5 Replies Latest reply on Jul 22, 2016 10:05 AM by gkaiseril
    javascript to show date field in the format as below
    rakeshk21205956 Level 1
      I am making a form in which client need the date to be shown in the format as below
      Like if he puts  date  13/05/2015 then it should show  as  May 13th, 2016  (plz note there should be "th" after 13)
                                        19/07/2016  should show as July 19th, 2016     ("th" after 19 should be there)
      Thanking you
        • 1. Re: javascript to show date field in the format as below
          There's no built-in option to do that (the problem is the "-th" suffix). You will need to write your own custom Format script to achieve it.
          • 2. Re: javascript to show date field in the format as below
            could you provide me with the javascript .
            • 3. Re: javascript to show date field in the format as below
              This way of enumerating numbers is known as "Ordinal". There are many was to script this. What works for web JavaScript can easily work with little modification in Acrobat forms. This type of date format is usually used in legal forms.
              You should be able to search the forums for "legal date" or "ordinal" and find the post.
              I found a JavaScript function that can take as input a number and returns the number with the ordinal suffix. This allows you to create any number of date formats.
              This function is not limited to just dates bat can be used to add the ordinal suffix to any number.
              The function:
              function ordinal_suffix_of(I)I
                  var j = i % 10, // 10's remainder
                      k = i % 100, //100's remainder
                      cSuffix = "th"; // default suffix result
                  if (j == 1 && k != 11) {
                // not 11;
                      cSuffix = "st";
                  if (j == 2 && k != 12) {
                // not 12;
                      cSuffix = "nd";
                  if (j == 3 && k != 13) {
                // not 13;
                      cSuffix = "rd";
                  return i + cSuffix;
              } // end ordial_suffix function;
              I would place this code in the document level script location and then call it as needed in the various fields.
              I would enter the date in different field that would not print and then have the formatted date in a different field. You should know how to split the inputted date string into the month, date, and year parts and then rearrange them as needed.
              You can test the code using the Acrobat JavaScript console:
              function ordinal_suffix_of(i)
                // not 11;
                      cSuffix = "st";
                // not 12;
                      cSuffix = "nd";
                // not 13;
                      cSuffix = "rd";
                  return i + cSuffix;
              function MyDateFormat(cFormat, cDate)
              var oDate = util.scand(cFormat, cDate);
              if(oDate == null)
              {app.alert("Invalid date provided", 1, 0);
              else
              return util.printd("mmmm", oDate) +" " + ordinal_suffix_of(oDate.getDate()) + ", " + util.printd("yyyy", oDate);
              var dateInput = "13/05/2015"; // inputted date value;
              var cFormattedDate = MyDateFormat("d/mm/yyyy", dateInput); // formatted string for date;
              console.println(cFormattedDate);
              dateInput = "23/5/2015";
              console.println(MyDateFormat("d/mm/yyyy", dateInput));
              dateInput = "19/07/2015";
              dateInput = "9/07/2015";
              • 4. Re: javascript to show date field in the format as below
                Sir,
                I am not able to make this work for my form,,, plz explain where i am going wrong..
                • 5. Re: javascript to show date field in the format as below
                  Your posts do not show me what you are doing.
                  The following link connects to working form:
                  OrdinalSuffix
