10 Replies Latest reply on Mar 24, 2009 11:27 AM by Chet Zeshonski
    Multiple conditional build tags
    limacon
      Hi all,
      I have a problem with using multiple conditional build tags in my help project (RoboHelp 7 HTML).
      A, B, C, D tags are used in this project for project files (in Project Manager tab), for the topics in TOC, and for the text in topics.
      1. The topic '1' must be included into the A and B help files. The A and B tags are applied to this topic in the Project Manager and in the TOC. But when the HTML help is generated for the A tag included, and the rest topics excluded, it doesn't contain the topic '1'.
      2. Some text in the topic '2' is marked with D and C tags (topic '2' itself doesn't have any tags applied). When generate the output help file for D or C tag, it does'nt contain this text. It works only if discard one of the tags, and generate help for the tag that was left as applied.
      I could not find an answer either in the Robohelp help or on this forum. I have the impression that I use the functionality incorectly or may be multiple tags don't work in RoboHelp 7..
      Have you ever encountered with this problem?
      Regards,
      Olga
        • 1. Re: Multiple conditional build tags
          RoboColum(n) Level 5
          Hi Olga.
          You can use multiple tags so this isn't the problem. My first question is whether the tags are needed on the TOC. If all you are trying to do is include topics you'd only need to apply these to the topic or its text.
          For "topic 2", can you tell us what build tag expression you are using?
          • 2. Re: Multiple conditional build tags
            limacon Level 1
            Colum, thanks for the response!
            I removed tags for topic from the TOC, but it still doesn't work - the topic is absent in help file (generated for Online tag, see graphics below), despite that the Online tag is applied to this topic in Project Manager.
            Please, view the pictures below, may be it will be easier to undestand and help me :)
            Image 1. Multiple tags for topics and text in Test Project
            Image 2. Settings for HTML Layout (Conditional Build Expression)
            Image 3. The output help file.
            • 3. Re: Multiple conditional build tags
              Hi Olga.
              With the settings in your images what you will do is exclude all topics where the "Print" tag has been applied and then exclude the text from the remaining topics where the "Print" tag has been applied. So if you have two tags applied (one of which is being exlcuded) it will not appear in the output.
              Rick Stone has an article on using build tags which explains things well. Click here to read it. It was written before the days when you could apply tags to TOCs but the premise is still the same.
              • 4. Re: Multiple conditional build tags
                Level 1
                When you generate the A-tagged output, don't exclude anything. Just set up RoboHelp to include A. It will include all text/topics that include the A tag and any untagged text/topics. If you define your build tag expression to include certain tags and exclude other tags, it will get rid of the excluded tags first. So your A-tagged output expression should simply read "A."
                The same approach will probably solve your second problem.
                • 5. Re: Multiple conditional build tags
                  limacon Level 1
                  Column, ChetZeshonski,
                  Thanks a lot for your answers!
                  I read the article written by Rick Stone's. I was confused to learn that conditional build tags functionality in RoboHelp can not be used in way I thought and desired.
                  Thus, to solve the problem, I should duplicate the topics and tag the first copy with 'A' tag, and the second copy with 'B' tag (or 'C' and 'D' tags for text according to examples in my starting post).... This will not make my task easier... :(
                  BTW, does Adobe corporation has an issue tracking system for bugs/feature requests, that is opened for customers and Adobe users (for example like the Atlassian JIRA) ?
                  Regards,
                  Olga
                  • 6. Re: Multiple conditional build tags
                    Hi Olga,
                    Hopefully you will have seen ChetZeshonski post which outlines what to try next and which provides some other answers to your question. This approach would do away with having to maintain different copies of the same topic. The whole reason for conditional build tags is to do away with such an approach.
                    As far as issue tracking is concerned, you are emailed a receipt of any bug/feature request you make and they should contact you when progress has been made with it.
                    • 7. Re: Multiple conditional build tags
                      Should contact you maybe. Will contact you, don't hold your breath.
                      • 8. Re: Multiple conditional build tags
                        limacon Level 1
                        ChetZeshonski,
                        I tried to do what you said and... oh miracle, it works :)
                        Thanks!
                        Olga
                        • 9. Re: Multiple conditional build tags
                          limacon Level 1
                          Ability of using the "Advanced Conditional Build Tag Expression" is not so simple and clear for the RoboHelp user as it may looks.
                          By default, if I select "tag1" by Move Left button and deselect other tags by Move Right arrow in Define CBT Expression dialog box, and indicate which topics must be available and which ones must be excluded, the Expression is written like: "NOT tag2 NOT tag3 ... NOT tagn". But in case when it is written as: "tag1" it works such as I want :)
                          So, I should always edit the expression manually in order to generate correct help.
                          Frankly speaking, I think it would be more logical if RoboHelp developers could write the default Expression without 'NOT' operator, I mean to show tags that are selected as available, not excluded from the output help.
                          Regards,
                          Olga
                          P.S.: I'm getting clever and clever, and feeling as real RoboHelp expert thanks to your answers! Thank you!
                          • 10. Re: Multiple conditional build tags
                            Level 1
                            You're welcome, Olga. Conditional build tag expressions aren't as easy to create as they appear at first glance, but a little trial and error will help you a lot. It certainly helped me.
