScript semantics dictate that all elements must be deleted; costs time
              var j, n = source.length;
              target.length = 0;
              for (j=0; j < n; j++) {
                target.push(source[j]);
            function ReplaceArrayItem (array, index, item) {
              array.splice (index, 1, item);
            function InsertArrayItem (array, index, item) {
            // Insert item after index, pushing the rest 'upwards'
              array.splice (index, 0, item);
            function ExtractArray (target, source, index, n) {
            // extract n items starting at index in source giving new array target
            // Create local extract and use copy method
              var lArray = source.splice(index, n);
              var j, n = lArray.length;
              target.length = 0;
                target.push(lArray[j]);
            Thanks for listening and forcing me to think myself!
