2 Replies Latest reply on Jul 13, 2016 4:34 AM by Loic.Aigon
    Apple or javaScript to make multiple pages
    paturner7
      Hi guys,
      I have an apple script someone made for InDesign CS6 and i am trying to use it in InDesign CC. Unfortunately its not working. Can anyone tell me how to manipulate this script to get it to work in CC?
      See script:
      on open theFolder
      display dialog "How many *Pages* in the catalog?" default answer "" buttons {"Create Spreads", "Cancel"} default button 1
        copy the result as list to {theButton, theNumber}
        if theNumber is "" then
        set theNumber to "force an error" --making the number this string will force an error in the next step
        end if
        try
        set theNumberInt to theNumber as integer --will error if the number of pages entered is a blank or some text and go to the on error section
        set divisor to (theNumberInt mod 2) - 1
        set test to 100 / divisor --will error if the number of pages entered is not an even number end go to the on error section
        tell application "Finder" to set FileList to get every item of (entire contents of folder theFolder) whose kind is "InDesign® CS6 Document"
        set divisor2 to count of items of FileList
        if divisor2 is not 1 then --if there's more than 1 indd v6 document in the folder, this will force an error
        set divisor2 to 0
        end if
        try
        set test2 to 100 / divisor2 --ok there's one and only one indd v6 file in the folder, keep going...
        set fileName to name of item 1 of FileList as text
        set i to 0
        repeat with i from 1 to (theNumberInt / 2) - 1
        set Spot to offset of "002" in fileName
        set divisor3 to 100 / Spot
        set nameStart to text 1 thru (Spot - 1) of fileName
        set namePage to "00" & (2 * i) + 2 as text
        set namePage to characters -1 thru -3 of namePage as text
        set theFile to duplicate item 1 of FileList
        set name of theFile to nameStart & namePage & "A0.indd" as text
        end repeat
        on error
        display dialog "The folder needs to contain a single InDesign version 6 document of page 002." buttons {"OK"} default button 1
        end try
        on error
        display dialog "Please enter an even number." buttons {"OK"} default button 1
        end try
      end open
