2 Replies Latest reply on Jul 22, 2016 7:35 AM by tomb92212784
    RoboHelp Entry Screen Size
    tomb92212784 Level 1
      My entry screen in RoboHelp is quite long (15'?) which results in the text size being quite small (see attached). The resulting text in the generated/output file is as expected.
      If I increase the % in the View section of the Edit tab, it helps somewhat, however I now need to scroll right to get to the rest of the screen.
      Is there a way to reduce the width of the work space that will also result in a larger text size without the need to scroll? I've been using RH for several years and have never had to work with text this small.
      RH2015 12.0.1.338
