1 Reply Latest reply on Jul 13, 2016 2:24 AM by Bernd Alheit
    Hyperlinks not saving properly on Acrobat Pro
    annam1025
      I am editing my resume and using Acrobat Pro to add links to certain words on the document. When doing so the program let's you select the appearance of the link on your document ex) visible rectangle / underlines / invisible, etc etc.
      I have selected a simple underline and it appears correctly in Acrobat Pro, but when I save it as a PDF the links look totally different and there is a solid rectangle around the selected words (where there should be a line). There are shots of the discrepancies below.
      I am a rookie and this is likely a problem with an easy fix. Thanks so much. Screenshot 2016-07-12 20.18.10.pngScreenshot 2016-07-12 20.26.14.png
