• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
MX8 CFHTTP Bug
Advocate ,
Mar 17, 2009 Mar 17, 2009
I believe I found a bug with the CFHTTP tag in CF8. I have a CFHTTP post call being made within a loop through a list of URL's (multiple servers). I exit out of the loop upon a successful CFHTTP.StatusCode indicator (200 or 202 status codes). This logic has been working this way for years in CF5, 7 & 8.
Just the other day we upgraded our SSL certificate on one of the CF5 servers this CF8 page is communicating to via this CFHTTP loop logic. The new SSL cert is not recognized by our JRE and the POST to this server results in the following error: HTTP ERROR: Connection Failure. Status code unavailable.
I already know why the SSL cert is unrecognized and I'll be correcting that BUT the loop logic found a side effect I believe to be a bug. In looping through to the next URL, the formfields in the POST are double posted. By "double post," I mean if I indended to post USERNAME=Joe123, the second action page in the url list receives USERNAME=Joe123,Joe123 -- this is for all the form fields.
I have not determined if this is always the case and have just not noticed or if this is specifically related to the SSL failure. Below is a snippet of my code. This snippet has been simplified for this example so there might be a typo, but hopefully it will convey the issue:
TOPICS
Advanced techniques
Views
574
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Mar 21, 2009 Mar 21, 2009
As you know, the double post is usually caused by a form that contains two or more fields that share the same name. Have you ruled out that possibility, for example, using the following test?
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 22, 2009 Mar 22, 2009
I used your code with 3 URLs and cfparams for the attributes, but failed to reproduce the problem. But then again there are differences that might be significant. I'm doing everything locally on my PC, using http, and the value of my useragent is Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0; .NET CLR 2.0.50727; .NET CLR 1.1.4322; InfoPath.1)
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
The only way I can reproduce the problem is post to a server using a SSL cert that CF (Java) does not recognize (maybe a self issued cert) and then immediately post to a server where the SSL cert is recognized.
Votes
Translate
Translate
Report
Report
Resources
Documentation
