• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Can't open existing topics after opening project
New Here ,
Mar 20, 2009 Mar 20, 2009
Hi, I am using RH7 with Win XP.
When I open up my project and double click on an existing topic to edit it, RH7 stalls/crashes. If I create a new topic, then open an existing topic, everything works fine.
I thought the solution was the default editor setting I found in the following topic but it turns out that it did not permanently fix the problem.
http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=65&catid=447&threadid=1402188&C...
Any ideas?
Views
1.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Mar 21, 2009 Mar 21, 2009
Instead of double clicking a topic, right click and try Edit With > RoboHelp WYSIWYG.
If that doesn't work, I think I would go straight for an uninstall and reinstall, assuming this is the same with all projects.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 21, 2009 Oct 21, 2009
I am having this problem again.  I have tried everything I can think of to resolve the problem.  The only thing that is working right now that will allow me to open any of my topics is to create a new topic.  This somehow allows the WYSIWYG editor to start working again and allows me to open my existing topics.
Votes
Translate
Translate
Report
Report
Community Expert ,
Did you uninstall and reinstall?
Are your projects on your hard disk?
Same problem with the supplied sample projects?
Votes
Translate
Translate
Report
Report
New Here ,
I have not reinstalled yet.  I am trying to avoid it like the plague since I would have to get my IT dept involved.
My projects are on my local hard drive.
The sample projects seem to work OK.
I have played around with the project a little more and I am finding that if I open certain topics for editing first then everything works fine.  It seems like trying to open up some topics right after opening the project will cause a crash.  In other words my problem seems to be topic dependent.
I looked at the HTML behind topics that work fine and ones that cause a crash and at first I thought the common link between the ones that were causing the crash were that they had some meta tags that started out like:
<meta name=MS-HAID content=
but I found one exception so now I have no idea.
Any ideas?
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 22, 2009 Oct 22, 2009
Go to http://www.helpware.net/FAR/far_faq.htm and search in that page on MS-HAID.
The tag is index related. Does thinking "index" prompt any thoughts on the cause of the problem?
In a copy of the project, try trashing the index and all references to that tag.
Before that, try renaming the CPD file via Windows Explorer and then re-open the project.
If the supplied projects work, I doubt a reinstall will make any difference.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks for all of the ideas Peter.  Unfortunately, I have other things I have to move on to.  I will keep a note to try the index thrashing sometime when I have more time.
As for the cpd file, that is one of the first things I tried but it did not help.
For now, I will just have to use the workaround of editing a topic i know does not have problems right after opening the project.
Thanks again.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Well, it seems that my workaround is not working so well on another project that I am editing today.  I just remembered my other workaround which is to create a new topic before trying to open any existing topics (I probably got the idea from you or someone else in the forum).
Votes
Translate
Translate
Report
Report
New Here ,
Mar 23, 2009 Mar 23, 2009
Thanks Peter
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
