0 Replies Latest reply on Jul 18, 2016 11:20 AM by Mr.Chahu
    Faulting application name: InDesign.exe, version: 11.4.0.90, time stamp: 0x574c8600
    Mr.Chahu
      I have been getting this message when InDesign is or upon launched the other Adobe cloud applications open fine except for InDesign
      this is what has been done so.
      UnInstall all the application and all Adobe Creative Cloud Applications as well (None was left in the system in other words)
      Delete All Adobe Applications Including Flashmedia and Adobe reader as well
      Delete All Adobe Folders from inside AppData Roaming and Also LOCAL
      Delete All Folders Inside Appdata  LocalLow as well
      Download the Adobe Uninstaller and run it to be sure 100% that there is no adobe applications whatsoever in the system (No adobe Folders here)
      I Also Ensure Deleting all Folders under  C:\Program Files (x86)  and Also C:\Program Files as well  (No adobe folders here)
      Ensure Folder C:\Program Files (x86)\Common\Adobe   also ((Deleted Folder)
      Folder Deleted as well is C:\Program Files\Common\Adobe
      I Use the Adobe Creative Cloud (CC) Cleaner Tool    <<<=== Launched and Delete ALL Keys and Applications for Adobe and Choose English
      Here below are the System Analysis logs that i have collected to furnish with the best possible information
      I also used these 2 Threads below to resolve the issue but none were useful
      https://forums.adobe.com/thread/2171975
      https://forums.adobe.com/thread/717953
      Please See Below the messages after a brand clean install of the Adobe Creative Cloud
      FYI:  Computer is attached to a domain but has full Administrator priviledge to execute any admin command
      Log Name:      Application
      Source:        Application Error
      Date:          7/1/2016 5:07:27 PM
      Event ID:      1000
      Task Category: (100)
      Level:         Error
      Keywords:      Classic
      User:          N/A
      Computer:      LCPBXXXXXX
      Description:
      Faulting module name: LogSession.dll, version: 7.3.1.72, time stamp: 0x5629df39
      Exception code: 0xc0000005
      Fault offset: 0x00000000000c8103
      Faulting process id: 0x1128
      Faulting application start time: 0x01d1d3dc866828e3
      Faulting application path: C:\Program Files\Adobe\Adobe InDesign CC 2015\InDesign.exe
      Faulting module path: C:\Program Files\Adobe\Adobe InDesign CC 2015\LogSession.dll
      Report Id: cffa745b-3fcf-11e6-b979-0021ccd16e10
      Event Xml:
      <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
        <System>
          <Provider Name="Application Error" />
          <EventID Qualifiers="0">1000</EventID>
          <Level>2</Level>
          <Task>100</Task>
          <Keywords>0x80000000000000</Keywords>
          <TimeCreated SystemTime="2016-07-01T21:07:27.000000000Z" />
          <EventRecordID>95191</EventRecordID>
          <Channel>Application</Channel>
          <Computer>LCPB379C0.kma.local</Computer>
          <Security />
        </System>
        <EventData>
          <Data>InDesign.exe</Data>
          <Data>11.4.0.90</Data>
          <Data>574c8600</Data>
          <Data>LogSession.dll</Data>
          <Data>7.3.1.72</Data>
          <Data>5629df39</Data>
          <Data>c0000005</Data>
          <Data>00000000000c8103</Data>
          <Data>1128</Data>
          <Data>01d1d3dc866828e3</Data>
          <Data>C:\Program Files\Adobe\Adobe InDesign CC 2015\InDesign.exe</Data>
          <Data>C:\Program Files\Adobe\Adobe InDesign CC 2015\LogSession.dll</Data>
          <Data>cffa745b-3fcf-11e6-b979-0021ccd16e10</Data>
        </EventData>
      </Event>
      Source:        ASP.NET 4.0.30319.0
      Date:          7/1/2016 4:15:42 PM
      Event ID:      1020
      Task Category: Setup
      Level:         Warning
      Keywords:      Classic
      User:          N/A
      Computer:      LCPXXXXXX
      Description:
      Updates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NET to run in IIS, please install or enable IIS and re-register ASP.NET using aspnet_regiis.exe /i.
      Event Xml:
        <System>
          <Provider Name="ASP.NET 4.0.30319.0" />
          <EventID Qualifiers="32768">1020</EventID>
          <Level>3</Level>
          <Task>1</Task>
          <TimeCreated SystemTime="2016-07-01T20:15:42.000000000Z" />
          <EventRecordID>95144</EventRecordID>
          <Security />
        </System>
        <EventData>
        </EventData>
      </Event>
      Date:          7/5/2016 5:04:04 PM
      Event ID:      1000
      Level:         Error
      Keywords:      Classic
      User:          N/A
      Computer:      LCPXXXXXX
      Description:
      Faulting process id: 0x150c
      Faulting application start time: 0x01d1d7009db46229
      Report Id: 00f95724-42f4-11e6-b7ef-0021ccd16e10
      Event Xml:
        <System>
          <Level>2</Level>
          <Task>100</Task>
          <TimeCreated SystemTime="2016-07-05T21:04:04.000000000Z" />
          <EventRecordID>95642</EventRecordID>
          <Computer>LCPBXXXXXl</Computer>
          <Security />
        </System>
        <EventData>
          <Data>150c</Data>
          <Data>01d1d7009db46229</Data>
          <Data>00f95724-42f4-11e6-b7ef-0021ccd16e10</Data>
        </EventData>
      </Event>
      Source:        Windows Error Reporting
      Date:          7/5/2016 6:24:54 PM
      Event ID:      1001
      Task Category: None
      Level:         Information
      Keywords:      Classic
      User:          N/A
      Computer:      LCPBXXXXXl
      Description:
      Fault bucket 240118888, type 28
      Event Name: APPCRASH
      Response: Not available
      Cab Id: 0
      Problem signature:
      P1: InDesign.exe
      P2: 11.4.0.90
      P3: 574c8600
      P4: LogSession.dll
      P5: 7.3.1.72
      P6: 5629df39
      P7: c0000005
      P8: 00000000000c8103
      P9:
      P10:
      C:\Users\A04001\AppData\Local\Temp\WERB1C5.tmp.WERInternalMetadata.xml
      These files may be available here:
      C:\Users\A04001\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_InDesign.exe_5f 33a5a1795baaf824fece0d270a0b6f044ac1_1978d108
      Analysis symbol:
      Rechecking for solution: 0
      Report Id: 80a21123-42fe-11e6-b7ef-0021ccd16e10
      Report Status: 0
      Event Xml:
        <System>
          <Provider Name="Windows Error Reporting" />
          <EventID Qualifiers="0">1001</EventID>
          <Level>4</Level>
          <Task>0</Task>
          <TimeCreated SystemTime="2016-07-05T22:24:54.000000000Z" />
          <EventRecordID>95686</EventRecordID>
          <Security />
        </System>
        <EventData>
          <Data>240118888</Data>
          <Data>28</Data>
          <Data>APPCRASH</Data>
          <Data>Not available</Data>
          <Data>0</Data>
          <Data>
          </Data>
          <Data>
          </Data>
          <Data>
      C:\Users\A04001\AppData\Local\Temp\WERB1C5.tmp.WERInternalMetadata.xml</Data>
          <Data>C:\Users\A04001\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_InDesign .exe_5f33a5a1795baaf824fece0d270a0b6f044ac1_1978d108</Data>
          <Data>
          </Data>
          <Data>0</Data>
          <Data>80a21123-42fe-11e6-b7ef-0021ccd16e10</Data>
          <Data>0</Data>
        </EventData>
      </Event>
      Date:          7/5/2016 6:19:13 PM
      Event ID:      1000
      Level:         Error
      Keywords:      Classic
      User:          N/A
      Description:
      Faulting process id: 0x6dc
      Faulting application start time: 0x01d1d70b021efabc
      Event Xml:
        <System>
          <Level>2</Level>
          <Task>100</Task>
          <TimeCreated SystemTime="2016-07-05T22:19:13.000000000Z" />
          <EventRecordID>95681</EventRecordID>
          <Security />
        </System>
        <EventData>
          <Data>6dc</Data>
          <Data>01d1d70b021efabc</Data>
        </EventData>
      </Event>
