10 Replies Latest reply on Jul 16, 2016 8:06 PM by peterg1510
    Crashes with LR6.6 when importing pictures
    manuelaw98189123 Level 1
      Hey dear community,
      has somebody else also the problem, that LR6.6 crashes ( goes to deadlock loop ) when downloading pictures?
      If so, is there a help??
      System I am running
      LR6.6
      MACBookPro mid 2010
      OS X 10.11.4
      The program runs into the mistakes mode unintendetly even having worked for sessions correctly
      My help is : strg-contr-alt-esc and immediately stop program. Afterwards it runs for a while.
      Thanks for a feedback
      Best regards from Frankonia
        • 1. Re: Crashes with LR6.6 when importing pictures
          Tanuj Sandal Adobe Employee
          Hi Frankonia,
          Could you please let me know if you are trying to import images from an external device?
          If yes, try copying the images to the desktop and then try to import the images.
          Also go to the Preferences, and then performance, and make sure the option for "Use graphics processor" is unchecked.
          Regards
          Tanuj
          • 2. Re: Crashes with LR6.6 when importing pictures
            Hey dear Tanuj,
            in short my feedback
            1. "use graphics processor" in unchecked all time
            2. happens as well when importing from Camera ( D800 and CANON G7x) as also directly from the harddisc of the MACBook
            hope this gives you more clearity
            Regards
            • 3. Re: Crashes with LR6.6 when importing pictures
              Thank you for the information.
              I would suggest you to uninstall and reinstall Lightroom once from your computer and then check if the application still freezes or not.
              • 4. Re: Crashes with LR6.6 when importing pictures
                Hey Tanuj
                now I have a problem
                I have uninstalled the programm, but how to download now again?
                I do not find a way from may personal folder how to get it.
                Please send me a hint :-)
                best regards from Frankonia
                • 6. Re: Crashes with LR6.6 when importing pictures
                  peterg1510
                  I have had the same problem since updating to CC 2015.6 [ 1078672 ]. I
                  have no problems with earlier versions.
                  There have been many complaints on the web about this problem However,
                  I don't know if Adobe knows or acknowledges  that there's a major problem.
                  Something in Adobe land is obviously wrong.
                  A long on-line session with Lightroom tech support where they remotely
                  controlled my Mac yielded nothing.
                  It seems that there is a memory leak when going to
                  Import. To see this, launch Mac > Activity Monitor > Memory. When
                  Lightroom tries to launch Import and there's a spinning beach ball,
                  watch Lightroom's memory in Activity Monitor as it climbs into MANY
                  gigabytes. I've had Lightroom try to consume over 26GB of memory! Once
                  the memory starts climbing, doing a Force Quit is the only escape.
                  Lightroom Import eventually works after several failed
                  attempts with no change in the computer's configuration.
                  Things that I've experimented with no luck include:
                       • A long on-line session with Lightroom tech support where they remotely
                       • Turning on/off in System Preferences Lightroom Plug-ins.
                       • Going on & off-line, with and without Creative Cloud. No luck.
                       • Uninstalling & reinstalling Lightroom. Reverted back. Works fine with
                  earlier versions; but, of course, new functions are missing.
                       • Deleting Lightroom's .plist files in the Library.
                  Lightroom creates a new one. You'll have to reselect some preferences.
                  Quitting all other apps Different or no camera cards.
                  Some progress:
                  My theories on the cause of this problem changes with the phase of the
                  moon. Apparently, Adobe has deactivated the full screen mode with this
                  version. If you hover the mouse cursor over the green dot at the top
                  left of the Lightroom window, you will see a plus sign, not the two
                  expansion arrows that's in most other Mac apps. This makes me think
                  that Adobe knows there's a graphics problem. My latest plan of attack
                  is to make the Lightroom window smaller before quitting Lightroom.
                  Have no edge of the Lightroom window touch the screen's edge or top
                  menu. Then quit and relaunch. Lightroom launch time also seems a bit shorter.
                  If Lightroom freezes, I now:
                       1. Force Quit. Relaunch. Do NOT import.
                       2. Make Lightroom window smaller so it does not touch any menu or screen edge.
                       3. Quit. Relaunch.
                  With luck, Import will then work. When it works, in the Import mode, folders in
                  existing hard drives will immediately display. If they don't display, Lightroom will
                  probably freeze and obviously won't import. Have a drink and repeat above steps.
                  Perhaps, by the next full moon, I'll have a different theory.
                  Cheers
                  Peter
                  • 7. Re: Crashes with LR6.6 when importing pictures
                    Hey Peter,
                    seems you are discribing the problem like it is.
                    Would be really good from ADOBE to react on the facts.
                    I hope with Lightroom does not go the way like APERTURE went.
                    Till now I found LIGHTROOM a real good software with an excellent performance and quite good tools
                    Lets hope, somebody is looking more deeply on it.
                    Greetings and again liked the way you have investigated on the phenomena
                    • 8. Re: Crashes with LR6.6 when importing pictures
                      Joseph Ingerham
                      Everyone reading this post,
                      Peter I have been having the same problems with adobe and LightRoom now for over a year now and still they can not correct the issue.  I'm sure if I had some type of issue with my payments they would find a way to make sure I wasn't able to use the program.  I also think it is funny (not really) but the Staff person who was answering all of the questions before you posted your issue all of a sudden stopped responding.  I have spend countless HOURS, yes HOURS on the phone with Adobe and still not fix.
                      It doesn't matter where I import images from; cameras, external hard drives, thumb drives, or the IMac's hard drive itself, LightRoom locks up and restarts the computer.
                      I got so irritated about this issue and so tired of ADOBE saying it is something wrong with my computer or the install, I took my IMAC to Apple and hand THEM do a complete erase of the hard drive and installed a fresh new install of the operating system.  I then went through and reinstalled all of my programs and I still have the same problem with ADOBE LIGHTROOM!!!
                      Apparently ADOBE knows it has a problem and simply has no clue as to how to fix the problem, and instead of telling everyone, because they fear they will abandon ship with adobe products they just simply keep giving the customers the run around, or it seems in this case once again they just stop responding to questions.
                      I guess it is time to start looking around for other programs that will actually work when you need them, and not just crash when you upload photos.  What good is a product that has all kinds of potential but crashes and fails to work when you try an use it.
                      Adobe, if you can fix this problem I would have no problem paying for and using your products; however, I have yet to find anyone who has been helped by you to correct this problem and I have not received any software updates that seem to address this issue.
                      A very unhappy paying customer,
                      Joe
                      • 9. Re: Crashes with LR6.6 when importing pictures
                        peterg1510 Level 1
                        Joe & Manuel
                        Thanks for your replies. I did some more testing with no improvement.
                        Tests included deleting my Mac > User > Login items and all apps that automatically launch when logging in. No luck.
                        I did a single Mac boot in the Safe mode and LR worked. Would have to do many Safe boots to confirm.
                        LR does launch and work OK sometimes with my normal Login items & configuration. Once it works OK, it continues to work OK. In other words, LR either launches and continues to work or it freezes the first time when switching to LR > Import.
                        I have already uninstalled and reinstalled LR 2015.6.  Problem returns.
                        Graphics processor is not checked.
                        EVERY Lightroom freeze is accompanied by a memory leak (perhaps not the correct name), which eventually grows to dozens of GIGAbytes (e.g. >26GB) of memory used according to "Activity Monitor". This never happened with previous Lightroom versions. Reverted back to earlier LR versions, which works OK. Reinstall most recent LR and problem returns.
                        Except for a LR programming bug, I can't think of any reason why another Mac app could cause LR to consume many gigabytes of memory and freeze. The fact that old LR versions work and the newest doesn't tells me something's wrong with the new version. Duh!
                        Although I have not looked deeply, there are some gripes with Windows 10 users with a similar problem.
                        Too bad that Adobe gives no indication that the have even looked at or acknowledged the problem. I'd be happy to send them a crash report, which is created when I Force Quit.
                        Peter
                        • 10. Re: Crashes with LR6.6 when importing pictures
                          peterg1510 Level 1
                          Above is a screen capture showing a frozen Lightroom while it was trying to open the "Import" module.
                          1. In Lightroom, the primary hard drive (Macintosh HD) could not expand to display any folders inside this drive. Other connected drives, including an internal SSD and external HD are not even visible. No SD photo card is plugged in.
                          2. In Activity Monitor, Lightroom wants 31.20GB of memory. I finally Force Quit LR after it got above 41GB. (Once LR memory starts to expand like this, LR will never fix itself.
                          While it may be that another app is conflicting with Lightroom, I think Adobe should be able to write code that's immune from other apps. They could do that with earlier LR versions. I have lots of programs on my Mac and I don't know of any that interfere with another like what's happening in LR.
                          Thanks fer listenin'
                          Peter
