30 Replies Latest reply on Mar 14, 2018 2:24 PM by meriçg75308842
    Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
    arunas36741820 Level 1
      I'm trying the below code to get a stamp with the multiple input. Based on the selection of option buttons, I require the stamp to be updated. I'm unable to find the error. Could someone help pl.
        • 1. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
          if(event.source.forReal && (event.source.stampName == "#pfP__PjJ7SwG7RRWsGspWA"))
          if ("ok" == app.execDialog(DiaBox))
          this.getField("Approved - Submit Final Copies").checkThisBox(0, DiaBox.bChk1);
          this.getField("Approved as commented - Resubmit").checkThisBox(0, DiaBox.bChk2);
          this.getField("Not Approved - Resubmit").checkThisBox(0, DiaBox.bChk3);
          this.getField("Cleared for Manufacture").checkThisBox(0, DiaBox.bChk4);
          this.getField("For Information").checkThisBox(0, DiaBox.bChk5);
          var cMsg = DiaBox.byName;
          event.value = "Remarks # " + cMsg;
          event.source.source.info.exhibit = cMsg;
          var DiaBox =
          result:"cancel",
          DoDialog: function(){return app.execDialog(this);},
          bChk1:true,
          bChk2:false,
          bChk3:false,
          bChk4:false,
          bChk5:false,
          stredt1:"",
          initialize: function(dialog)
          var dlgInit =
          "Chk1": this.bChk1,
          "Chk2": this.bChk2,
          "Chk3": this.bChk3,
          "Chk4": this.bChk4,
          "Chk5": this.bChk5,
          "Name": this.stredt1,
          dialog.load(dlgInit);
          commit: function(dialog)
          var oRslt = dialog.store();
          this.bChk1 = oRslt["Chk1"];
          this.bChk2 = oRslt["Chk2"];
          this.bChk3 = oRslt["Chk3"];
          this.bChk4 = oRslt["Chk4"];
          this.bChk5 = oRslt["Chk5"];
          this.byName = oRslt["Name"];
          description:
          elements:
          type: "view", elements:
          type: "view",
          char_height: 10,
          elements:
          type: "static_text",
          item_id: "stat",
          name: "Please select the review category:",
          width: 152,
          height: 23,
          char_width: 15,
          alignment: "align_fill",
          font: "dialog",
          type: "radio",
          item_id: "Chk1",
          group_id: "rado",
          name: "Approved - Submit Final Copies",
          type: "radio",
          item_id: "Chk2",
          group_id: "rado",
          name: "Approved as commented - Resubmit",
          type: "radio",
          item_id: "Chk3",
          group_id: "rado",
          name: "Not Approved - Resubmit",
          type: "radio",
          item_id: "Chk4",
          group_id: "rado",
          name: "Cleared for Manufacture",
          type: "radio",
          item_id: "Chk5",
          group_id: "rado",
          name: "For Information",
          { type: "edit_text",
          item_id: "Name",
          height: 23,
          char_width: 20,
          char_height: 10,
          alignment: "align_center",
          name: "Enter Initials",
          type: "ok_cancel",
          • 2. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
            The above code is working only if my source stamp file is open first before the pdf in which I want to stamp is open. if the source stamp file is not open, the pop up box for input is not opening! it directly applies the seal on PDF without taking the user input
            • 3. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
              Where did you place this code? Are you sure you're using the correct stampName value?
              • 4. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                Yes! I have rechecked the stamp name. and I have placed the code in custom calculation script of one text box... textbox2.
                • 5. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                  Sorry for insisting, but this is crucial... How did you check the stamp name?
                  • 6. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                    There is only one stamp name , that is one used by JavaScript, and then there is the stamp user label that one sees displayed by the UI.
                    Dynamic stamp secrets using JavaScript and Acrobat XI by Thom Parker
                    • 7. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                      I placed the stamp on PDF and ... in console I gave the    this.selectedAnnots[0].AP  ....
                      this is the stamp name
                      #pfP__PjJ7SwG7RRWsGspWA ...
                      • 8. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                        OK, that's fine.
                        I think the issue is that you defined the dialog object after the code where you're calling it. You should move the definition of DiaBox to the top of the code.
                        • 9. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                          Thank you soo much, it worked when I changed the order!!! cool
                          • 10. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                            So the final code that worked....
                            var DiaBox =
                            result:"cancel",
                            bChk1:false,
                            bChk2:false,
                            bChk3:false,
                            bChk4:false,
                            bChk5:false,
                            stredt1:"",
                            var dlgInit =
                            "Opt1": this.bChk1,
                            "Opt2": this.bChk2,
                            "Opt3": this.bChk3,
                            "Opt4": this.bChk4,
                            "Opt5": this.bChk5,
                            this.bChk1 = oRslt["Opt1"];
                            this.bChk2 = oRslt["Opt2"];
                            this.bChk3 = oRslt["Opt3"];
                            this.bChk4 = oRslt["Opt4"];
                            this.bChk5 = oRslt["Opt5"];
                            description:
                            elements:
                            type: "view",
                            elements:
                            type: "view",
                            char_height: 10,
                            elements:
                            item_id: "stat",
                            width: 152,
                            height: 23,
                            char_width: 15,
                            font: "dialog",
                            type: "radio",
                            item_id: "Opt1",
                            group_id: "rado",
                            type: "radio",
                            item_id: "Opt2",
                            group_id: "rado",
                            type: "radio",
                            item_id: "Opt3",
                            group_id: "rado",
                            type: "radio",
                            item_id: "Opt4",
                            group_id: "rado",
                            type: "radio",
                            item_id: "Opt5",
                            group_id: "rado",
                            type: "edit_text",
                            item_id: "Name",
                            height: 35,
                            char_width: 20,
                            char_height: 10,
                            name: "Enter Comments",
                            type: "gap",    //Add a small vertical gap between
                            height: 10      //..radio fields and buttons
                            type: "ok_cancel",
                            this.getField("Text3").value = ((!identity.name || identity.loginName != (event.source.source || this).Collab.user) ? (event.source.source || this).Collab.user : identity.name);
                            this.getField("Text1").value = util.printd("h:MM tt,dd-mmm-yyyy", new Date());
                            this.getField("cbx1").checkThisBox(0, DiaBox.bChk1);
                            this.getField("cbx2").checkThisBox(0, DiaBox.bChk2);
                            this.getField("cbx3").checkThisBox(0, DiaBox.bChk3);
                            this.getField("cbx4").checkThisBox(0, DiaBox.bChk4);
                            this.getField("cbx5").checkThisBox(0, DiaBox.bChk5);
                            console.println("Success1");
                            event.value = "Comment # " + cMsg;
                            • 11. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                              armies19630736
                              I tried to follow this solution but mine doesn't populate the radio button selection onto the actual stamp. It will be print the info on By: and Date: but the rest will not populated. Please help. My code is  below.
                              var DiaBox =
                              result:"cancel",
                              bChk1:false,
                              bChk2:false,
                              bChk3:false,
                              bChk4:false,
                              stredt1:"",
                              var dlgInit =
                              "Choice1": this.bChk1,
                              "Choice2": this.bChk2,
                              "Choice3": this.bChk3,
                              "Choice4": this.bChk4,
                              "Comment": this.stredt1,
                              var results = dialog.store();
                              this.bChk1 = results["Choice1"];
                              this.bChk2 = results["Choice2"];
                              this.bChk3 = results["Choice3"];
                              this.bChk4 = results["Choice4"];
                              this.byName = results["Name"];
                              description:
                              elements:
                              type: "view",
                              elements:
                              type: "view",
                              char_height: 10,
                              elements:
                              item_id: "stat",
                              width: 152,
                              height: 23,
                              char_width: 15,
                              font: "dialog",
                              type: "radio",
                              item_id: "Choice1",
                              group_id: "Group1",
                              type: "radio",
                              item_id: "Choice2",
                              group_id: "Group1",
                              name: "Reviewed with changes noted",
                              type: "radio",
                              item_id: "Choice3",
                              group_id: "Group1",
                              name: "Revise and Resubmit",
                              type: "radio",
                              item_id: "Choice4",
                              group_id: "Group1",
                              type: "edit_text",
                              item_id: "Name",
                              height: 35,
                              char_width: 20,
                              char_height: 10,
                              type: "ok_cancel",
                              if(event.source.forReal && (event.source.stampName == "#stamp1"))
                              this.getField("By").value = ((!identity.name || identity.loginName != (event.source.source || this).Collab.user) ? (event.source.source || this).Collab.user : identity.name);
                              this.getField("Date").value = util.printd("h:MM tt,dd-mmm-yyyy", new Date());
                              this.getField("Comment").value = results["Name"];
                              this.getField("rado1").checkThisBox(0, DiaBox.bChk1);
                              console.println("Stamp Name: " + event.source.stampName);
                              • 12. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                Karl Heinz Kremer Adobe Community Professional
                                The item ID can only be four letters long. You are using for example "Choice4" - this will not work.
                                • 13. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                  armies19630736 Level 1
                                  I edited it and changed it to "Btn1" and so on. Still not transferring the selection from the dialog box onto the stamp
                                  var DiaBox =
                                  result:"cancel",
                                  bChk1:false,
                                  bChk2:false,
                                  bChk3:false,
                                  bChk4:false,
                                  stredt1:"",
                                  var dlgInit =
                                  "Btn1": this.bChk1,
                                  "Btn2": this.bChk2,
                                  "Btn3": this.bChk3,
                                  "Btn4": this.bChk4,
                                  this.bChk1 = results["Btn1"];
                                  this.bChk2 = results["Btn2"];
                                  this.bChk3 = results["Btn3"];
                                  this.bChk4 = results["Btn4"];
                                  description:
                                  elements:
                                  type: "view",
                                  elements:
                                  type: "view",
                                  char_height: 10,
                                  elements:
                                  item_id: "stat",
                                  width: 152,
                                  height: 23,
                                  char_width: 15,
                                  font: "dialog",
                                  type: "radio",
                                  item_id: "Btn1",
                                  group_id: "Group1",
                                  type: "radio",
                                  item_id: "Btn2",
                                  group_id: "Group1",
                                  type: "radio",
                                  item_id: "Btn3",
                                  group_id: "Group1",
                                  type: "radio",
                                  item_id: "Btn4",
                                  group_id: "Group1",
                                  type: "edit_text",
                                  item_id: "Name",
                                  height: 35,
                                  char_width: 20,
                                  char_height: 10,
                                  type: "ok_cancel",
                                  this.getField("Comment").value = this.byName;
                                  event.value = "Name " + cMsg;
                                  • 14. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                    Are you getting any error messages on the JavaScript console?
                                    • 15. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                      I have an error :
                                      TypeError: this.getField(...) is null
                                      115:App:Calculate
                                      • 16. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                        Check your line #115, you are trying to reference a field that does not
                                        exist.
                                        • 17. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                          Okay, I've fixed the error on line #115 but now I have these errors ( see below) . and line 125 is this this.getField("Btn1").checkThisBox(0, DiaBox.bChk1);
                                          Btn 1 thru Btn4 is the item_id of each of my radio button
                                          125:App:Calculate
                                          TypeError: event.source is null
                                          116:Field:Calculate
                                          125:App:Calculate
                                          116:Field:Calculate
                                          116:Field:Calculate
                                          • 18. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                            "stamp1" can't be the name of your stamp. You need to find out the internal AP name.
                                            Also, change this line:
                                            if (event.source.forReal && (event.source.stampName == "#stamp1")) {
                                            to:
                                            if (event.source && event.source.forReal && (event.source.stampName == "#stamp1")) {
                                            • 20. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                              It's a property of the stamp. To find it out apply your stamp to a page, select it with the mouse, and then run this code from the JS Console:
                                              This is the value you need to use as the stampName in your code.
                                              • 22. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                                the name of my stamp is #stamp1 because I named it that way.
                                                • 23. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                                  My problem or error is this statement this.getField("Btn1").checkThisBox(0,DiaBox.bChk1);
                                                  it's giving me an error of NULL and I don't understand why
                                                  • 25. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                                    sorry, I have another problem. How do I reset the check mark every time the stamp is applied. Right now once the first selection was checked every time I re-apply the stamp it is defaulted to the first selection that I had made (
                                                    • 26. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                                      That means there's no field with that name in your file.
                                                      • 27. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                                        After this line:
                                                        Add this:
                                                        this.resetForm();
                                                        • 29. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                                          It is only recognizing the first radio button no matter which button I select, it will only check the first radio button
                                                          • 30. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                                            meriçg75308842
                                                            Can you try that
                                                            var DiaBox =
                                                            result:"cancel",
                                                            bChk1:false,
                                                            bChk2:false,
                                                            bChk3:false,
                                                            bChk4:false,
                                                            stredt1:"",
                                                            var dlgInit =
                                                            "Btn1": this.bChk1,
                                                            "Btn2": this.bChk2,
                                                            "Btn3": this.bChk3,
                                                            "Btn4": this.bChk4,
                                                            description:
                                                            elements:
                                                            type: "view",
                                                            elements:
                                                            type: "view",
                                                            char_height: 10,
                                                            elements:
                                                            item_id: "stat",
                                                            width: 152,
                                                            height: 23,
                                                            char_width: 15,
                                                            font: "dialog",
                                                            type: "radio",
                                                            item_id: "Btn1",
                                                            group_id: "Group1",
                                                            type: "radio",
                                                            item_id: "Btn2",
                                                            group_id: "Group1",
                                                            type: "radio",
                                                            item_id: "Btn3",
                                                            group_id: "Group1",
                                                            type: "radio",
                                                            item_id: "Btn4",
                                                            group_id: "Group1",
                                                            type: kas geliştirme "edit_text",
                                                            item_id: "Name",
                                                            height: 35,
                                                            char_width: 20,
                                                            char_height: 10,
                                                            type: "ok_cancel",
                                                            • 31. Re: Dynamic Stamp with multiple input from option buttons to be filled into the checkbox!
                                                              FINALLY!!! Here is the final code that works for me.
                                                              var DiaBox =
        result:"cancel",
        bChk1:false,
        bChk2:false,
        bChk3:false,
        bChk4:false,
        stredt1:"",
        var dlgInit =
        "Btn1": this.bChk1,
        "Btn2": this.bChk2,
        "Btn3": this.bChk3,
        "Btn4": this.bChk4,
        this.stredt1 = results["Name"];
        description:
        elements:
        type: "view",
        elements:
        type: "view",
        char_height: 10,
        elements:
        item_id: "stat",
        name: "SELECT THE REVIEW CATEGORY:",
        width: 152,
        height: 23,
        char_width: 15,
        font: "dialog",
        type: "radio",
        item_id: "Btn1",
        group_id: "Group1",
        type: "radio",
        item_id: "Btn2",
        group_id: "Group1",
        type: "radio",
        item_id: "Btn3",
        group_id: "Group1",
        type: "radio",
        item_id: "Btn4",
        group_id: "Group1",
        item_id: "stat2",
        name: "ENTER REJECTION COMMENTS:",
        width: 152,
        height: 23,
        char_width: 15,
        font: "dialog",
        type: "edit_text",
        item_id: "Name",
        height: 35,
        char_width: 20,
        char_height: 10,
        type: "ok_cancel",
                                                              this.resetForm();
        this.getField("Comment").value = DiaBox.stredt1;
        this.getField("Group1","Btn1").checkThisBox(0,DiaBox.bChk1);
        this.getField("Group2","Btn2").checkThisBox(0,DiaBox.bChk2);
        this.getField("Group3","Btn3").checkThisBox(0,DiaBox.bChk3);
        this.getField("Group4","Btn4").checkThisBox(0,DiaBox.bChk4);
        var cMsg = this.stredt1;
        event.value = cMsg;
