Hi I've developed an app with Flash Builder, it's response well when app is running, but when if the app is not running, and I invoke the app from a browser link, then it just start with a blank screen, and if I make a 2nd click on the same link, It moved more step then seems it blocked some where, and if I make the 3rd. click, the app dropped. Does someone experience the same and has a solution?
The clues are:
1. I am running the app on iOS 9.3 and build with Flex 4.15 sdk /air20.
2. It response well if I manual launch it and invoke from browser.
3. The same app running on Android device has no problem.
4. The app will response to the url which the browser sent (the scheme has been modified to invoke the app.)
I found the answer.
Due to the 2nd InvokeEvent coming on different time frame. I don't know why the 2nd InvokeEvent with arguments coming after the expecting function running on iOS where Android use the exactly same procedure.
It gets normal after I delayed the function which expecting the 2nd InvokeEvent arguments for 100 milliseconds.
I found a similar discussion here. It seems like the app need to handle the 2nd invokeEvent fired from the caller. Will try this solution.
I found the answer.
