2 Replies Latest reply on Jul 20, 2016 8:13 AM by TakkZ
    Plugin library version error
    TakkZ Level 1
      Good morning,
      building an app I'm coding I found myself in front of the impossibility to made the build due to a problem with two plugin:
      HelpShift: helpshift-support-plugin and ZeroConf cordova-plugin-zeroconf.
      The first one generates the following error on android:
      :helpshift-support-plugin:nativeSDK:processDebugResources/project/helpshift-support-plugin/dev-nativeSDK/build/intermediates/res/debug/values-v23/values.xml:5: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Inverse'.
      And this on iOS:
      /tmp/gimlet/2078210/project/JarvisDev/Plugins/cordova-plugin-zeroconf/ZeroConf.swift:10:34: error: use of undeclared type 'CDVPlugin'
      @objc(ZeroConf) class ZeroConf : CDVPlugin
      The second plugin, ZeroConf, seems to work on Android, but it doesnt on iOS, giving the same error of HelpShift Plugin.
      I've already tried to put:
      <config-file platform="android" parent="/manifest" mode="merge">
        <uses-sdk android:minSdkVersion="19" android:targetSdkVersion="23"
          android:compileSdkVersion="23" android:buildToolsVersion="23" />
      </config-file>
      in my config.xml file, but it doesn't work,.
      There is a way to made those plugins working with PhoneGap Build or I need to find another solution?
      Thank you,
      Vittorio Giovanelli
        • 1. Re: Plugin library version error
          Chris W. Griffith Adobe Community Professional
          I would suggest contacting the plugin authors to help with this issue.
          Chris
          • 2. Re: Plugin library version error
            TakkZ Level 1
            Thank you, i've done it.
            And they make me notice that, even with
            <preference name="android-targetSdkVersion" value="23" />
            log shows that version 22 is used:
            /android-sdk/build-tools/23.0.1/aapt package -f --no-crunch -I /android-sdk/platforms/android-22/android.jar -M /project/helpshift-support-plugin/dev-nativeSDK/build/intermediates/bundles/debug/Android Manifest.xml -S /project/helpshift-support-plugin/dev-nativeSDK/build/intermediates/res/debug -A /project/helpshift-support-plugin/dev-nativeSDK/build/intermediates/bundles/debug/assets -m -J /project/helpshift-support-plugin/dev-nativeSDK/build/generated/source/r/debug --debug-mode --custom-package com.helpshift --non-constant-id -0 apk --output-text-symbols /project/helpshift-support-plugin/dev-nativeSDK/build/intermediates/bundles/debug
            That generate the exception.
            I've tryed with the
                </config-file>
            But it fails with wrong config.xml error.
            This is the stacktrace on that point:
            :helpshift-support-plugin:nativeSDK:processDebugManifest
            :helpshift-support-plugin:nativeSDK:processDebugResources/project/helpshift-support-plugin /dev-nativeSDK/build/intermediates/res/debug/values-v23/values.xml:5: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Inverse'.
            /project/helpshift-support-plugin/dev-nativeSDK/build/intermediates/res/debug/values-v23/v alues.xml:20: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Colored'.
            FAILED
            FAILURE: Build failed with an exception.
            * What went wrong:
            Execution failed for task ':helpshift-support-plugin:nativeSDK:processDebugResources'.
            > com.android.ide.common.internal.LoggedErrorException: Failed to run command:
              Error Code:
              1
              Output:
              /project/helpshift-support-plugin/dev-nativeSDK/build/intermediates/res/debug/values-v23/ values.xml:5: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Inverse'.
              /project/helpshift-support-plugin/dev-nativeSDK/build/intermediates/res/debug/values-v23/ values.xml:20: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Colored'.
            Thank you for your answer.
