9 Replies Latest reply on Jul 15, 2016 7:48 AM by maria__
    Silent Autoupdate failed
    BruceFeuillette
      Hello !
      Everything was fine until version 19.0.0.185. After installing this version, the autoupdate don't work.
      Nothing has changed in our infrastructure. We proceed like we do usually : deleting the content from pub\flashplayer\update\current\sau and putting the fp_background_update.cab content into. It was working well before.
      currentmajor.xml content
      <version>
      <Player major="22" majorBeta="22"/>
      </version>
      mms.cfg content
      AutoUpdateDisable=0
      SilentAutoUpdateEnable=1
      SilentAutoUpdateServerDomain=flash.internalserver.com
      Flashinstall.log
      2016-7-15+7-47-42.373 [info] 1628 flash.internalserver.com
      2016-7-15+7-47-42.374 [info] 1629 flash.internalserver.com
      2016-7-15+7-47-42.375 [info] 1614
      2016-7-15+7-47-42.375 [info] 1615
      2016-7-15+7-47-42.377 [info] 1618
      2016-7-15+7-47-42.378 [info] 1619 1063
      2016-7-15+7-47-42.399 [info] 1628 flash.internalserver.com
      2016-7-15+7-47-42.401 [info] 1629 flash.internalserver.com
      2016-7-15+7-47-42.402 [info] 1614
      2016-7-15+7-47-42.403 [info] 1615
      2016-7-15+7-47-42.404 [info] 1618
      2016-7-15+7-47-42.406 [info] 1608
      2016-7-15+7-47-42.407 [info] 1612
      2016-7-15+7-47-42.409 [info] 1620
      Nothing more. The Events Manager don't have entries for Flash or something else.
        • 1. Re: Silent Autoupdate failed
          ridhijain Adobe Employee
          Which version fp_background_update.cab are you using? Please try with the latest 22.0.0.210 build. If still you are facing some issues let us know.
          Thanks!
          • 2. Re: Silent Autoupdate failed
            BruceFeuillette Level 1
            I think it's the latest, I've downloaded it this morning from this page : Distribution d'Adobe Flash Player | Adobe
            Flash Player 22.0.0.209 (Mac & Win NPAPI & PPAPI); 22.0.0.210 (Win ActiveX)
            • 3. Re: Silent Autoupdate failed
              The Logs in the screenshot do not have much information. None of the codes is representing an error.
              Could you please add SilentAutoUpdateVerboseLogging=1 entry in the mms.cfg file, delete the FlashInstall.log file and retry. Please provide the FlashInstall.log file. You can upload the same, by going through the instructions provided How to share a document
              Thanks!
              • 4. Re: Silent Autoupdate failed
                The log was generated with verbose logging.
                Something happens later today.
                2016-7-15+7-59-0.200 [info] 1628 flash.internalserver.com
                2016-7-15+7-59-0.250 [info] 1629 flash.internalserver.com
                2016-7-15+7-59-0.301 [info] 1614
                2016-7-15+7-59-0.351 [info] 1615
                2016-7-15+7-59-0.402 [info] 1618
                2016-7-15+7-59-0.876 [info] 1619 1063
                2016-7-15+7-59-1.34 [info] 1628 flash.internalserver.com
                2016-7-15+7-59-1.35 [info] 1629 flash.internalserver.com
                2016-7-15+7-59-1.36 [info] 1614
                2016-7-15+7-59-1.38 [info] 1615
                2016-7-15+7-59-1.39 [info] 1618
                2016-7-15+7-59-1.41 [info] 1604
                2016-7-15+7-59-1.41 [info] 1608
                2016-7-15+7-59-1.43 [info] 1612
                2016-7-15+7-59-1.45 [info] 1620
                2016-7-15+8-59-0.440 [info] 1628 flash.internalserver.com
                2016-7-15+8-59-0.490 [info] 1629 flash.internalserver.com
                2016-7-15+8-59-0.541 [info] 1614
                2016-7-15+8-59-0.591 [info] 1615
                2016-7-15+8-59-0.640 [info] 1618
                2016-7-15+8-59-0.689 [info] 1619 1063
                2016-7-15+8-59-0.780 [info] 1628 flash.internalserver.com
                2016-7-15+8-59-0.781 [info] 1629 flash.internalserver.com
                2016-7-15+8-59-0.782 [info] 1614
                2016-7-15+8-59-0.783 [info] 1615
                2016-7-15+8-59-0.784 [info] 1618
                2016-7-15+8-59-0.786 [info] 1604
                2016-7-15+8-59-0.789 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
                2016-7-15+8-59-1.232 [warning] 1470 12175
                2016-7-15+8-59-1.233 [warning] 1474 183
                2016-7-15+8-59-1.234 [warning] 1475
                2016-7-15+8-59-1.235 [info] 1432
                2016-7-15+8-59-1.237 [info] 1612
                2016-7-15+8-59-1.238 [info] 1620
                i don't know why it occurs at 8h59 and not a 7h59. Nothing has changed on the server.
                EDIT : I think I got something. It appears that the self signed certificate on IIS 6.1 has expired on november. I'll investigate on this.
                Is there a way to disable SSL on the update ? We're running our own update server and only corporate computers are doing updates.
                EDIT 2 : I've used SelfSSL to issue a new certificate (self signed too) but the problem is still here.
                2016-7-15+12-17-25.464 [info] 1628 flash.internalserver.com
                2016-7-15+12-17-25.465 [info] 1629 flash.internalserver.com
                2016-7-15+12-17-25.466 [info] 1614
                2016-7-15+12-17-25.467 [info] 1615
                2016-7-15+12-17-25.468 [info] 1618
                2016-7-15+12-17-25.470 [info] 1619 1063
                2016-7-15+12-17-25.595 [info] 1628 flash.internalserver.com
                2016-7-15+12-17-25.597 [info] 1629 flash.internalserver.com
                2016-7-15+12-17-25.598 [info] 1614
                2016-7-15+12-17-25.599 [info] 1615
                2016-7-15+12-17-25.600 [info] 1618
                2016-7-15+12-17-25.602 [info] 1608
                2016-7-15+12-17-25.603 [info] 1612
                2016-7-15+12-17-25.605 [info] 1620
                2016-7-15+12-32-19.402 [info] 1628 flash.internalserver.com
                2016-7-15+12-32-19.452 [info] 1629 flash.internalserver.com
                2016-7-15+12-32-19.503 [info] 1614
                2016-7-15+12-32-19.552 [info] 1615
                2016-7-15+12-32-19.602 [info] 1618
                2016-7-15+12-32-19.667 [info] 1619 1063
                2016-7-15+12-32-19.721 [info] 1628 flash.internalserver.com
                2016-7-15+12-32-19.721 [info] 1629 flash.internalserver.com
                2016-7-15+12-32-19.721 [info] 1614
                2016-7-15+12-32-19.721 [info] 1615
                2016-7-15+12-32-19.721 [info] 1618
                2016-7-15+12-32-19.721 [info] 1604
                2016-7-15+12-32-19.737 [info] 1608
                2016-7-15+12-32-19.738 [info] 1612
                2016-7-15+12-32-19.740 [info] 1620
                2016-7-15+12-34-37.616 [info] 1628 flash.internalserver.com
                2016-7-15+12-34-37.666 [info] 1629 flash.internalserver.com
                2016-7-15+12-34-37.715 [info] 1614
                2016-7-15+12-34-37.765 [info] 1615
                2016-7-15+12-34-37.815 [info] 1618
                2016-7-15+12-34-37.865 [info] 1619 1063
                2016-7-15+12-34-38.4 [info] 1628 flash.internalserver.com
                2016-7-15+12-34-38.5 [info] 1629 flash.internalserver.com
                2016-7-15+12-34-38.6 [info] 1614
                2016-7-15+12-34-38.7 [info] 1615
                2016-7-15+12-34-38.8 [info] 1618
                2016-7-15+12-34-38.10 [info] 1608
                2016-7-15+12-34-38.11 [info] 1612
                2016-7-15+12-34-38.13 [info] 1620
                • 5. Re: Silent Autoupdate failed
                  It seems since you have already tried performing an Update on the machine you are facing the issue as there are registry entries present which are not allowing update.
                  Could you delete the following entries and try once:
                  1. Go to run and type regedit. Traverse to path HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerSAU
                  2. Delete UpdateAttempts and LastUpdateCheck and modify the value for CheckFrequency to 0.
                  3. Then retry the process of updation.
                  • 6. Re: Silent Autoupdate failed
                    Ah ! I was searching the registry key as I remember there was something to do with it.
                    but still no luck.
                    2016-7-15+13-23-7.22 [info] 1628 flash.internalserver.com
                    2016-7-15+13-23-7.345 [info] 1629 flash.internalserver.com
                    2016-7-15+13-23-7.395 [info] 1614
                    2016-7-15+13-23-7.444 [info] 1615
                    2016-7-15+13-23-7.494 [info] 1618
                    2016-7-15+13-23-7.544 [info] 1619 1063
                    2016-7-15+13-23-7.673 [info] 1628 flash.internalserver.com
                    2016-7-15+13-23-7.674 [info] 1629 flash.internalserver.com
                    2016-7-15+13-23-7.675 [info] 1614
                    2016-7-15+13-23-7.676 [info] 1615
                    2016-7-15+13-23-7.677 [info] 1618
                    2016-7-15+13-23-7.679 [info] 1608
                    2016-7-15+13-23-7.682 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
                    2016-7-15+13-23-7.956 [warning] 1470 12175
                    2016-7-15+13-23-7.958 [warning] 1474 183
                    2016-7-15+13-23-7.959 [warning] 1475
                    2016-7-15+13-23-7.960 [info] 1432
                    2016-7-15+13-23-7.961 [info] 1612
                    2016-7-15+13-23-7.963 [info] 1620
                    Something is wrong with the SSL. The last thing is that the certificate is self-signed... as before it expires but it was fine.
                    • 7. Re: Silent Autoupdate failed
                      maria__ Adobe Employee
                      BruceFeuillette
                      The issue is with the certificate.  Background Updates requires SSL regardless if it's hosted internally or not, due to security reasons (internal security breeches do happen).
                      For the warnings:
                      1470 = WinHttpSendRequest call to currentmajor.xml failed
                      1474 = WinHttpReceiveResponse call to currentmajor.xml failed
                      1475 = Could not retrieve currentmajor.xml
                      12175 Is the corresponding Microsoft error code: ERROR_WINHTTP_SECURE_FAILURE
                      Resolving the SSL cert issue should resolve this issue.
                      • 8. Re: Silent Autoupdate failed
                        Ok, I eventually got it...
                        The self signed certificate on IIS has expired on november but we missed it.
                        I had to use SelfSSL in the IIS resource toolkit to create a new certificate until 2043. I should be retired at that time !
                        The tough part was to update the GPO to install this new certificate in the computer store. I completely forgot it.
                        Now it's running fine and Flash is up-to-date on my computer. The others 360 PCs will do it later
                        Thanks for the registry trick that lead to a better log !
                        • 9. Re: Silent Autoupdate failed
                          Treat. Glad you were able to resolve the issue and everything is working now.
