2 Replies Latest reply on Jul 12, 2016 10:55 AM by ricks23678806
    Need help with Acrobat Pro JavaScript  -  Force Selection of Radio Button
    ricks23678806
      Hi folks,
      Newbie here again.
      I have a group of 3 radio buttons named  "Payroll".  The three buttons are named:
      9101_Hourly
      8688_Certified
      7380_Bus-Driver
      What JavaScript code will force the user to select one of these buttons before moving on to the next field ?
      Am using Adobe Acrobat Pro  XI.
      Any and all help much appreciated !
      Many thanks & till later,
      Rick Stockstill
      North East Independent School District
      San Antonio, TX
      rstock@neisd.net
        • 1. Re: Need help with Acrobat Pro JavaScript  -  Force Selection of Radio Button
          You might want to this approach. If a user does not understand the form and cannot move out of a field they can become very negative about the form. A possible better approach would be to have a displayed field indicate thing one of the payroll options needs to be selected and when one is selected the message disappears. You should also include some code to verify the payroll type has been completed before the form is saved, printed or closed. You could also make the working time fields locked until the payroll selection has been made.
          Disabling (graying-out) form fields with Acrobat 7 and 8 by Thom Parker. It iwas before version XI so the interface for processing the fields is different but the code and form field features are still the same.
          • 2. Re: Need help with Acrobat Pro JavaScript  -  Force Selection of Radio Button
            ricks23678806 Level 1
            Your input appreciated.  :-)
            That being said, the form is a conversion from having used a Word document in the past.. and people would forget or ignore things we wanted/need them to address.   Use of a PDF form is intended to help them to  "not forget"   and/or  "not ignore"  specific data fields.
            The plan is to send an accompanying 1 page explanation so that expectation will be set before the fact.
            Hope all is well & till later,
            Rick S.
            ps:  would still like some JavaScript code if you have any that will help solve this particular problem.
