8 Replies Latest reply on Nov 30, 2017 9:06 AM by haseebmukhtar
    c# sample echo sign
    rickyy26597406
      I already signed developer account.
      I need to get sample in c# how to upload a document(PDF) with 5 pages and send to the clients to sign.
      Inside of the pdf, all information already filled in and one thing I need to know below:
      Is it truth Echo Sign has special format name like textbox in pdf that used to allow receiver to sign?
        • 1. Re: c# sample echo sign
          haseebmukhtar00
          I am writing a C# wrapper for Adobe Sign Rest API, please have a look it might help you.
          https://github.com/haseebmukhtar/AdobeSign.Net
          • 2. Re: c# sample echo sign
            keviny75380389 Level 1
            Yes it is possible. Base on haseebmukhtar00's work, I was able to add a sign field on existing PDF file with following code.
                        //FormFields
                        documentCreationInfo.formFields = new List<FormField>();
                        var formFields = documentCreationInfo.formFields;
                        formFields.Add(new FormField
                                displayLabel = "Client Sign",
                                recipientIndex = 1,
                                contentType = "SIGNATURE",
                                maxLength = 50,
                                minLength = 1,
                                locations = new List<Location>
                                    new Location {
                                        height = 20,
                                        width = 230,
                                        pageNumber = "3",
                                        left = 65,
                                        top = 152 // from left bottom corner.
                                name = "Client1Sign1",
                                inputType = "SIGNATURE",
                                required = true,
                                defaultValue = "",
                                fontSize = "8.0",
                                readOnly = true,
                                borderWidth = "1.0",
                                tooltip = "Please sign "
            • 3. Re: c# sample echo sign
              shojik58550374
              haseebmukhtar00,
              Can you show me how to get access token with Adobe Sign Rest API? I am not able to get it,
              • 4. Re: c# sample echo sign
                jamesj1 Level 1
                Hi shojik58550374,
                If you can show us your code we can show you where you may have gone wrong.
                • 5. Re: c# sample echo sign
                  shojik58550374 Level 1
                  Actually I got access token portion working. However. I fails with page limit event though it has only one page. I guess they won't allow us to upload anything for Free Trial.
                       "code": "BAD_REQUEST",
                       "message": "Adobe Sign was unable to create your agreement because the document(s) exceeded your page limit."
                  • 6. Re: c# sample echo sign
                    thangarai vendhe66303680 Level 1
                    You have to generate Integrated API for you Application in Adobe Sign. And Use that Integrated Key to API Calls instead of Access-token.
                    To enable the integrated Key option, send a mail to adobe support.
                    • 7. Re: c# sample echo sign
                      haseebmukhtar
                      Hi
                      This error comes when you are not providing the contect type/mime type;
                      If you are uploading a PDF file and have not provided the content type / mime type then you will get this error.
                      Please add a mime type parameter in AddDocument method.
                      • 8. Re: c# sample echo sign
                        haseebmukhtar Level 1
                        Hi
                        You can use the field name {{Sig_es_:signer1:signature}} to use as a signature block.
                        Please see Adobe Sign Text Tag Guide
