I've had no problems with ADE for several years (ver 2.0.1.78765). Now, suddenly, it won't allow me to return a book, giving the following message: "Error returning item! Please authorize your computer first." When I go to the help menu > Authorization, it says the computer is already authorized, and gives the authorization string.
If I try to put a newly downloaded book into ADE, I get a message which says "Error!, Check authorization", but it doesn't tell me how to do that.
I recently got a message from Microsoft saying I needed to change my logon to a local account, and then went through that procedure. Could this be the reason that ADE no longer works? If so, how do I get ADE operational again?
Kent Drummond
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept
...Copy link to clipboard
Windows:
Choose Start > Run.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
