17 Replies Latest reply on Jul 11, 2016 6:10 AM by capegirl1
    LRCC is slow
    capegirl1
      I have the top end Macbook Pro with the upgraded processor.  While using LR,  I keep getting the spinning ball and its becoming very frustrating.  It doesn't always respond.  I have already gone into the performance and unchecked use graphics card to see if it would make a difference.  It did not.  I have closed down LR and reopened it and no difference.  I am at a loss.  I had my computer checked out by Apple and they don't see any issues with it.  Anyone have any suggestions?
        • 1. Re: LRCC is slow
          ssprengel Adobe Community Professional & MVP
          What pixel dimensions are your screen?
          • 2. Re: LRCC is slow
            capegirl1 Level 1
            2880x1800  retina
            • 3. Re: LRCC is slow
              GPU computations were added to speed things up for hi-res displays.  A 3K such as you have may or may not be helped.  My 1.7K is fine without the GPU.
              Have you paused Face Detection?
              • 4. Re: LRCC is slow
                capegirl1 Level 1
                Face detection where? In LR or my laptop?
                • 5. Re: LRCC is slow
                  dj_paige Level 10
                  Can you state the exact CPU and GPU in your computer?
                  Exactly what tasks in Lightroom produce the spinning ball?
                  Are you performing a lot of brushing or spot healing on each photo?
                  • 6. Re: LRCC is slow
                    capegirl1 Level 1
                    Performing brushing, healing, gradient........happens regularly .
                    Memory 16GB 1600 Mhz DDR3
                    AMD Radeon R9 M370X 2048MB
                    2.8Ghz Intel Core i7
                    • 7. Re: LRCC is slow
                      capegirl1 Level 1
                      Shouldn't be happening, thats why I bought this high end mac.  I am beginning to hate LR.
                      • 8. Re: LRCC is slow
                        Click the || to pause Face Detection if it isn't already Paused.
                        • 9. Re: LRCC is slow
                          capegirl1 Level 1
                          Says, face detection paused.
                          • 10. Re: LRCC is slow
                            dj_paige Level 10
                            This is most likely the problem. If you do lots of brushing or spot healing on a single photo, Lightroom will slow down. This is a known issue with Lightroom.
                            The solutions are (in no particular order):
                            1. Turn off the Graphics acceleration in Lightroom
                            2. Do the brushing and spot healing as the next to last step in your editing; and the last step would be to turn on Lens Corrections
                            3. Do the brushing in Photoshop or Photoshop Elements
                            4. Get a faster GPU
                            • 11. Re: LRCC is slow
                              capegirl1 Level 1
                              I do not think this is a computer issue.  I have tried all the above I believe and nothing seems to work.  I am not good with PS unfortunately.  And since my mac is fairly new, I dont think I will be getting a faster GPU.  Plus its doesnt get any faster.
                              This is unacceptable.  I will be calling Adobe.
                              • 12. Re: LRCC is slow
                                dj_paige Level 10
                                First, I made a mistake, it should say "Get a faster CPU"
                                You can call Adobe if you want, but the fact is that this is a known problem, that lots of brushing and spot healing will cause Lightroom to slow down, and the only ways I know of that can improve the problem are the ones I stated. You're not going to find the magic cure, it doesn't exist.
                                • 13. Re: LRCC is slow
                                  capegirl1 Level 1
                                  Do you have the same problem then? Appreciate the help.
                                  • 14. Re: LRCC is slow
                                    dj_paige Level 10
                                    I had the problem in the past on an old and very slow computer. When a bought a brand new computer with a much faster CPU, the problem went away.
                                    • 15. Re: LRCC is slow
                                      capegirl1 Level 1
                                      Interesting........ok.  Maybe I will go back to the mac store.  What is your CPU/GPU if you dont mind me asking??
                                      • 16. Re: LRCC is slow
                                        dj_paige Level 10
                                        I have a i7-4770K @ 3.5GHz, and the GPU acceleration is turned off, but there's a lot more to it than that.
                                        You have a much larger screen than I do, this means that Lightroom will have to do more work to fill the screen (which of course means that things will be slower) and you may be doing a lot more brushing/spot healing than I did. All of these things factor into the speed that you are seeing.
                                        To be honest, I think (in other words, THIS IS MY OPINION) right now Adobe does not have a good solution for people who want to do a lot of brushing in Lightroom on computers that have the new larger screens like you do. Maybe if you bought the fastest CPU that exists today, it will work fine, I don't know, but there's no way to find out until you actually make the purchase. (As I stated above, Photoshop will not have the slightest problem with this brushing)
                                        • 17. Re: LRCC is slow
                                          capegirl1 Level 1
                                          Thanks so much for info.  Maybe I will switch to a different software for my editing.  Nik software is free......
