4 Replies Latest reply on Jul 14, 2016 12:54 PM by Jump_Over
    I need help with a script to search for missing links on my computer and then relink them.
    Awitmer Level 1
      Hello everybody!
      Recently my IT department at my workplace moved a bunch of files, so I
      literally have hundreds .indd files with missing links. I a script that
      could search the directory for the missing links and then relink them, would
      be really nice to have!
      I found the script below in this forum to find and relink missing links but
      it is not working for me. Below is a screenshot of the message I get when
      the script is finished running. I know the file is in the directory I choose
      because I can find it in Windows explorer. What am I missing?
      Can anybody help me out? I am using Indesign CS6 on a Windows 7 machine. Let
      me know if you need any more info from me.
      Here is the code for the script that I am trying to use.
      //Search computer for missing links.
      var processed = 0
      var skipped = 0
      var updated = 0
      if (app.documents.length > 0){
          if(app.activeDocument.links.length > 0){
              var mydoc = app.activeDocument;
              var mylinks = mydoc.links;
              var myRoot = Folder.selectDialog("Choose the volume or server where
      assets are located", undefined, false);
              main();
      else
      { alert("No Links present")
      else{alert("No Documents Open")
      function main(){
          if(myRoot != null){
              for(var i = 0; i < mylinks.length ; i++){
                  if(mylinks.item(i).status == LinkStatus.linkMissing){
                          var linkdata= mylinks.item(i).filePath;
                          var my_result = linkRepair(linkdata);
                              if (my_result == false){
                                  var filetype = "." + mylinks.item(i).linkType;
                                  var mysearch =  search(linkdata, filetype);
                                      if(mysearch != undefined){
      var myswitch = confirm(mylinks.item(i).name + " has been found in a
      different location, Relink and Update?", "Relinker")
                                              if(myswitch){
      mylinks.item(i).relink(File(mysearch));
                                                  mylinks.item(i).update();
                                  else{
                                      alert("" + mylinks.item(i).name +" was not
      found\nFolders processed: "+processed + "\nFiles skipped: "+ skipped)
                              else{ alert( my_result + " has been found");
                                  mylinks.item(i).relink(File(my_result));
      function linkRepair(linkdata){
      var mypath = linkdata.split(":")
              my_status = analyzePath(mypath)
              if(my_status == true){alert("UPDATED");
                      updated++
          return my_status
      function analyzePath(mypath){
      var num = mypath.length ;
      for(var i = 0; i < num-1; i++){
          mypath.shift()
          var newpath = pathRebuild(mypath)
          newpath = (myRoot + newpath)
              if(File(newpath).exists){
                  return newpath
          return false
      function pathRebuild(pathArray){
      var solidPath = ""
          for(var i = 0; i < pathArray.length ; i++){
              solidPath +=  "/" + pathArray[i] ;
          return solidPath;
      function search(linkdata, filetype){
          var mylink = mypath.pop();
          var OK = confirm("Relative Path does not exist, search folder hiearchy
      for file?", true, "File Scanner")
          if(OK){
      var myscanresult = getfiles(mylink, myRoot)
      return myscanresult
      function getfiles(mylink, myBase){
      myBase = Folder(myBase);
      var files = myBase.getFiles("*")
      for(var i = 0; i < files.length; i++){
      try{
      var foldertest = files[i].getFiles();
      processed++
      var myfile =    File(files[i] + "/" + mylink)
          if(myfile.exists == true){
              return myfile
              break;
          else{
          var myscan = getfiles(mylink, Folder(files[i]))
              if(myscan != undefined){
              return myscan
              break;
      catch(myerror){
          skipped++
      Thanks in advance for your help!!!! I greatly appreciate it!!!
