8 Replies Latest reply on Mar 18, 2009 12:54 PM by EDUYork
    CFCONTENT from within any AJAX layout
    EDUYork
      CFCONTENT does not work as documented when I call it from within my AJAX app. Workarounds that call the code from another directory are way too kludgey for the client, but proved my standard code works outside of AJAX layout areas.
      This problem was first mentioned here in January '07 but never answered. Has anyone found a workaround?
        • 1. Re: CFCONTENT
          Level 7
          hmm... a code sample will probably be good....
          Azadi Saryev
          Sabai-dee.com
          http://www.sabai-dee.com/
          • 2. Re: CFCONTENT
            Level 7
            And possibly a description of what the problem actually is!
            Adam
            • 3. CFCONTENT from within any AJAX layout
              EDUYork Level 1
              Thanks and apologies... I should have just said "CFCONTENT does not work when called from within any AJAX container," for example CFDIV, CFWINDOW, CFLAYOUTAREA.
              According to this 2007 post by tSpark it applies to CFDOCUMENT as well: See CF8 - Ajax Form Post and Document Type
              The code I'm now testing with is in a file named cfContentDisplay.cfm which is copied from the CFCONTENT example in the CF8 documentation, but I'm using my own query against my own datasource, and cfContent is itself a cfinclude on a template named fileDisplay.cfm. To launch it I have tried several variations on the theme: ColdFusion.navigate('file_display.cfm?nowrap=true&ext=xls&q=incList','docDisplayWindow',m yCallBack,myErrorHandler,'post','sendIncompletesForm'); (I love this function because it's so easy to pass and retrieve a mixture of form and url variables.) The result is exactly as tSpark described... I see the HTML table in a standard browser window, it does not launch and display in Excel. The same code works as expected (and as I've used it repeatedly for at least 4 or 5 years) if it is in a non-AJAX page. That helps sometimes, but the current project is to be hosted on a server on which the app will have no access to anything outside its own directory, so I'm in need of a real fix.
              I hope that's clear.
              • 4. Re: CFCONTENT
                Level 7
                Before we go looking at if this is a ColdFusion <cfcontent...> bug.
                Does this work with any technology that tries to deliver alternate
                content from an AJAX request?
                I'm wondering if it is the browser that is ignoring the content data as
                it is not expecting anything but text/html or similar to be used inside
                the text/html document it is already processing.
                I.E. Since this is not a full, normal request for content, the browser's
                content detection functionality is not firing to handler different types
                of content. Or maybe that is a silly thought, I do very little AJAX.
                If one can do this type of thing with AJAX calls to other application
                server languages, then maybe it is a ColdFusion bug or the others are
                offering a non-standard implementation of the standard. I would not
                know which.
                • 5. Re: CFCONTENT from within any AJAX layout
                  EDUYork Level 1
                  Thanks again for the speedy reply. I don't know the answer to that, but it also occurred to me that ColdFusion scripts are parsed multiple times before rendering, and to make regular HTML <script> containers work one wraps them in CFOUTPUT to delay the rendering and retain their variables. Maybe WDDX or some way to delay the output is required.
                  Cheers!
                  • 6. Re: CFCONTENT
                    Level 7
                    > CFLAYOUTAREA.
                    Right. Well I think you might be misunderstanding how all this works.
                    Firstly, here's a very small replicable case:
                    <!--- mimeTypeTestMain.cfm --->
                    <cfwindow initshow="true" source="./mimeTypeTestInner.cfm" />
                    <!--- mimeTypeTestInner.cfm --->
                    <cfcontent type="application/msexcel" reset="true">
                    <cfheader name="Content-Disposition"
                    value="filename=mimeTypeTestInner.xls">
                    <table border="1">
                    <tr><td>Foo</td></tr>
                    <tr><td>Bar</td></tr>
                    </table>
                    As you say, this just displays an HTML table in the window.
                    Now, first things first, the <cfcontent> tag is indeed doing its job
                    exactly as intended. If you watch the underlying HTTP requests/responses
                    taking place, you'll see the MIME type of mimeTypeTestInner.cfm is indeed
                    being set to application/excel, and the content-disposition is being set to
                    the correct file name.
                    However that sort of thing is only ever interpretted by the browser as
                    starts receiving a new response from a request it itself has made (you
                    know, typing in a URL in the address bar, or clicking on a link or
                    sumbitting a form on the referring page, etc.
                    A <cfwindow> is *not* a "window" in the sense of a browser window (or a
                    browser frame or iframe), it's just a <div> with some styling applied to it
                    to make it look "window-y". Part of the <cfwindow> tags functionality is
                    that behind the scenes, a Javascript XML object is making a request back to
                    the server to get the content for the window as specified in the "source"
                    attribute. Having received some data back, some client side JS (which
                    <cfwindow> has previously sent down to the browser) grabs it and pops it
                    into the innerHtml of the <div>. It doesn't pay any attention to your
                    headers. It doesn't actually make any sense it pay any attention to header
                    information like that, because the content of the request is being
                    integrated into an existing doc, which already has a name and a MIME type.
                    Make sense?
                    I've singled out <cfwindow> here because I happen to be getting myself up
                    to speed with CF8 at present, and <cfwindow> was one of those tags I have
                    never used in production code: so it's kind of "on my radar" at present.
                    The other AJAX-esque tags will work the same way, for the same reasons
                    though.
                    Adam
                    • 7. Re: CFCONTENT from within any AJAX layout
                      EDUYork Level 1
                      >>> Make sense?
                      Totally. Or at least I'll find out if it did in a few minutes when I try the idea you just gave me. :)
                      I'll let you know, thanks.
                      • 8. Re: CFCONTENT from within any AJAX layout
                        EDUYork Level 1
                        Thanks everyone, I made it work. Special thanks to Adam for the final hint.
                        I'm sure there are more elegant ways but here it is so far...
