29 Replies Latest reply on Jul 8, 2016 1:59 PM by trshaner
    PSD files fail to import
    mbrunspire Level 1
      None of my PSD files will import into Lightroom anymore. This has been going on for several versions of Lightroom. Despite going through every discussion I can find on the subject, a layered PSD will not import. I've always had Maximize PSD and PSB File Compatibility checked in Photoshop. I've tried re-saving the files, unchecking the Don't Import Suspected Duplicates, not using keywords on import but nothing changes. The import appears to be starting but the Import files at their current location progress bar at the top left of the window displays but never shows any progress. It will remain there until I click the X, then after a few seconds goes away but another import attempt is impossible until quitting and restarting because the import button is greyed out.
        • 1. Re: PSD files fail to import
          johnrellis Most Valuable Participant
          Are these files larger than 65,000 pixels on a side, or do they have a total number of pixels (width x height) greater than 512M?  Those are the maximum sizes allowed by LR.
          If they are smaller than that, please upload a sample PSD to Dropbox (or similar) and post the sharing link here.  We can put the file under the microscope to see what might be going wrong, figure out a workaround, and submit a detailed bug report if necessary,
          • 2. Re: PSD files fail to import
            mbrunspire Level 1
            The file is not very large (3336 x 2218). However, of the three layers in the PSD the primary layer is a RAW image converted into a Smart Object. Once I rasterized the Smart Object and did a Save As, I was able to import into LR. I do not want to rasterize every smart object in order to make it work with LR. Is there some reason LR cannot handle any smart object layers?
            • 3. Re: PSD files fail to import
              ManiacJoe Adobe Community Professional
              LR does not do layers, in any file format.
              LR only uses the full-size preview JPG stored in the TIF or PSD file, thus the need for "maximize compatibility" to be turned on so that the preview JPG is created.
              • 4. Re: PSD files fail to import
                I just did a test with LR CC 2015.6  and PS CC 2015.1.2 and didn't observe your symptoms.  When I save a PSD with a raw smart-object layer and an additional adjustment layer, if I select Maximize Compatibility, LR imports it just fine.  If I do Save As and deselect Maximize Compatibility, LR handles that gracefully, showing "Preview unavailable for this file" on the thumbnail in the Import window and showing the error message "This file could not be read. Please ... with the Maximize Compatibility preference enabled."
                Please Help > System Info in LR and PS and report the exact versions you're running.
                • 5. Re: PSD files fail to import
                  mbrunspire Level 1
                  To say that LR doesn't do layers you must mean it cannot create or edit layers, because as I have many other layered Photoshop files in catalogs and as I said, the test file imported with layers once the smart object was rasterized.
                  • 6. Re: PSD files fail to import
                    mbrunspire Level 1
                    Photoshop:
                    Adobe Photoshop Version: 2015.5.0 20160603.r.88 2016/06/03:23:00:00 CL 1078833  x64
                    Operating System: Mac OS 10.11.5
                    System architecture: Intel CPU Family:6, Model:94, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
                    Physical processor count: 4
                    Processor speed: 3300 MHz
                    Built-in memory: 32768 MB
                    Free memory: 19589 MB
                    Memory available to Photoshop: 29907 MB
                    Memory used by Photoshop: 70 %
                    Alias Layers: ^0
                    Modifier Palette: Disabled.
                    Design Space: Enabled.
                    3D Multitone Printing: Disabled.
                    Highbeam: Enabled.
                    Image tile size: 1024K
                    Image cache levels: 4
                    Font Preview: Medium
                    TextComposer: Latin
                    Display: 1
                    Main Display
                    High DPI Monitor
                    Display Bounds: top=0, left=0, bottom=1440, right=2560
                    OpenGL Drawing: Enabled.
                    OpenGL Allow Old GPUs: Not Detected.
                    OpenGL Drawing Mode: Advanced
                    OpenGL Allow Normal Mode: True.
                    OpenGL Allow Advanced Mode: True.
                    AIFCoreInitialized=1
                    AIFOGLInitialized=1
                    OGLContextCreated=1
                    NumGLGPUs=1
                    NumCLGPUs=1
                    glgpu[0].GLVersion="2.1"
                    glgpu[0].IsIntegratedGLGPU=0
                    glgpu[0].GLMemoryMB=4096
                    glgpu[0].GLName="AMD Radeon R9 M395X OpenGL Engine"
                    glgpu[0].GLVendor="ATI Technologies Inc."
                    glgpu[0].GLVendorID=4098
                    glgpu[0].GLRectTextureSize=16384
                    glgpu[0].GLRenderer="AMD Radeon R9 M395X OpenGL Engine"
                    glgpu[0].GLRendererID=16915462
                    glgpu[0].HasGLNPOTSupport=1
                    glgpu[0].CanCompileProgramGLSL=1
                    glgpu[0].GLFrameBufferOK=1
                    glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                    glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                    glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                    glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                    glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                    glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                    clgpu[0].CLPlatformVersion="1.2 (Apr 26 2016 00:05:53)"
                    clgpu[0].CLDeviceVersion="1.2 "
                    clgpu[0].IsIntegratedCLGPU=0
                    clgpu[0].CLMemoryMB=4096
                    clgpu[0].CLName="AMD Radeon R9 M395X Compute Engine"
                    clgpu[0].CLVendor="AMD"
                    clgpu[0].CLVendorID=16915456
                    clgpu[0].CLDriverVersion="1.2 (Apr 26 2016 00:27:37)"
                    clgpu[0].CUDASupported=0
                    clgpu[0].CLBandwidth=1.20461e+11
                    clgpu[0].CLCompute=1206.54
                    License Type: Subscription
                    Serial number: 94070766347500373415
                    GUIDBucket:
                      bucket: 128
                      test: ReduceUXFriction
                    Application folder: /Applications/Adobe Photoshop CC 2015.5/
                    Photoshop scratch has async I/O enabled
                    Scratch volume(s):
                      Startup, 1.92T, 1.12T free
                    Required Plug-ins folder: /Applications/Adobe Photoshop CC 2015.5/Adobe Photoshop CC 2015.5.app/Contents/Required/Plug-Ins/
                    Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2015.5/Plug-ins/
                    Installed components:
                       AdbePM.framework   AdbePM   2.5.00.37723   1.573920
                       adobe_caps.framework   adobe_caps   10.0.0.5   1.584361
                       AdobeACE.framework   AdobeACE   2.20.02.36408   79.573668
                       AdobeAGM.framework   AdobeAGM   4.30.60.36408   79.573668
                       AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
                       AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
                       AdobeBIB.framework   AdobeBIB   1.2.03.36408   79.573668
                       AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.573668
                       AdobeCoolType.framework   AdobeCoolType   5.15.00.36408   79.573668
                       AdobeCrashReporter.framework   AdobeCrashReporter   7.3.2
                       AdobeExtendScript.framework   AdobeExtendScript   4.5.6.4   80.1060872
                       AdobeJP2K.framework   AdobeJP2K   1.2.2.36027   79.261706
                       AdobeLinguistic.framework      21429
                       AdobeMPS.framework   AdobeMPS   5.8.1.36043   79.571748
                       AdobeOwl.framework   AdobeOwl   5.2.11
                       AdobePDFL.framework   AdobePDFL   15.0.0.36274   79.182661
                       AdobePDFSettings.framework   AdobePDFSettings   1.4
                       AdobePIP.framework   AdobePIP   7.3.1.128.44549
                       AdobeScCore.framework   AdobeScCore   4.5.6.4   80.1060872
                       AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.36043   79.571757
                       AdobeSVGRE.framework   AdobeSVGRE   6.0   79.571757
                       AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                       AdobeXMP.framework   AdobeXMPCore   79.159284   79.159284
                       AdobeXMPFiles.framework   AdobeXMPFiles   79.159284   79.159284
                       AdobeXMPScript.framework   AdobeXMPScript   79.159284   79.159284
                       ahclient.framework   ahclient   2.0.0.1
                       AIDE.framework   AIDE   1.5.0.36070   79.571906
                       aif.framework   aif   6.0.00.1   1.
                       amtlib.framework   amtlib   10.0.0.3
                       boost_date_time.framework   boost_date_time   10.0.0.0
                       boost_filesystem.framework   boost_filesystem   10.0.0.0
                       boost_signals.framework   boost_signals   10.0.0.0
                       boost_system.framework   boost_system   10.0.0.0
                       boost_threads.framework   boost_threads   10.0.0.0
                       Cg.framework   NVIDIA Cg
                       CIT.framework
                       CITThreading.framework
                       dvaaudiodevice.framework   dvaaudiodevice   10.0.0.0
                       dvacore.framework   dvacore   10.0.0.0
                       dvamarshal.framework   dvamarshal   10.0.0.0
                       dvamediatypes.framework   dvamediatypes   10.0.0.0
                       dvametadata.framework   dvametadata   10.0.0.0
                       dvametadataapi.framework   dvametadataapi   10.0.0.0
                       dvametadataUI.framework   dvametadataUI   10.0.0.0
                       dvaplayer.framework   dvaplayer   10.0.0.0
                       dvatransport.framework   dvatransport   10.0.0.0
                       dvaui.framework   dvaui   10.0.0.0
                       dvaunittesting.framework   dvaunittesting   10.0.0.0
                       dynamiclink.framework   dynamiclink   10.0.0.0
                       ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
                       ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
                       ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
                       LogSession.framework   LogSession   7.3.1.128.44549
                       manta.framework   manta   2.0.00.1   1.
                       mediacoreif.framework   mediacoreif   10.0.0.0
                       PlugPlugExternalObject.framework      7.0.0.50
                       PlugPlugOwl.framework   PlugPlugOwl   7.0.0.50
                       UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
                       WRServices.framework   WRServices   12.0.0   12.0.0.1000
                    Required plug-ins:
                       3D Studio 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Accented Edges 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Adaptive Wide Angle 17.0.0, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                       Angled Strokes 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Average 17.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “Average.plugin”
                       Bas Relief 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       BMP 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Camera Raw 9.6 (625), Copyright © 2016 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                       Camera Raw Filter 9.6 (625), Copyright © 2016 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                       Chalk & Charcoal 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Chrome 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Cineon 17.0.0  ©2002-2016 Adobe Systems Incorporated - from the file “Cineon.plugin”
                       Clouds 17.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
                       Collada DAE 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Color Halftone 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Colored Pencil 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       CompuServe GIF 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Conté Crayon 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Craquelure 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Crop and Straighten Photos 17.0.0  Copyright © 2003-2016 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                       Crop and Straighten Photos Filter 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Crosshatch 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Crystallize 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Cutout 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Dark Strokes 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       De-Interlace 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Dicom 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “dicom.plugin”
                       Difference Clouds 17.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
                       Diffuse Glow 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Displace 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Dry Brush 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Eazel Acquire 17.0.0  Copyright © 2007-2016 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                       Entropy 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Export Color Lookup Tables 17.0.0  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                       Extrude 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       FastCore Routines 17.0.0  ©1990-2016 Adobe Systems Incorporated - from the file “FastCore.plugin”
                       Fibers 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Film Grain 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Filter Gallery 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Flash 3D 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Fresco 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Glass 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Glowing Edges 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Google Earth 4 KMZ 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Graphic Pen 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Halftone Pattern 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       HDRMergeUI 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                       HSB/HSL 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       IFF Format 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       IGES 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Ink Outlines 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       JPEG 2000 17.0.0  Copyright © 2001-2016 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                       Kurtosis 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Lens Blur 17.0.0, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                       Lens Correction 17.0.0, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                       Lens Flare 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Liquify 17.0.0, Copyright © 2001-2016 Adobe Systems Incorporated - from the file “Liquify.plugin”
                       Matlab Operation 17.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                       Maximum 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Mean 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Measurement Core 17.0.0  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                       Median 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Mezzotint 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Minimum 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       MMXCore Routines 17.0.0  ©1990-2016 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                       Mosaic Tiles 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Multiprocessor Support 17.0.0  Copyright © 1990-2016 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                       Neon Glow 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Note Paper 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       NTSC Colors 17.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                       Ocean Ripple 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       OpenEXR 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Paint Daubs 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Palette Knife 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Patchwork 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Paths to Illustrator 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       PCX 17.0.0  ©1989-2016 Adobe Systems Incorporated - from the file “PCX.plugin”
                       Photocopy 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Photoshop 3D Engine 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                       Photoshop Touch Copyright ©2013-2016 Adobe Systems Incorporated - from the file “PSDX.plugin”
                       Picture Package Filter 17.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                       Pinch 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Pixar 17.0.0  ©1989-2016 Adobe Systems Incorporated - from the file “Pixar.plugin”
                       Plaster 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Plastic Wrap 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       PLY 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       PNG 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Pointillize 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Polar Coordinates 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Portable Bit Map 17.0.0  ©1989-2016 Adobe Systems Incorporated - from the file “PBM.plugin”
                       Poster Edges 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       PRC 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Radial Blur 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Radiance 17.0.0  ©2003-2016 Adobe Systems Incorporated - from the file “Radiance.plugin”
                       Range 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Render Color Lookup Grid 17.0.0  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                       Reticulation 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Ripple 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Rough Pastels 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Save for Web 17.0.0, Copyright © 1999-2016 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                       ScriptingSupport 17.0.0, Copyright © 2016 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                       Shake Reduction 17.0.0, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                       Shear 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Skewness 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Smart Blur 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Smudge Stick 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Solarize 17.0.0  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “Solarize.plugin”
                       Spaces 17.0.0, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
                       Spatter 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Spherize 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Sponge 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Sprayed Strokes 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Stained Glass 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Stamp 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Standard Deviation 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       STL 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Sumi-e 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Summation 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Targa 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Texturizer 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Tiles 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Torn Edges 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Twirl 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       U3D 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Underpainting 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Vanishing Point 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                       Variance 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                       Virtual Reality Modeling Language | VRML 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Water Paper 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Watercolor 17.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                       Wave 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Wavefront|OBJ 17.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                       Wind 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                       Wireless Bitmap 17.0.0  ©1989-2016 Adobe Systems Incorporated - from the file “WBMP.plugin”
                       ZigZag 17.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                    Optional and third party plug-ins: NONE
                    Duplicate and Disabled plug-ins: NONE
                    Plug-ins that failed to load: NONE
                    Extensions:
                       Recent Files  1.2.0 - from the file “/Applications/Adobe Photoshop CC 2015.5/Adobe Photoshop CC 2015.5.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
                       com.adobe.inapp.purchase  2.4.83 - from the file “/Applications/Adobe Photoshop CC 2015.5/Adobe Photoshop CC 2015.5.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.ht ml”
                       Libraries  2.4.83 - from the file “/Applications/Adobe Photoshop CC 2015.5/Adobe Photoshop CC 2015.5.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
                       Start  1.2.0 - from the file “/Applications/Adobe Photoshop CC 2015.5/Adobe Photoshop CC 2015.5.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
                       PixelSquid  0.7.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.pixelsquid.heroplayer/index.html”
                       Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2015.5/Adobe Photoshop CC 2015.5.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
                       Export As  3.0.5 - from the file “/Applications/Adobe Photoshop CC 2015.5/Adobe Photoshop CC 2015.5.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html ”
                       Device Preview  1.2.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.preview20155/PSPanel/panel.html”
                       com.adobe.preview.loader  1.2.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.preview20155/PSLoader/loader.html”
                    Installed TWAIN devices: NONE
                    Lightroom:
                    Lightroom version: CC 2015.6 [ 1078672 ]
                    License: Creative Cloud
                    Operating system: Mac OS 10
                    Version: 10.11 [5]
                    Application architecture: x64
                    Logical processor count: 4
                    Processor speed: 3.3 GHz
                    Built-in memory: 32,768.0 MB
                    Real memory available to Lightroom: 32,768.0 MB
                    Real memory used by Lightroom: 457.2 MB (1.3%)
                    Virtual memory used by Lightroom: 833.9 MB
                    Memory cache size: 0.0 MB
                    Maximum thread count used by Camera Raw: 4
                    Camera Raw SIMD optimization: SSE2,AVX,AVX2
                    Displays: 1) 5120x2880
                    Graphics Processor Info:
                    Check OpenGL support: Passed
                    Vendor: ATI Technologies Inc.
                    Version: 4.1 ATI-1.42.11
                    Renderer: AMD Radeon R9 M395X OpenGL Engine
                    LanguageVersion: 4.10
                    Application folder: /Applications/Adobe Lightroom
                    Library Path: /Users/ProductioniMac/Dropbox (Spire Agency)/CREATIVE DROPBOX/Lightroom Catalogs/Spire Portfolio Photography/Spire Portfolio Photography.lrcat
                    Settings Folder: /Users/ProductioniMac/Library/Application Support/Adobe/Lightroom
                    Installed Plugins:
                    1) Aperture/iPhoto Importer Plug-in
                    2) Canon Tether Plugin
                    3) Facebook
                    4) Flickr
                    5) Leica Tether Plugin
                    6) Nikon Tether Plugin
                    Config.lua flags: None
                    AudioDeviceIOBlockSize: 512
                    AudioDeviceName: Built-in Output
                    AudioDeviceNumberOfChannels: 2
                    AudioDeviceSampleRate: 44100
                    Build: Uninitialized
                    CoreImage: true
                    GL_ACCUM_ALPHA_BITS: 0
                    GL_ACCUM_BLUE_BITS: 0
                    GL_ACCUM_GREEN_BITS: 0
                    GL_ACCUM_RED_BITS: 0
                    GL_ALPHA_BITS: 8
                    GL_BLUE_BITS: 8
                    GL_DEPTH_BITS: 24
                    GL_GREEN_BITS: 8
                    GL_MAX_3D_TEXTURE_SIZE: 16384
                    GL_MAX_TEXTURE_SIZE: 16384
                    GL_MAX_TEXTURE_UNITS: 8
                    GL_MAX_VIEWPORT_DIMS: 16384,16384
                    GL_RED_BITS: 8
                    GL_RENDERER: AMD Radeon R9 M395X OpenGL Engine
                    GL_SHADING_LANGUAGE_VERSION: 1.20
                    GL_STENCIL_BITS: 8
                    GL_VENDOR: ATI Technologies Inc.
                    GL_VERSION: 2.1 ATI-1.42.11
                    OGLEnabled: true
                    GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
                    • 7. Re: PSD files fail to import
                      trshaner Adobe Community Professional & MVP
                      As already suggested by the best way to determine what's causing this issue is to upload one of the PSD files to Dropbox or other file sharing site and let us have a look at it.
                      • 8. Re: PSD files fail to import
                        mbrunspire Level 1
                        A test import of one of the files (still containing the Smart Object layer) from my desktop was successful so I tried moving it back to the original location. That import failed. Wondering if it was a problem with the location (6 levels deep on my hard drive), I tried moving it one level up. That import failed as did every attempt from each higher level of folder. I am at a loss to figure out what the problem is.
                        If you want to test one of the files here is a Dropbox link: Dropbox - Spire_Portfolio_103.psd
                        • 9. Re: PSD files fail to import
                          Just Shoot Me Adobe Community Professional
                          The problem is the PSD's you are trying to import into LR are not save with the Max Compatibility option turned on.
                          Open one of them in PS. Go to the PS Preferences and make sure Max Compatibility is set to Always. Do a Save As for that file and either give it a new name or overwrite the original. Then try importing it into LR. If it imports OK then that is the problem, No Max Compatibility.
                          • 10. Re: PSD files fail to import
                            The PSD file imports with no issues into LR 2015.6 on my Windows 7 system.
                            Check the top-level folder and makes sure it has Read & Write permissions for your user account:
                            OS X Yosemite: Set permissions for items on your Mac
                            EDIT: You need to check permissions settings for both the Source folder and Destination folder you are using in the LR Import module
                            • 11. Re: PSD files fail to import
                              mbrunspire Level 1
                              That is not true. Max Compatibility has always been on. In fact, I've done several "Save As" attempts making sure the compatibility is on with each. As I stated, the exact file failed to import in one location and succeeded when imported from my desktop.
                              • 12. Re: PSD files fail to import
                                Hmm, that imports into my LR CC 2015.6 without problem.  ImageMagick confirms the file was indeed saved with Maximize Compatibility:
                                (Layer 0 is the compatibility layer.)
                                • 13. Re: PSD files fail to import
                                  Bob Somrak Level 6
                                  Do you have any "non-standard" characters in your path names.  That would explain why it will import from the desktop and not a subfolder.  It could also explain why the smart object file will not import but the raster file will if Lightroom reads those characters during import of the PSD.
                                  • 14. Re: PSD files fail to import
                                    That image imports just fine on lr 2015.5.1 running on a Win 7 system.
                                    So this must be a permissions problem.
                                    • 15. Re: PSD files fail to import
                                      mbrunspire Level 1
                                      Not sure how Read & Write permissions could be the problem since PSD files are the only format that will not import from the folder and I move/copy/save frequently. One point to note that may have no significance is; this is a Dropbox folder. We use Dropbox like a server and so, when I say the file is 6 levels deep, it is 6 levels deep in my Dropbox folder.
                                      @Bob Somrak the file naming is pretty simple "Spire_Portfolio_103.psd"
                                      • 16. Re: PSD files fail to import
                                        Bob Somrak Level 6
                                        I was talking about the PATH names also.
                                        • 17. Re: PSD files fail to import
                                          Is the Dropbox folder on the same hard drive as your Desktop or is it on an external hard drive?
                                          • 18. Re: PSD files fail to import
                                            mbrunspire Level 1
                                            There is nothing in the folder names except for the • placed before the name in the first level in the Dropbox folder. And I tested the import on each level and all failed until it was on the desktop.
                                            johnrellis Yes, the Dropbox folder is on the internal drive of a iMac (Retina 5K, 27-inch, Late 2015).
                                            • 19. Re: PSD files fail to import
                                              Bob Somrak Level 6
                                              A . (period) in front of a file on a Mac means it is a HIDDEN file/folder.  Could that be a problem?  I am not familiar using dropbox in the manner you are using it.
                                              • 20. Re: PSD files fail to import
                                                mbrunspire Level 1
                                                Sorry, I was not saying there was a . (period) it is a bullet (on the Mac; Option + 8 key)
                                                • 21. Re: PSD files fail to import
                                                  Bob Somrak Level 6
                                                  I see that now. I should have looked closer  I would think a "bullet" is a nonstandard filename/path character but if thats the way Dropbox operates than I am out of ideas.
                                                  • 22. Re: PSD files fail to import
                                                    On my configuration (CC 2015.6, OS X 10.11.5), LR doesn't have any problem importing the sample PSD from a folder starting with a bullet • .
                                                    But I wonder: Do the problem PSDs use embedded smart objects or linked smart objects (smart objects that refer to other files)?  The sample PSD had an embedded smart object. But if the problem PSDs use linked smart objects, perhaps LR or PS is choking on bullets in the links' paths containing a bullet.
                                                    • 23. Re: PSD files fail to import
                                                      mbrunspire Level 1
                                                      johnrellis Thanks for the thoughts, but unfortunately neither the bullet or the smart object appear to be the problem (in that way at least) since I've moved the file up levels above the bullet appended folder with the same fail and, the smart objects are all embedded.
                                                      • 24. Re: PSD files fail to import
                                                        I'm out of ideas here -- perhaps others might have better suggestions.  You could submit a bug report in the official Adobe feedback forum, where Adobe wants bug reports submitted: Photoshop Lightroom | Photoshop Family Customer Community . But Adobe isn't likely to pay much attention if we can't reproduce the problem reliably, unfortunately.
                                                        • 25. Re: PSD files fail to import
                                                          You can check these recommendations:
                                                          Why aren't certain files on one computer syncing to another? (Dropbox Help Center)
                                                          You can also post this issue on the Dropbox forums, which is monitored by their Tech Support team:
                                                          Dropbox Community
                                                          • 26. Re: PSD files fail to import
                                                            mbrunspire Level 1
                                                            Thanks trshaner but I'm not having any Dropbox sync problems, but my tests leave a small chance that Dropbox is part of the problem.
                                                            I just did some more testing, duplicating each level of folders, copying each folder name directly. Instead of the first level folder being named "Dropbox", it was "LR Test" and placed at the same level as the Dropbox folder. The import worked. Then, I moved that entire test into Dropbox. The import worked. Then I moved the test PSD back to its original location. The import failed.
                                                            I wonder if LR is having trouble with the file path or the fact that the embedded Smart Object is the DNG file (even though that DNG was not previously imported into this catalog). Take a look at the attached screen capture showing some of the Lightroom Folders in my catalog; What does the question mark mean?
                                                            Are the multiple occurrences of the "Spire Portfolio images" folder due to failed imports (this is the location of the PSD)?
                                                            Is there some way to force LR to re-index a folder?
                                                            This seems like it might be related to the problem. I would expect the "Originals" subfolder to reflect the many images inside and yet it shows 0.
                                                            • 27. Re: PSD files fail to import
                                                              What exactly do you mean by the above two sentences? Need specifics as to the physical location (local drive or Web) and full path details, such as:
                                                              External USB3 drive
                                                              E:\Pictures\Canon EOS 5D MkII\2009_11_14\IMG_0001.PSD
                                                              A DNG file copy is embedded in the PSD so no issues with it not being imported into LR.
                                                              It means the folder has been moved or renamed from outside of LR (i.e. with Finder).
                                                              Right-click on each of the 0 picture folders and select 'Show in Finder.' Are there any files in those folders. If so Right-click on each folder and select 'Synchronize Folder' and tell us what happens.
                                                              • 28. Re: PSD files fail to import
        mbrunspire Level 1
        SOLVED! Thanks to everyone for all the feedback. With all the help I was able to track down and fix the problem:
        I see now what the folders with question marks are. A mouseover shows me the file path. Some are from the test imports, some from past imports where files were later reorganized so, no problem there.
        When I viewed the path of the "Spire Portfolio images" folder (the only remaining folder in the list by that name after deleting those from test imports) it points to the source folder (the one I’ve been trying to import from—"Spire Portfolio images"). And, the "Originals" sub-folder maps as expected to the subfolder of the "Spire Portfolio images". Several hundred of the catalog's images reside in that "Originals" folder. But after looking through the rest of the “Folders” list in LR, I see another “Originals” folder and it does have several hundred images showing as I would expect and it too points to within the target folder.
        Once I right-clicked and chose the Synchronize Folder option on the "Spire Portfolio images" folder I was hesitant to select the “Import new photos” option because the image count displayed in the dialog seems to include all sub-folders (I do not want all the images). Selecting only “Scan for metadata updates” did nothing recognizable. So, I decided to delete the problem folder (and its sub-folder) displaying 0 images. A new import attempt was successful. It now correctly shows the target folder, its subfolders and the accurate image counts. An import of the rest of the images was fast and accurate. Fixed!
        • 29. Re: PSD files fail to import
        Glad you got it resolved. Now the question of the day is–What actually caused this issue?
