3 Replies Latest reply on Mar 19, 2009 8:30 PM by Newsgroup_User
    Categories/Subcategories Tree Component
    released87 Level 1
      I am creating a tree component from a products category/subcategory properties.
      I am using an XML product list structured as follows:
      <products>
      <product>
      <category>Category 1</category>
      <subcategory>Sub 1</sub>
      <name>Name</name>
      <number>325</number>
      </product>
      <products>
      The product node will be repeating. What I intend to do is load the xml, creating an array/xml collection with the categories. Then I need to remove duplicates, because lots of products will share the same category.
      Total:
      <category>Category 2</category>
      <category>Category 3</category>
      Duplicates Removed:
      After that I need to loop through the products again, using each category outputted from the previous list, and merge into a new xml file.
      for(subcategory in categoryArray){
      categoryList.(category== category1).addElement(subcategory);
      Basically I need the output to be something like this:
      <category name="Category 1">
      <sub>Sub1</sub>
      <sub>Sub2</sub>
      </category>
      <category name="Category 2">
      <sub>Sub 1</sub>
      <sub>Sub 3</sub>
      </category>
      That way I can use the outputted XML in a tree control to select categories and then subcategories if needed.
      I know this is an advanced process, so if you could just point in the right direction or some examples that would be greatly appreciated.
      Jesse
        • 1. Re: Categories/Subcategories Tree Component
          Level 7
          "released87" <webforumsuser@macromedia.com> wrote in message
          news:gpov9k$rdp$1@forums.macromedia.com...
          > Hi,
          > properties.
          > <products>
          > <product>
          > <name>Name</name>
          > </product>
          > <products>
          > remove
          > Total:
          > Duplicates Removed:
          http://joshblog.net/2007/05/17/filter-xml-data-with-e4x-in-flash-part-2/
          You'll need to copy the nodes rather than just put a reference to them in
          there.
          HTH;
          Amy
          • 2. Re: Categories/Subcategories Tree Component
            released87 Level 1
            how can i append multiple children to a node?
            var outputXML:XML= new XML(<output></output>);
            //Categories
            categoryList= productsXML.data.row.category;
            var testList:XMLList= productsXML.data.row.subcategory;
            var testString:XML= <test></test>;
            testString.test.appendChild(testList.toXMLString());
            for(var i:int =1; i<categoryList.length(); i++){
            var temp:String= productsXML.data.row.(id== i).category;
            outputXML.appendChild(<category label={temp}>{testString}</category>);
            var hash:Object = {};
            var uniqueList:XMLList = outputXML.*.(hash[toXMLString()] == undefined ? hash[toXMLString()] = valueOf() : false);
            this is a testing script, but I keep getting the same error because I cannot use appendChild() to add multiple nodes.
            TypeError: Error #1086: The appendChild method only works on lists containing one item.
            • 3. Re: Categories/Subcategories Tree Component
              Level 7
              news:gptm9n$po0$1@forums.macromedia.com...
              > //Categories
              ^loop through these nodes and make copies of them.
