0 Replies Latest reply on Jul 11, 2016 5:56 AM by Charles_Parrington
    Problems getting Indesign Server CS6 to run
    Charles_Parrington Level 1
      Hi there
      I have been battling to get InDesign Server CS6 to run on a new server. Please can you assist and tell me if I am looking in the correct place?
      I have installed Indesign Server CS from the installer files, I must add that this license was installed on a previous server that crashed.
      During installation I input the license key provided by Adobe for the version I am using. But I also used the adobe_prtk ... command prompt to activate the license; I received the following from the command prompt. (i have not shown the correct serial number for obvious reasons.
      C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\Enterprise\utilities\APTEE\
      CS6>adobe_prtk --tool=Serialize --leid=InDesignServer-CS6-Win-GM --serial=9999-1
      9999-9999-9999-9999-9999 --adobeid=charles@mydomain.co.za
              Copyright 2012 Adobe Systems Incorporated
              All rights reserved.
      Return Code = 0
      I get the Return Code = 0 which I understand means the product was activated correctly?
      But then I run the IndesignServer.exe from the command prompt and during the startup I am getting "Unknown Server License: .... see below, again just masked the actual license code used during the activation above.
      .  InDesign CS6 Server Version 8.0.3 x64
      .  Copyright 1999-2012 Adobe Systems Incorporated and its licensors.
      .  All rights reserved. See the other legal notices in the ReadMe.
      07/11/16 14:35:41 INFO  [server] Initializing
      07/11/16 14:35:41 INFO  [server] Loading the application
      07/11/16 14:35:41 INFO  [server] Scanning for plug-ins
      07/11/16 14:35:41 INFO  [server] Registering 123 plug-ins
      07/11/16 14:35:46 INFO  [server] Completing Object Model
      07/11/16 14:35:46 INFO  [server] Saving Object Model
      07/11/16 14:35:46 INFO  [server] Initializing plug-ins
      07/11/16 14:35:46 INFO  [server] Calling Early Initializers
      07/11/16 14:35:47 INFO  [server] Starting up Service Registry
      07/11/16 14:35:49 INFO  [server] Executing startup services
      07/11/16 14:35:49 ERROR [server] Unknown server license:99999999999999999999:
      07/11/16 14:35:50 INFO  [server] Using configuration configuration_noport
      07/11/16 14:35:51 INFO  [server] Initializing Application
      07/11/16 14:35:51 INFO  [server] Completing Initialization
      07/11/16 14:35:51 INFO  [server] Calling Late Initializers
      07/11/16 14:35:56 INFO  [server] Image previews are off
      07/11/16 14:35:56 INFO  [server] Server Running
      07/11/16 14:35:56 INFO  [javascript] Executing File: C:\Program Files\Adobe\Adob
      e InDesign CS6 Server x64\Scripts\startup scripts\ConnectInstancesToESTK.js
      e InDesign CS6 Server x64\Scripts\converturltohyperlink\startup scripts\ConvertU
      e InDesign CS6 Server x64\Scripts\converturltohyperlink\ConvertURLToHyperlinkMen
      So what is the problem, what have we not done? Any suggestions please? What is also strange is that we then tested our script using the ExtendedScript application, and it worked fine, but as soon as we try to trigger IndesignServer using a script nothing happens, is this to do with the licensing above?
