11 Replies Latest reply on Jul 6, 2016 10:27 PM by sreekarthik.k@gmail.com
    How to highlight continue 3 line end hyphen-nit word
    karthiks94217840 Level 2
      Dear Friends,
      I need your help!
      How to highlight the continue 3 line end hyphen-nit word? Screenshot below.
      I have highlight for all hyphen-nit word (below my code). But, i need to highlight for continue 3 line hyphen-nit words only. Otherwise no need single and double word hyphen highlight. Please suggest friends
      My code:
      var doc = app.activeDocument,
          _stories = doc.stories;
      for(var i=0;i<_stories.length;i++)
              var _lines = _stories[i].lines;
              for(var j=0;j<_lines.length;j++)
                      if(_lines[j].words[-1].lines.length >= 2)
                              _lines[j].words[-1].fillColor = "Green";
      Thanks in advance
        • 1. Re: How to highlight continue 3 line end hyphen-nit word
          Dear Friend,
          One quick question: I have recess the above question is possible to script? Yes or No.
          Thanks in Advance
          • 2. Re: How to highlight continue 3 line end hyphen-nit word
            Dear Friends,
            Please, give me any one solution? very urgent.
            That is possible?
            Thanks in Advance
            • 3. Re: How to highlight continue 3 line end hyphen-nit word
              Trevorׅ Adobe Community Professional
              Hi Karthiks
              If you are looking to highlight all occurrences of 3 or more consecutive hyphenated last words you can try.
              I'm not claiming it's a particularly efficient way of doing it.
              function color3PlusHyphenateted() {
                  var doc, stories, n, l, lastWords, firstWords, hyphenateted, e, i, lwl, HReg;
                  HReg = /HHH+/g;
                  doc = app.activeDocument;
                  stories = doc.stories.everyItem().getElements().slice(0);
                  l = stories.length;
                  for (n = 0; n < l; n++) {
                      lastWords = [0].concat([], stories[n].lines.everyItem().words[-1].getElements().slice(0));
                      firstWords = stories[n].lines.everyItem().words[0].getElements().slice(0);
                      lwl = lastWords.length;
                      hyphenateted = [];
                      for (i = 1; i < lwl; i++) {
                          hyphenateted[i] = (lastWords[i] === firstWords[i]) ? 'H' : '0';
                      hyphenateted = hyphenateted.join('');
                      while (e = HReg.exec(hyphenateted)) {
                          for (i = e.index + 1; i <= HReg.lastIndex; i++) {
                              lastWords[i].fillColor = doc.colors[3];
                      HReg.lastIndex = 0;
              app.doScript(color3PlusHyphenateted,ScriptLanguage.JAVASCRIPT,undefined, UndoModes.ENTIRE_SCRIPT, 'color3PlusHyphenateted');
              If you only highlight all occurrences of exactly 3 consecutive hyphenated last words change the line
              HReg = /HHH+/g;
              to
              HReg = /HHH/g;
              HTH
              Trevor
              • 4. Re: How to highlight continue 3 line end hyphen-nit word
                This is a more normal way to do it.
                    var doc, stories, n, l, lastWords, firstWords, hyphenateted, isHyphanated, i, j, lwl, hyphenatetedLen;
                    l = stories.length;
                        hyphenateted = [];
                        for (i = 0; i < lwl; i++) {
                            isHyphanated = (lastWords[i] === firstWords[i]);
                            if (isHyphanated) {
                                hyphenateted.push(lastWords[i]);
                            } else {
                                hyphenatetedLen = hyphenateted.length;
                                if (hyphenatetedLen > 2) {
                                    for (j = i - hyphenatetedLen; j < i; j++) {
                                        lastWords[j].fillColor = doc.swatches[6];
                                hyphenateted = [];
                app.doScript(color3PlusHyphenateted, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, 'color3PlusHyphenateted');
                • 5. Re: How to highlight continue 3 line end hyphen-nit word
                  Edit above to correct a bug
                  • 6. Re: How to highlight continue 3 line end hyphen-nit word
                    Dear Friend Trevor,
                    Very very Thank you soooooo mach for you Trevor .
                    Your coding is working super-good. Really, your are save my life. You are super.
                    One more Thanks Thanks Thanks
                    • 7. Re: How to highlight continue 3 line end hyphen-nit word
                      Dear Friends,
                      One more help! The same thing for in above answer.
                      @Trevor: I need to highlight for including all hard hyphens also. In below formula for find to all hard hyphens words. But, I don't now how to add that formula in your above code? (please use correct answer code).
                      @Formula: "\\w+[-~=~-~_]"
                      @Example: Only for, both soft hyphen between hard hyphen will be come. That time i need to highlight for all 3 hyphen words (soft & hard hyphens). I have place screenshot for your reference.
                      For highlight in the center word is hard hyphen word.
                      Thanks in Advance
                      • 8. Re: How to highlight continue 3 line end hyphen-nit word
                        Thanks in Advance
                        I only read that bit afterwards so you'll have to do
                        I prefer the 2nd answer.
                            var doc, stories, n, l, lastWords, firstWords, hyphenateted, isHyphanated, i, j, lwl, hyphenatetedLen, everyLastWord;
                            l = stories.length;
                            app.findGrepPreferences = app.changeGrepPreferences = null;
                            app.findGrepPreferences.findWhat = '\-$';
                                everyLastWord = stories[n].lines.everyItem().words[-1];
                                lastWords = [0].concat([], everyLastWord.getElements().slice(0));
                                everyLastWord = everyLastWord.findGrep();
                                everyLastWord = [0].concat([], everyLastWord);
                                hyphenateted = [];
                                    isHyphanated = ((everyLastWord[i] && everyLastWord[i].length) || (lastWords[i] === firstWords[i]));
                                    if (isHyphanated) {
                                    } else {
                                                lastWords[j].fillColor = doc.swatches[9];
                                        hyphenateted = [];
                        • 9. Re: How to highlight continue 3 line end hyphen-nit word
                          Excuse the lack of code formatting above, Jives is playing up today!
                          • 10. Re: How to highlight continue 3 line end hyphen-nit word
                            Dear Friend Trevor,
                            Again and again - Thank you so mach for you Trevor .
                            That coding also working super-good. You are super man.
                            One more Thanks so mach
                            • 11. Re: How to highlight continue 3 line end hyphen-nit word
                              Level 1
                              While running the script it throw the below erro in the 10th line. Please advice.
