10 Replies Latest reply on Apr 28, 2006 12:24 PM by Newsgroup_User
    How to deploy coldfusion as mvc framework from server standpoint?.
    CFDEBUG
      Does anyone know how to deploy mvc framework from server standpoint?. I have all my business logic as cfcs but I want to move them to different server so that my cfm code is in one server and my cfcs are in another. Has anyone done this or point me in the right direction?.
        • 1. Re: How to deploy mvc from server standpoint?.
          Level 7
          My first question would be why you don't want to have your .cfm pages
          and your CFCs on the same physical server? I would think you'd have to
          have a very compelling reason to do this in order to add the additional
          complexity as well as the performance hit you'll take by instantiating
          remote objects (if it's even doable, which I'd have to think about).
          Matt
          Matt Woodward
          mpwoodward@gmail.com
          Adobe Community Expert - ColdFusion
          • 2. Re: How to deploy mvc from server standpoint?.
            CFDEBUG Level 1
            Thanx Matt for replying. Unfortunately it was not my decision. My company wanted to do it like that for security reasons. They wanted to make coldfusion apps like Java 3-tier with jsps in one server and servlets/ejbs in another, if possible. I thought that it would be like making it unncessarily complex. But didn't have facts to prove it.
            Can you give me some reasons why I should stick to keeping them in one server?. and why I shouldn't move them into different servers. May be I can convince them if there are some solid reasons. By the way, I'm using model-glue.
            • 3. Re: How to deploy mvc from server standpoint?.
              Level 7
              can you just use coldfusion mappings?
              like, if cfcs are on \\myoneserver\mycfcroot and you map /mycfcroot to that
              directory, can your cfm pages on server 2 use
              createobject("component","mycfcroot.mycfc");
              never tried it, but seems like it should work.
              "CFDEBUG" <webforumsuser@macromedia.com> wrote in message
              news:e2o2o7$nrp$1@forums.macromedia.com...
              > coldfusion
              > another, if
              > But
              > can
              > model-glue.
              • 4. Re: How to deploy mvc from server standpoint?.
                Level 7
                i had a minute and gave this mapping idea a shot. i had a cfc on our nas
                drive, mapped it in administrator like so:
                /frameworkroot = \\ournasdrive\com\company\framework
                then in a cf page running on a differnet machine, did
                createObject("component","frameworkroot.mycfc")
                and it worked fine
                "Marc E" <cf@hifiwebdesign.com> wrote in message
                news:e2ovnp$1tg$1@forums.macromedia.com...
                > that directory, can your cfm pages on server 2 use
                >> coldfusion
                >> another, if
                >> But
                >> can
                >> model-glue.
                • 5. Re: How to deploy mvc from server standpoint?.
                  Level 7
                  I'd be curious to hear the reasoning behind the argument that putting
                  your CFCs on another server necessarily gives you increased security.
                  More moving parts = more complex. I guess I'd just have to hear a
                  compelling argument for doing this other than a blanket "because it's
                  more secure" statement. The main reason this sort of setup is used in
                  the Java world is for distributed computing purposes, not for security.
                  I'm not saying there is absolutely no security benefit for doing
                  this--conceptually one could argue this is similar to putting your
                  database server behind a firewall so it can't be hit by the outside
                  world--but that reason alone doesn't make the argument complete in my mind.
                  Biggest one I can think of would be performance, not to mention
                  deployment complexities, increased hardware requirements (if your CFCs
                  are on a server other than the ones your CFML pages are on, you better
                  be darn sure you have redundancy there!), and increased licensing costs
                  for CF (different physical server = another CF license). I'd be very
                  surprised if you didn't take a big performance hit calling the objects
                  from another server, but I'd have to experiment with timing the mapping
                  process Marc E outlines. I guess to me you're asking why you shouldn't
                  move them onto different servers, when the real question in my mind is
                  why you *should*. Security alone doesn't sell it for me, but there may
                  be other reasons in your particular environment why this makes sense.
                  Matt
                  Matt Woodward
                  • 6. Re: How to deploy mvc from server standpoint?.
                    CFDEBUG Level 1
                    Matt, I think I'm going to go convince my people not to proceed in that direction. I have everything written using model-glue framework and I don't want to complicate stuff just to adhere to the policy that may not apply to all languages since not all languages follow the same architecture.
                    Thanx Marc. At the worst case, if I have to go with that architecture, I will look into your idea. Looks pretty simple.
                    Thanx guys for your suggestions. They are helpful.
                    • 7. Re: How to deploy mvc from server standpoint?.
                      Level 7
                      we've actually been trying to go in the opposite direction, mostly for ease
                      of deployments. we have a cluster of CF servers, and every time we do a code
                      push, we have to migrate to all servers. it's annoying and prone to
                      problems.
                      We want to move all our code onto one machine, such that no webserver has
                      any code on it at all. we deploy code to one machine, and all webservers on
                      the cluster benefit from the push. this machine is not web accessible at all
                      and thus one could say less prone to security problems than a webserver is,
                      although i'm not sure that's such a good reason. mostly for us it's ease of
                      deployment.
                      separating normal cfm files from objects seems kind of silly, when if you
                      want security you'd put all code on a separate, non-web-accessible machine.
                      thanks to CF mapping, you can just point "/" to the code root of hte machine
                      on which the code lives, and all is well with the world.
                      This is actually how we have our internal environment set up, it's just our
                      production environment where our host is a pain in the *** about it.
                      i'd be extremely surprised to see a performance problem with this setup.
                      It's not like the web servers are in philly and the code servers are in
                      taiwan, sending thousands of bytes per second. you've probably literally got
                      the webserver sitting right beside the server on which the code lives. it's
                      virtually the same thing as just keeping CF on the C drive and all the code
                      on the D Drive (assuming disk speeds on the machines are adequate).
                      news:e2qi60$1s5$1@forums.macromedia.com...
                      > don't
                      > to all
                      > will
                      • 8. Re: How to deploy mvc from server standpoint?.
                        Level 7
                        > problems.
                        Actually that's exactly the way we have our new high availability
                        environment configured. All the code runs off an EMC device. Not sure
                        why I didn't draw this parallel yesterday with running the CFML on one
                        server and the CFCs on another server--as long as you have a
                        sufficiently fast network (we're on gigabit) and device/drives (our
                        stuff is fiber channel), then as you mention below performance probably
                        isn't an issue. I'd be curious if doing this over 100 megabit with more
                        low-end hardware would perform as well as having things on a local
                        drive, however.
                        > deployment.
                        Yep, very true, and although the NAS/DAS device isn't *directly*
                        accessible via the web, remember that's it's accessible by the user
                        that's being used by the web site users, so there isn't a huge security
                        benefit here vs. having the code locally. You're absolutely right
                        Yeah, this is where we head was earlier in the discussion--putting the
                        CF "pages" on one server and the CFCs on another just seemed a bit wacky
                        to me.
                        Right, this is what we do on our production environment but we don't
                        even use a CF mapping (though you could). We just point our web server
                        to the EMC device and everything else just falls into place, provided
                        you've set up the user CF and your web server process (or using "connect
                        as" in IIS in W2K3) are running as so they have access to the network
                        storage device.
                        True, good point. We have extremely good performance (might even be
                        *faster* than local drive speed) with our EMC device, and again I'm not
                        sure why I didn't see this parallel yesterday in the discussions. Blame
                        it on a very hectic week. ;-)
                        Matt
                        Matt Woodward
                        • 9. Re: How to deploy mvc from server standpoint?.
                          CFDEBUG Level 1
                          Marc, That was a great idea. So basically if I have a server within vendor dmz and another server within trusted network, I can put the "/" mapping in my vendor dmz server and let it point to all the code in trusted network server and the trusted network server will not have any webserver at all?. So if the user accesses the site, it goes to the vendor dmz server and then it gets the page from trusted network server due to mapping?.
                          • 10. Re: How to deploy mvc from server standpoint?.
                            Level 7
                            I think so. also, since the cf files are just byte code when CF actually
                            gets them, the "code" itself isn't being read from disk except for the first
                            time it's loaded into the JVM. so in terms of disk reads, it's minimal
                            except on startup. that is, if my understanding of jvm is correct.
                            i asked about this on java.programmer, and someone on there said the same
                            thing you did matt: that reading from the external drive could conceivably
                            be faster if the drive on that machine is faster, as is apparently typical
                            with storage type devices. i'm no expert here, though. of course, all fo
                            this is probably splitting hairs anyway.
                            news:e2t76e$j1g$1@forums.macromedia.com...
                            > dmz
                            > server
                            > the
                            > the
