3 Replies Latest reply on Jul 13, 2016 12:46 PM by Obi-wan Kenobi
    Creating Odd Numbered Lists
    faithm78405282
      Hello,
      My coworkers and I are trying to create an odd numbered list in inDesign for a math textbook we are creating. We can't seem to find any ways across the internet to help us with our problem. We need a list for odd numbered problems, ex:
      1
      3
      5
      7
      etc.
      Does anyone know how to do this?
        • 1. Re: Creating Odd Numbered Lists
          Sandee Cohen Adobe Community Professional
          You're going to need two paragraph styles both set to have numbers.
          Then apply the style 1 to the odd numbers and style 2 to the even numbers.
          Then make the leading and point size of style 2 microscopic
          Then make the character color for style 2 None.
          Finally make your list as
          Style 1 with text
          Style 2 with only a paragraph return
          Style 1 with text
          Style 2 with only a paragraph return.
          Your users will never see the number in style 2 but you will have the effect of an odd numbered list.
          It's very possible someone else will have a more elegant solution. But this is what occurred to me.
          • 2. Re: Creating Odd Numbered Lists
            faithm78405282 Level 1
            We have considered this go around, but it's not in best practice for the level of product we are trying to produce. If there is a way to do this in one paragraph style, character style, or GREP, that is what we are looking for.
            • 3. Re: Creating Odd Numbered Lists
              Obi-wan Kenobi Level 5
              Hi Sandee,
              Elegant trick I use too, playing a double regex to treat the question in batch [1 click using Multi/Find-Change of our friend Martinho da Gloria]!  ;-)
              I use a non-joiner to keep in mind this kind of special use of blank line!
              Note we don't really need to use $0 in the replace-field! Why do I use it: to not forget that we can use:
              $0$0 to have this numbering: 1, 4, 7, 10, …
              $0$0$0;-) to have: 1, 5, 10, 15, …
              Another way I use too allowing more graphic effects on the numbering. 1 click too!
              A third variant: anchoring an invisible auto-num text block [visible outside page] at the beginning of the target paras!
