4 Replies Latest reply on Feb 22, 2018 2:53 PM by Tripodtrisha
    Crop/resize clip
    Fältbutiken Level 1
      How can I crop or and resize a clip in a video? By accident I captured some things in the corner of one video that I need to crop away.
        • 1. Re: Crop/resize clip
          petergaraway Adobe Employee
          Hello!
          At this time Clip does not have that feature. What you can do is, edit your project in Clip and then tap the 'Share' button and select 'Send to Premiere Pro' and make any further changes there including cropping or resizing your video.
          Keep on the lookout for future versions.
          Best,
          Peter Garaway
          • 2. Re: Crop/resize clip
            Jimi_O Level 1
            Cropping a video is super easy. No one on this forum points to this cropping tool.....
            Click on your video in your timeline. Go to your EFFECTS Tab > VIDEO EFFECTS>TRANSFORM>CROP........
            Either Double Click on CROP or drop it into your clip
            In your EFFECTS CONTROL WINDOW you now have the options to adjust all 4 sides of the video in a Percentage amount that you want.
            Simply add the percentage amount, OR, put your curser over the %, hold the button down and move your mouse left/right to decrease or increase that parameter... there's also a zoom option underneath for a nice effect when needed
            Hope this helps!!!
            • 3. Re: Crop/resize clip
              Thanks for the response JO but this user is referring to Premiere Clip our Mobile editing app, not Premiere Pro.
              Best,
              Peter Garaway
              • 4. Re: Crop/resize clip
                Tripodtrisha
                Although I don't know about the apps and don't have Pro, I think I found a way to do this in Premier Elements 15. I selected the clip, then clicked on the image in the monitor box and then dragged the corner out to pull the image past the edge. I was able to get rid of a couple things that were in both the bottom edge and the side without distorting the image or ending up with a black boarder. Don't know if this helps. I am still learning this program myself.
                Trisha
