10 Replies Latest reply on Jul 7, 2016 5:45 PM by johnrellis
    lightroom [following recent updates, Dehaze and geometric corrections have disappeared]
    scamander
      I downloaded all the updates recently made available and now the dehaze has disappeared from lightroom also the geometric corrections, I have to use camera raw now for these. Is there some way to get these functions back?
        • 1. Re: lightroom
          dj_paige Level 10
          It sounds like you have some version of Lightroom 6, which does not include DeHaze, this is only available in the Creative Cloud versions of Lightroom.
          The lens corrections are now under the Transform tab.
          • 2. Re: lightroom
            scamander Level 1
            Thank you for your answer but I have the creative cloud version including all the other apps and I had the Dehaze and the other corrections I mentioned before this update, I don't even see a trensform tab now.
            • 3. Re: lightroom
              johnrellis Most Valuable Participant
              Please do Help > System Info and report the exact version of LR shown there.
              • 4. Re: lightroom
                Also, in Develop, do Window > Panels > Transform and Window > Panels > Effects to make sure those two panels are showing.
                • 5. Re: lightroom
                  scamander Level 1
                  There isn't any "windows panels transform" and the effects panel only contains grain and post crop vignetting facilities
                  • 6. Re: lightroom
                    • 7. Re: lightroom
                      scamander Level 1
                      I hope this reaches you
                      • 8. Re: lightroom
                        Did you try to post something more?  This is all that was posted.
                        • 9. Re: lightroom [following recent updates, Dehaze and geometric corrections have disappeared]
                          scamander Level 1
                          Lightroom version:  CC 2015 License: Creative CloudOperating system: Mac OS 10Version: 10.11 Application architecture: x64Logical processor count: 4Processor speed: 1.7 GHzBuilt-in memory: 8,192.0 MBReal memory available to Lightroom: 8,192.0 MBReal memory used by Lightroom: 1,105.2 MB (13.4%)Virtual memory used by Lightroom: 1,613.4 MBMemory cache size: 306.5 MBMaximum thread count used by Camera Raw: 2Camera Raw SIMD optimization: SSE2,AVX,AVX2Displays: 1) 1440x900
                          Graphics Processor Info: Intel HD Graphics 5000 OpenGL Engine
                          Check OpenGL support: PassedVendor: Intel Inc.Version: 4.1 INTEL-10.14.66Renderer: Intel HD Graphics 5000 OpenGL EngineLanguageVersion: 4.10
                          Application folder: /Applications/Adobe LightroomLibrary Path: /Users/angelaarenal/Pictures/Angela's Master Catalog/Angela's Master Catalog.lrcatSettings Folder: /Users/angelaarenal/Library/Application Support/Adobe/Lightroom
                          Installed Plugins: 1) Aperture/iPhoto Importer Plug-in2) Behance3) Canon Tether Plugin4) Facebook5) Flickr6) Helicon Focus Export7) Leica Tether Plugin8) Nikon Tether Plugin
                          Config.lua flags: None
                          AudioDeviceIOBlockSize: 512AudioDeviceName: Built-in OutputAudioDeviceNumberOfChannels: 2AudioDeviceSampleRate: 44100Build: UninitializedCoreImage: trueGL_ACCUM_ALPHA_BITS: 0GL_ACCUM_BLUE_BITS: 0GL_ACCUM_GREEN_BITS: 0GL_ACCUM_RED_BITS: 0GL_ALPHA_BITS: 8GL_BLUE_BITS: 8GL_DEPTH_BITS: 24GL_GREEN_BITS: 8GL_MAX_3D_TEXTURE_SIZE: 2048GL_MAX_TEXTURE_SIZE: 16384GL_MAX_TEXTURE_UNITS: 8GL_MAX_VIEWPORT_DIMS: 16384,16384GL_RED_BITS: 8GL_RENDERER: Intel HD Graphics 5000 OpenGL EngineGL_SHADING_LANGUAGE_VERSION: 1.20GL_STENCIL_BITS: 8GL_VENDOR: Intel Inc.GL_VERSION: 2.1 INTEL-10.14.66GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
                          • 10. Re: lightroom [following recent updates, Dehaze and geometric corrections have disappeared]
                            That first line:
                            indicates you are running the first version of CC 2015 (2105.0), which didn't have Dehaze or the new Transform.  You said you "downloaded all the updates recently" -- I'm not sure how you did that, but it didn't work.
                            If you do Help > Updates, the Creative Cloud desktop app should appear and look similar to below, except that updates to Lightroom should be listed:
                            If you don't see Lightroom updates listed, try signing out from the Creative Cloud by doing Help > Sign Out in LR, then sign in, then do Help > Updates again.
                            If that doesn't work, download the Lightroom CC 2015.6 update from here: Install Photoshop Lightroom. That will download "setup.dmg".  Double-click that file and then double-click "AdobePatchInstaller.app".
