4 Replies Latest reply on Jul 11, 2016 7:03 AM by Szalam
    Burt in image.
    joeb57726292 Level 1
      So I worked on a project a while back and now ocasinally a frame from it (always the same) is burnt on to other projects. It seems to be when theres noting there, for example when I first create a comp and theres is no solids or footage in it and more annoyingly if I pre-comp something and theres alpha in there somewhere.
      It reacts like all other layers it can go under or over other things when pre-comp, I can add effects to it but the footage isn't imported or even on my computer.
      Other note is that when I open projects on another system this doesn't happen, It also renders as any other layer would.
      oh and finally I've done the usual reinstall stuff.
      In this image you can see the playhead is over nothing, theres o hidden layers and this should be a blank layer.
      The videos are just examples of the renders
