2 Replies Latest reply on Jul 8, 2016 4:22 AM by prtamil
    Script error
    prtamil Level 1
      I am trying to apply right indent for the paragraphs when they come with the XML tag P with attribute Type and its value icon. Here is my code.
      myFilePath="C:/Program Files/Adobe/Adobe InDesign CC 2015 (32-bit)/Scripts/XML Rules/glue code.jsx"
      app.scriptPreferences.userInteractionLevel=UserInteractionLevels.interactWithAll;
      var myFile = File(myFilePath);
      app.doScript(myFile);
      if (app.documents.length != 0){
          var myDocument = app.documents.item(0);
          var myRuleSet = new Array (new anchor);
          with(myDocument){
              var elements = xmlElements;
              __processRuleSet(elements.item(0), myRuleSet);
      else{
          alert("No open document");
      function anchor(){
          this.name = "image";
          this.xpath = "//p";
          this.apply = function(myElement, myRuleProcessor){
              with(myElement){
                  var myName=myElement.xmlAttributes.itemByName("type").value;
      //~             app.select(myElement);
                  alert(myName);
                  if (myName == "icon"){
                          app.select(texts);
                      app.selection[0].rightIndent=21;
                  app.selection = null;
              return true;
      alert("Done");
      While I run this script I am getting below error
      XML structure is below
        • 1. Re: Script error
          csm_phil Level 4
          Hi prtamil,
          Use the below JS code, I've modified.
          #include "/Program Files/Adobe/Adobe InDesign CC 2015/Scripts/XML Rules/glue code.jsx"
              with(myDocument){
          else{
          function anchor(){
              this.name = "anchor";
              this.xpath = "//p[@type='icon']";
                  with(myElement){
                      var myName=myElement.xmlContent;
                      myName.rightIndent=21;
                  return true;
          alert("Done");
          thx,
          csm_phil
          • 2. Re: Script error
            prtamil Level 1
            Thanks a lot csm_phil.
            It works fine, can you please help me to learn what  causes error in my coding?
