I cannot open files from Open Library with Adobe Digital Editions. Authorisation gets stuck or program crashes immediately, whether I use an Adobe login or only a local authorisation.
Do used with operating system? Get you a error message?
'Adobe Digital Editions 4.5.1 has stopped working.
A problem caused the program to stop working correctly [...]'
Operating system Windows 7 Enterprise
Has you try right click and run as admin?
I cannot get through the authorisation screen, regardless of whether I start the program as an admin or in the normal way, regardless of whether I select the Adobe login or only the local authorisation without login. I can reset to the factory settings after the program crashes, but I cannot get beyond the login.
What happens when press shortcut: STRG + SHIFT + U?
That combination conjures up the authorisation window. I then have the option to select an 'eBook supplier', which has Adobe ID as default, and then two fields to fill: Adobe-id and password. I can also skip those fields and tick the box 'Authorise computer without id'. Whatever I do, in both cases the authorisation does not work and after a few minutes or hours I have to cancel the procedure again.
What happends when you enter the adobe id and password?
That's when the endless authorisation starts. If that authorisation is manually interrupted, the program will crash on start-up. If the factory settings are reset, the program won't crash, but neither will the authorisation work. The program has been re-installed several times.
I have been having same problem ADE sees the Kobo but won't when I arrow towards it Kobo is "grey"
Takes ages to load ADE
1 st poster can u read your book on the computer?
what key is STRG
No, I cannot read the book on the computer because it requires Adobe Digital Editions. I think I have to just give up. Thanks for all your replies.
Do you have a second email? If not get and then start a fresh attempt
Also I found trying to aurh very difficult If I remember correcty. I got to my final auth through the help button in the ADE.
I also Uninstalled ADE 4.5. And then installed ADE3 I have. Win 8.1 and it now all works. Keeping fingers crossed
