3 Replies Latest reply on Jul 7, 2016 4:37 PM by poodyglitz
    Import A Single AE Composition
    poodyglitz Level 1
      I want to import a single composition from another After Effects files (along with its accompanying footage files). When I import, I brings in every element from the project being imported from. o intermediate dialogs came up when I selected the file. Is there a way to selectively import contents from another AE projects? I'd hate it if I had to import everything and delete what I don't need — my projects tend to have a huge number of elements.
      Please advise. Thanks so much.
        • 1. Re: Import A Single AE Composition
          Mohammad.Harb MVP & Adobe Community Professional
          after importing the aep project and use some elements in your comps.
          Go to File -> dependencies -> Remove all unused footage
          Go to File -> dependencies -> Reduce projects
          * make sure to backup your file before.
          lets know if that helps
          • 2. Re: Import A Single AE Composition
            Roei Tzoref Adobe Community Professional
            I don't know about a solution and wish someone could suggest somethings. sounds like there could be a script for this...
            in the meantime I can suggest 2 workarounds I use:
            1. import the project, drag what I want to where I want and then select the compositions I want keep and select Reduce Project, Consolidate and re-order things in my project window through a script or manually.
            2. open another instance of Ae and select just the composition I want to keep and reduce project, then save. then I import this to my main instance of after effects where I need those assets imported to.
            • 3. Re: Import A Single AE Composition
              poodyglitz Level 1
              Selecting the composition and reducing the project works.
              Thanks, guys!
