2 Replies Latest reply on Jul 12, 2016 9:49 AM by ruthm99420069
    Page Setup
    ruthm99420069
      Every time i set up the paper size and click ok the screen shrinks to a single line. No matter what i do i cannot get it to change unless i use a template and then of course it is the wrong paper size again. I am trying to print to 24 inch aper size. What am i doing wrong?
        • 1. Re: Page Setup
          F. McLion Adobe Community Professional & MVP
          What is your LR version and your OS?
          How do you set up the paper size?
          Print photos from Lightroom
          • 2. Re: Page Setup
            ruthm99420069 Level 1
            LR CC 2015 and OS X El Capitan Version 10.11.5
            I am going to page set up then paper size, custom settings and manually adding the dimensions (which was a 640 roll, the dimensions automatically appeared which were 610mm x 18000mm with 3mm square margins) then ok.
            When i did this the screen would collapse into one long thin line with no illegible ruler on the side and upper bars.
            I got passed this by using a preset size which was 18" x 24"(Arch C) however its printing it as if its on an A1 sheet rather than on a roll.
