7 Replies Latest reply on Sep 25, 2017 1:49 AM by valedange
    How to: Unlinking or Unthread Text Boxes in InDesign
    Ala'a Assamawy Level 1
      Hello,
      I'm working on 300 pages report, how can I break the thread between chapters? please see the figure blow:
      Note: I'm using InDesign CC 2015 on Mac
      Thank you,
        • 1. Re: How to: Unlinking or Unthread Text Boxes in InDesign
          George_Salnik Adobe Community Professional
          What the problem with to unthread and cut-paste overset to next chapter frame?
          You can also use splitstory.jsx (default script in indesign), but than will need to recreate needed threads.
          • 2. Re: How to: Unlinking or Unthread Text Boxes in InDesign
            Thank you GeorgeS,
            Is there another way to do that.. the document I'm working on is huge, "unthread" and "cut-paste" will take a lot of time.
            • 3. Re: How to: Unlinking or Unthread Text Boxes in InDesign
              Daniel Flavin Level 4
              Do you actually need to split the threads or is your goal to force a chapter start on a new page?
              (Insert Break Character - Page Break - Odd Page Break - Even Page Break)
              • 4. Re: How to: Unlinking or Unthread Text Boxes in InDesign
                Obi-wan Kenobi Level 5
                Hi George,
                StorySplitter_AdiRavid.jsx
                • 5. Re: How to: Unlinking or Unthread Text Boxes in InDesign
                  StorySplitter
                  An InDesign CS/CS2/CS3 JavaScript by FourAces
                  © The Final Touch 2006
                  Version 3.0.0
                  Splits the selected Story to separate Text Frames, while maintaining their contents.
                  var myScriptVer = "3.0";
                  if(app.documents.length != 0){
                            var mySelection = app.activeDocument.selection;
                            if(mySelection.length != 0){
                                      myObjectType = mySelection[0].constructor.name;
                                      if(myObjectType == "TextFrame"){
                                                //The Interface Dialog
                                                var myDialog = app.dialogs.add({name:"Story Splitter v"+ myScriptVer});
                                                with(myDialog){
                                                          with(dialogColumns.add()){
        with (dialogRows.add()){
        with(borderPanels.add()){
        var mySplitOptions = radiobuttonGroups.add();
        with(mySplitOptions){
        radiobuttonControls.add({staticLabel:"Split All Frames", checkedState:true});
        radiobuttonControls.add({staticLabel:"Split Before Selected Frame"});
        radiobuttonControls.add({staticLabel:"Split After Selected Frame"});
        staticTexts.add({staticLabel:"© The Final Touch"});
                                                var myResult = myDialog.show({name:"SplitOptions"});
                                                if(myResult == true){
                                                          var myStory = mySelection[0].parentStory;
                                                          if(app.version.split(".")[0] >= 5){
        var myTextFrames = myStory.textContainers;
                                                          else{
        var myTextFrames = myStory.textFrames;
                                                          var myStoryFramesCount = myTextFrames.length;
                                                          if(myStoryFramesCount > 1){
        for(f = 0; f < myStoryFramesCount; f++){
        if (mySelection[0] == myStory.textFrames[f]){
        var myTextFrame = f;
        switch(mySplitOptions.selectedButton){
        case 0:
        mySplitAll();
        break;
        case 1:
        mySplitBefore();
        break;
        case 2:
        mySplitAfter();
        break;
                                                          else{
        alert("Are You Kidding Me?!\nThe Story you selected has only ONE text frame.");
                                      else{
                                                alert("Wrong Selection\nYou selected the wrong type of object. Please select a Text Frame.");
                            else{
                                      alert("No Selection Made.\nPlease select a Story to split.");
                  else{
                            alert("No Active Document Found.\nPlease open an InDesign document and select a Story to split.");
                  function mySplitAll(){
                            for(i = 0; i < myStoryFramesCount; i++){
                                      myTextFrames[i].duplicate();
                                                myTextFrames[i].remove();
                                      else{
                                                myTextFrames[0].remove();
                  function mySplitBefore(){
                            if(mySelection[0].previousTextFrame == null){
                                      alert("Unable Break Thread.\nThe selected Text Frame is the FIRST text frame of the thread.");
                            else{
                                      var myBfBreakFrame = mySelection[0].previousTextFrame;
                                      var myAfBreakFrame = mySelection[0];
                                      var myBreakStory = myBfBreakFrame.parentStory;
                                      mySelection[0].previousTextFrame = null;
                                      if(myBfBreakFrame.overflows == true){
                                                var myOversetText = myBreakStory.texts.itemByRange(myBfBreakFrame.insertionPoints[-1],myBreakStory.insertionPoints[-1]);
                                                myOversetText.select();
                                                app.cut();
                                                app.select(myAfBreakFrame.insertionPoints[0]);
                                                app.paste();
                  function mySplitAfter(){
                            if(mySelection[0].nextTextFrame == null){
                                      alert("Unable Break Thread.\nThe selected Text Frame is the LAST text frame of the thread.");
                            else{
                                      var myBfBreakFrame = mySelection[0];
                                      var myAfBreakFrame = mySelection[0].nextTextFrame;
                                      mySelection[0]          .nextTextFrame = null;
                                                app.cut();
                                                app.paste();
                  When a script is greatly written, it's for eternity! It works perfectly with ID CC!
                  Thanks a lot Adi!
                  2 people found this helpful
                  • 6. Re: How to: Unlinking or Unthread Text Boxes in InDesign
                    I like each chapter to be its own story, myself. It prevents unintentional page count changes during editing while warning you about overset text. Dave Saunders wrote a script to divide a story at any given frame which will work well for this: JavaScripting InDesign: Script of the Day -- Divide Story into Two
                    Not sure how many versions newer than CS it will run in natively, but if it fails, it should run if you put it in a subfolder of the scripts panel folder named Version 3.0 Scripts (the name is case sensitive).
                    • 7. Re: How to: Unlinking or Unthread Text Boxes in InDesign
                      valedange Level 1
                      Thank you, great plugin! It works fine with ID CC2017
