10 Replies Latest reply on Jul 17, 2016 10:19 PM by RoninEdits
    Premiere CPU utilization peaks around 50%
    Howard Hoffman Level 1
      [Posted initially in Premiere forum.  Was suggested to move it here.]
      I was running Premiere Pro CS 6 on Windows 7 (SSD) with 16 GB RAM.  Premiere can reach nearly 100% CPU utilization in things such as image stabilization.
      I just did a clean installation of Windows 10 on new SSD (the only change in the PC).  Now it peaks around 50%.  The CPU has 8 physical cores (AMD FX 8320E) and I can see all of them are in use nearly 50%.  One thing noticeable is that the core are running at only around 2 GHz while the max is 3.5 GHz (no overclock).  When encoding finishes,   Changing power plan does not have any effect.
      This is not just the reported number is low.  The stablizer runs only at about half the speed (frame per sec) compared to the old SSD.
      Windows 10 Pro 64-bit
      AMD FX 8320E (8-core) with 16 GB RAM
      MSI 970A-G46N
      Vidia GeForce GT 710
      Hard Drive: 1 SSD, 2 spin
      I've checked
      CPU affinity (all core)
      Memory set-aside in preference (changed to a small number and task manager shows only about 9 out of 16 GB of RAM are used).
      Is there any other things I could check?  I know this might not be just a Premiere (could be OS).
