8 Replies Latest reply on Jul 12, 2016 12:44 PM by prhmusic2
    Remove list of conditional build expressions - RoboHelp 11
    nicoleg34284383
      I'd like to remove the list of conditional build expressions that accumulate (Single Source Layouts > Right click item > Properties > Conditional Build Expression drop-down list). We often use tags then remove them so eventually those conditional build expressions are no longer needed. It would be best if these expression could be removed because I see them as a mistake waiting to happen.
      After I select an expression, I click Define which opens the Define Conditional Build Tag Expression window. In the Advanced section, I click Clear then OK but the expression still remains in this drop-down. Is there a way to clear this list?
