Currently we have a 400 license server that currently will not start Adobe Connect Service (adobe connect 9.5, on Windows Server 2008 R2) and the Adobe Connect Telephony Service. Each service I start, but after a short time, it stops the service abruptly.
I checked the debug logs, which come back with http-80-2 (ERROR) Error validating csrf token. com.macromedia.airspeed.StatusException$InternalError.
I additionally checked, the access log, whcih I get Internal error '[Macromedia][SQLServer JDBC Driver] SSL handshake failed: sun.security.validator.validatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: timestamp check failed' occurred."
Any advice to possible bring this back online?
What's the url of your installation? it's available on Internet?
If you use SSL i think the issue could be related to a due certificate.
Bye
The server is sitting in a closed environment, so I cannot put the URL out there.
Just thinking, do you believe that Encrypting the SQL database might lead to some issues?
I'm not sute, i've never did it, but the log seems to indcate that a certificate used is not valid.
Bye
Seems like it, however I am unsure. I am leaning towards the Database. I have Adobe Connect Support, so maybe they should be able to lend a hand?
I'd make a try with the support, maybe it's a DB related issue but i think anyway they can help you in gathering more information.
Hi, aveggiani47deck did you had a chance to solve the problem? I'm facing the same problem on my on premise installations.
Your help will be appreciated.
Best,
Bora
