4 Replies Latest reply on Jul 6, 2016 4:16 PM by oleh.melnyk
    Check hyperlink status
    selvam214 Level 1
      Hi All,
      How to check the hyperlink status in CC2015 (red/green as per below highlighted).
      Selva
        • 1. Re: Check hyperlink status
          Loic.Aigon Adobe Community Professional
          Have you even tried looking at something ?
          InDesign ExtendScript API (10.0)
          • 2. Re: Check hyperlink status
            selvam214 Level 1
            Hi Loic,
            I have tried to read the properties, but can't find the status method. Guide to me
            hyerlinkstatus();
            function hyerlinkstatus(){
                var d = app.documents[0];
                var allHyperlinks = d.hyperlinks;
                var myArr = new Array();
                for(var n=0;n<allHyperlinks.length;n++){
                    myArr[n] = new Array();
                    for(var x in allHyperlinks[n].properties){
                    myArr[n].push(allHyperlinks[n].properties[x]+"\r");
                alert(myArr);
            selva
            • 3. Re: Check hyperlink status
              Indeed, no properties or methods seem to actually return the hyperlink destination status as the panel does.
              I hope I am wrong but if confirmed, then the solution might be to call command line and ping every single urls and analyze the result.
              See doScript for that.
              • 4. Re: Check hyperlink status
                oleh.melnyk Level 3
                Well, in theory, you can send HEAD request through Socket connection, and check if response status code is 200 Ok
                for example using this code
                var site = "forums.adobe.com";
                conn = new Socket;
                if (conn.open (site+":80","UTF-8")) {
                    var request = "HEAD / \n\n";
                    conn.write (request);
                    var reply = conn.read(50);
                    conn.close();
                    //alert(reply);
                    var firstLine = reply.split("\n")[0];
                    var statusCode = firstLine.split(" ")[1];
                    var statusMsg = firstLine.split(/^.+\d{3}/)[1];
                    if(statusCode != 200) alert(site + " is not reachable:\n" + statusMsg);
                The problem is that socket didn't work with https (or at least I don't know how) and many sites now use it...
