4 Replies Latest reply on Sep 8, 2016 5:51 AM by paulh54619783
    PDF editing
    sankarg58501687
      While editing the PDF through Acrobat Pro, the images are skewing i.e., realigning the whole page inline to the text box inside.
        • 1. Re: PDF editing
          Adorobat Adobe Employee
          Hi sankarg58501687 ,
          Could you please tell what Operating System do you have - Windows/Mac?
          What product of Acrobat Pro do you have - Acrobat X,XI,DC?
          Could you please post a screenshot here?
          Is this happening with all the files or with this file only?
          Try to exit Acrobat and restart the Computer and then try to edit.
          Thank You!Shivam
          • 2. Re: PDF editing
            sankarg58501687 Level 1
            We are evaluating the trail version to ensure whether Acrobat Pro DC
            is fulfil our requirement or not. In this process, we have edited the PDF
            file to make compatible with text reading on scanned image. Once we edited,
            then the image inside the pdf is rotating based on the text alignment. our
            requirement is to not disturb the scanned image orientation.
            Please refer the snap shots.
            Before Editing is wrongly orientated and correctly scanned in all the
            directions, but where as the same PDF was used for editing then it is
            rotating and creating more gaps along the edges. This indicate others that
            scanning done wrongly.
            Please provide any solution to created the editable text from the scanned
            imaged without disturbing the current layout. Thanks.
            • 3. Re: PDF editing
              onkesh Adobe Employee
              Hi Sankar,
              I need some more information regarding the issue.
              • Can you please specify if this is related to a single files or the issue is reproducible on multiple files?
                • If this is file specific, can you share with us the file.
              • You have mentioned about some screen-shots in your post, they are not visible. Can you share them again?
              • Can you specify the build version of Acrobat DC that you are using?
              • Can you elaborate the steps further?
              • It seems you are working with a scanned file. Can you specify if you had scanned the file directly using Acrobat or has it been supplied to you before hand.
              Looking forward to your cooperation.
              Regards,
              Onkesh
              • 4. Re: PDF editing
                paulh54619783 Level 1
                Hello sankarg58501687,
                If your Image is Skewing then you can follow some different trick to Edit and convert your PDF in a word file. To do these follow these steps:
                First Solution: By using Google Drive
                Go to www.Google.com
                Search for Google Doc and open it.
                Drag and Drop the file you want to edit.
                Wait until uploading and it will be displayed in the drive as shown in the fig.
                Right click on the File and choose the file to OpenWith the Google Docs
                Now, the File would open in New Tab and you can Edit it in the way you want.
                Alternate solution simple solution:
                1. By using SysTools PDF Unlocker
                2. Download PDF Unlocker Software
                3. Browse the restricted PDF file
                4. Select PDF file then Click “Open” Button
                5. Select destination
                6. Then click Unlock PDF Button
                For detailed and clear understanding. kindly refer to the following link:
                Best Ways to Convert Adobe PDF to MS Word and Word To PDF | pdf-tips.blogspot.in
                Thanks & Regards
                Paul Hogan
